Control ESP32 GPIO Pins using Web Bluetooth
I am a beginner in ESP32 and I am learning how to connect LDR and Led on ESP32 connected to Web via Bluetooth. I found the tutorial from the following site:
But why does the sketch in the tutorial display an error when uploaded ? :
Here is the sketch in question:
#include <BLEDevice.h>
#include <BLEServer.h>
#include <BLEUtils.h>
#include <BLE2902.h>
// BLE UUIDs
#define SERVICE_UUID        "12345678-1234-1234-1234-123456789abc"
#define LED_CHAR_UUID       "abcdef01-2345-6789-0123-456789abcdef"
#define LDR_CHAR_UUID       "abcdef02-2345-6789-0123-456789abcdef"
// GPIO Pins
#define LED_PIN 2
#define LDR_PIN 34
BLECharacteristic *pLedCharacteristic;
BLECharacteristic *pLdrCharacteristic;
bool deviceConnected = false;
class MyServerCallbacks: public BLEServerCallbacks {
  void onConnect(BLEServer* pServer) {
    deviceConnected = true;
    Serial.println("Device connected");
  void onDisconnect(BLEServer* pServer) {
    Serial.println("Device disconnected");
    pServer->getAdvertising()->start(); // Restart advertising
class LedCallbacks: public BLECharacteristicCallbacks {
  void onWrite(BLECharacteristic *pCharacteristic) {
    std::string value = pCharacteristic->getValue();
    if (value.length() > 0) {
      Serial.print("LED command: ");
      Serial.println(value.c_str());
      if (value == "1") digitalWrite(LED_PIN, HIGH);
      else if (value == "0") digitalWrite(LED_PIN, LOW);
  // Initialize GPIO
  pinMode(LED_PIN, OUTPUT);
  digitalWrite(LED_PIN, LOW); // LED off by default
  // Initialize BLE
  BLEDevice::init("ESP32_GPIO_Control");
  BLEServer *pServer = BLEDevice::createServer();
  pServer->setCallbacks(new MyServerCallbacks());
  // Create BLE Service
  BLEService *pService = pServer->createService(SERVICE_UUID);
  // LED Characteristic (writeable)
  pLedCharacteristic = pService->createCharacteristic(
    LED_CHAR_UUID,
    BLECharacteristic::PROPERTY_WRITE
  pLedCharacteristic->setCallbacks(new LedCallbacks());
  // LDR Characteristic (readable, notifying)
  pLdrCharacteristic = pService->createCharacteristic(
    LDR_CHAR_UUID,
    BLECharacteristic::PROPERTY_READ | BLECharacteristic::PROPERTY_NOTIFY
  pLdrCharacteristic->addDescriptor(new BLE2902());
  // Start service and advertising
  pService->start();
  Serial.println("BLE server started. Waiting for connection...");
  if (deviceConnected) {
    // Read LDR value (0-4095) and map to percentage (0-100)
    int ldrValue = analogRead(LDR_PIN);
    int ldrPercent = map(ldrValue, 0, 4095, 0, 100);
    String ldrString = String(ldrPercent);
    // Update LDR characteristic and notify
    pLdrCharacteristic->setValue(ldrString.c_str());
    pLdrCharacteristic->notify();
    delay(500); // Update every 0.5 seconds
And here is the error that appears when uploading:
Web_BLE_2.ino:33:50: error: conversion from 'String' to non-scalar type 'std::string' {aka 'std::__cxx11::basic_string<char>'} requested
   33 |     std::string value = pCharacteristic->getValue();
exit status 1
Compilation error: conversion from 'String' to non-scalar type 'std::string' {aka 'std::__cxx11::basic_string<char>'} requested
In the arduino-esp32 BLE library, BLECharacteristic::getValue is defined to return a String as follows:
std::string and String are different class definitions, so an error occurs.
I don't know the author's software environment, but I think it will be OK if you do it like this:
    String value = pCharacteristic->getValue(); // std::string --> String
Edit: It seems that the returned class was changed from std::string to String when the library version was upgraded from 2.x to 3.x.
Okay thank you very much. He has worked
It was very kind of you to help me
You're welcome :blush:
