hye..I have two Xbees and two Arduinos coded to control angle of servo motor. How could I code both of them . I think we need a sender and receiver code. On the receiver ,I'm already have the receiver code, but I have no idea for sender code. I'm a total beginner. Thanks!
I want to create a wireless servo controller to control angle of servo motor . Now the problem is I don't know how to write the code:(
The above code that I posted is "receiver code".but could you please tell me how to write the (transmitter/sender) code for control the angle of servo?
actually I have just tried by myself to write the transmitter/sender code,but it doesn't work(something wrong with the code)...any help I will appreciate it.
At the moment your problem seems to be the communication, so I suggest you ignore the servo for now and just concentrate on getting communication working between two XBees. I suggest that Google is your friend here.
You probably could use the below test code for both sending and receiving. For testing, skip the xbees, and connect the sending arduino tx pin to the receiving arduino rx pin (and connect both arduino grounds together). Send a servo position command to the sending arduio via the serial monitor, and it will echo the command to the receiving arduino via the tx/rx connection.
// zoomkat 10-22-11 serial servo test
// type servo position 0 to 180 in serial monitor
// or for writeMicroseconds, use a value like 1500
// for IDE 0022 and later
// Powering a servo from the arduino usually *DOES NOT WORK*.
String readString;
#include <Servo.h>
Servo myservo; // create servo object to control a servo
myservo.writeMicroseconds(1500); //set initial servo position if desired
myservo.attach(7); //the pin for the servo control
Serial.println("servo-test-22-dual-input"); // so I can keep track of what is loaded
while (Serial.available()) {
char c = Serial.read(); //gets one byte from serial buffer
readString += c; //makes the string readString
delay(2); //slow looping to allow buffer to fill with next character
if (readString.length() >0) {
Serial.println(readString); //so you can see the captured string
int n = readString.toInt(); //convert readString into a number
// auto select appropriate value, copied from someone elses code.
if(n >= 500)
Serial.print("writing Microseconds: ");
Serial.println(n);
myservo.writeMicroseconds(n);
Serial.print("writing Angle: ");
Serial.println(n);
myservo.write(n);
readString=""; //empty for next input
here..alike code as above.. but mine is used to debug my servo.. i used PWMServo lib bcoz Servo.h seems like having conflict with SoftwareSerial.h.. i used softwareserial for my GPS module before this
Servo debugger by Heiswayi Nrird
#include <PWMServo.h> // library Servo.h conflicts with SoftwareSerial.h
PWMServo servo; // SERVO_PIN_A = pin 9 | SERVO_PIN_B = pin 10
char junk = ' ';
int angle;
void setup() // run once, when the sketch starts
Serial.begin(9600); // set up Serial library at 9600 bps
Serial.println("Enter value of angle (0 - 180) to drive the servo");
Serial.flush();
servo.attach(SERVO_PIN_A); // pin 9
servo.write(90);
while (Serial.available() == 0) ; // Wait here until input buffer has a character
angle = Serial.parseInt(); // new command in 1.0 forward
if (angle < 0 || angle > 180) { Serial.println("From 0 to 180 only!"); }
else {
Serial.print("Angle = "); Serial.println(angle); showDir(angle);
servo.write(angle);
while (Serial.available() > 0) { junk = Serial.read() ; } // clear the keyboard buffer
void showDir(int a)
if (a < 90) { Serial.print(" (Left)"); }
else { Serial.print(" (Right)"); }
queenka:
hye PeterH..im already test the coding as above and it work very well..after that, can i using the same testing for xbees??
Don't see why not. You might need to configure / initialise the Xbees, and you'd need to connect the Arduino's serial I/O to the XBee on each side instead of connecting wires between them, but fundamentally the XBee pair gives you a serial channel which is functionally equivalent to the wired connected between Rx/Tx pins.
