Hi
I have recently bought an arduino board as a possible solution for a project I am working on. I am trying to build a light organ - made of clear acrylic pipes each fitted with a set of LED's at the base. I want to be able to control the lights through MIDI - as I will be using a MIDI synth. This will be plugged into a sampler for the audio element and also send a MIDI signal to my computer (OS X) to trigger visual clips. What I am trying to figure out is how I can pass on this MIDI data my computer will be receiving onto the arduino board and simply control a set of LED's plugged into the digital I/O pins. The overall desired effect is to be able to trigger from one MIDI note a sound+video clip+LED.
From what I understand I would need to use another software like Processing to translate the MIDI data into serial data. Has anyone had much experience with this? Any help would be greatly appreciated.
