I have this Constant Current Led Driver and I want to dim the led which it powers using an Arduino.
How can I do this? is it even possible?
The ratings written on the case is
8-12W
Input - AC90-265V 50/60Hz
Output - DC24-45V 300mA ±5%
TC:75°C TA:50°C(MAX)
I'm attaching the photo of the drivers internals. The Mosfet I see is a CS2N60 A4H
No.
The design is properly not suitable for dimming control. You need to know a hell of a lot more about the circuit that a photograph of it.
So if I replace the Power supply with a basic AC to DC converter then can I use PWM?
First things first. What led are you driving? Will it be the ONLY one being driven, or will you add/subtract leds on a whim?
It's actually a (48v?)led strip without any resistors. I won't be adding anymore leds.
Noobian:
8-12W
I had the same question not too long ago. And the best answer I got was this.
It can be done. But it's beyond the abilities of someone who has to ask if it can. You're better off buying a dimmable LED driver. It will save you from burning down your house. Or worse, someone getting hurt or even killed.
That's how It was put to me. So, I gave up on the idea and bought what I needed.
DangerToMyself:
I don't want the Triac dimmable driver.
I've been doing some experimentation and I think I've got it figured out by now. I'm gonna use a boost converter to power the strip and use PWM to dim the leds. The driver is going to replaced by a wall wart.
So a boost converter that handles 48V output at a constant current of what? You still have not defined your problem, so you are wasting your time looking for a solution until you have.
It is unlikely you will find anything through that route.
XL6009 boost converter tops out at 37.1 volts. Gives 0.26 amps out.
