I need change my code serial to button control
if i press a 1st button, 1st motor have to rotate 45degree.
its same to other motors.
i have a serial control code but i don’t know what have to change for my purpose.
this is my serial control code
uint8_t step[4][4] = {{1, 0, 1, 0}, {0, 1, 1, 0}, {0, 1, 0, 1}, {1, 0, 0, 1}};
uint8_t motor_step[5] = {0, 0, 0, 0, 0};
int16_t motor_count[5] = {0, 0, 0, 0, 0};
uint8_t parsing_step = 0;
uint8_t parsing_motor = 0;
int8_t parsing_pm = 0;
uint16_t parsing_num1 = 0;
uint16_t parsing_num2 = 0;
Serial.begin(38400);
for (uint8_t i = 0; i < 5; i++)
pinMode(30 + 4 * i, OUTPUT);
pinMode(31 + 4 * i, OUTPUT);
pinMode(32 + 4 * i, OUTPUT);
pinMode(33 + 4 * i, OUTPUT);
Serial.println(“input command\nex)white,360*10\n”);
if (Serial.available() != 0)
char temp = Serial.read();
switch (parsing_step)
case 0:
if (‘a’ <= temp && temp <= ‘z’)
switch (temp)
case ‘w’:
parsing_motor = 0;
case ‘y’:
parsing_motor = 1;
case ‘r’:
parsing_motor = 2;
case ‘b’:
parsing_motor = 3;
case ‘d’:
parsing_motor = 4;
++parsing_step;
case 1:
if (temp == ‘,’)
++parsing_step;
parsing_pm = 1;
parsing_num1 = 0;
parsing_num2 = 0;
else if (temp == ‘\n’)
parsing_step = 0;
case 2:
if (temp == ‘-’)
parsing_pm = -1;
else if (‘0’ <= temp && temp <= ‘9’)
parsing_num1 = parsing_num1 * 10 + temp - ‘0’;
else if (temp == ‘*’)
++parsing_step;
motor_count[parsing_motor] += parsing_pm * (parsing_num1 / 1.8 + 0.5);
parsing_step = 0;
Serial.print("motor: “);
Serial.print(parsing_motor);
Serial.print(”, angle: ");
Serial.println(motor_count[parsing_motor]*1.8);
case 3:
parsing_num2 = parsing_num2 * 10 + temp - ‘0’;
motor_count[parsing_motor] += parsing_pm * (parsing_num1 * parsing_num2 / 1.8 + 0.5);
parsing_step = 0;
if (motor_count < 0)
++motor_count*;
digitalWrite(30 + 4 * i, step[motor_step][0]);
digitalWrite(31 + 4 * i, step[motor_step][1]);
digitalWrite(32 + 4 * i, step[motor_step][2]);
digitalWrite(33 + 4 * i, step[motor_step][3]);
--motor_step;
if (motor_step == 255)
_ {
motor_step = 3;
else if (motor_count > 0)
{_
--motor_count;
++motor_step;
if (motor_step == 4)
_ {
motor_step = 0;
delayMicroseconds(1000);
}*_
