I am trying to Control the Mp3 Player Using Arduino.
I wanted to On the Mp3 player using Button input from Arduino.. So i placed a pc 817 opto coupler in between the negative terminal of the Batttery.
But it i am unable to power on the device using that.
I used the same optocouplers for Mp3 Buttons which are Working Somehow..
anyone tell me why i am facing problem ?
Can i use optocoupler in between Battery Terminal?
anilkunchalaece:
Q1) What is the Volts and Amps rating of the opto-coupler?
Q2) What is Volts and Amps power requirement of the MP3 player?
Because you do not understand what you are doing.
Probably not.
The output transistor of an opto coupler is only good for a few mA. Fine for a push button signal but not for power.
You have to have another transistor or FET to do the switching and signal that through an optocoupler.
