Control box for roasting oven
Looking for someone to help me construct a control box for an electrical roasting oven for nuts. The box will control a an electrical motor for a rotating arm. The box will also control the heating elements for the oven.
The arm will rotate in intervals during the roasting cycle
The elements will be running on a constant temperature throughout the roasting cycle. The elemnts will have to keep a reasonably constant temperature, within 5% of target. It's not important that the temperature reading is completely accurate, it's important that it is consistent.
Thanks for reading this. Looking forward to hearing from you.
You can reach me here or christoofer@gmail.com
Regards, Christofer
This seems like a fairy simple automations task. The controller would be easy to program. Are you looking for a complete solution for controlling the motor and heater? If so I will need some information on the loads represented on by each.
If you are still looking for someone, I have been working in automations for several years.
