I have built an Arduino controlled RC car using L293D ICs and I am now looking to get it online using the Ethernet Shield (connected to a wireless router which will be mounted on the car itself). The problem I am having is finding a good way to control it from a computer on the internet or on the same LAN. I know there is the web server option, as well as TinyWebServer and webduino, but I can't seem to get any of it working. Therefore I was wondering if any of you would know of a good way that is right for this type of project.
Client/server communication using web forms is a means of communication used every single day. I'm using a form right now, with a text box to collect the data, and a submit button to execute an action method.
You used one to post this message. There are somewhere between dozens and millions of resources that discuss client/server communication.
I suspect that you are looking for WebControlOfServer.ino, where someone else has already done all the work.
If you can't get the basic web server example working, then the problem is NOT with the Arduino or the Ethernet shield. It is with your router/network/access.
That is a completely separate issue that needs to be dealt with separately, before you will make any progress controlling anything over the internet.
I should probably clarify; I can get the basic webserver working, but I was looking for an easier way to customize it, and add a bit more of a gui. I just had another thought about using HTML5 and the Canvas element. I could use a basic HTML5 markup containing only the canvas and an external Javascript file. But i’m not exactly sure on how I would go about doing this if it is even possible. I would like to use mouseDown and mouseUp values on the buttons to turn the motors on and off instead of having to submit and re-load a form in order to change the values. For my project it doesn’t seem very practical to do it that way.
Fancy web stuff will take a lot of memory if contained on the arduino. You could keep a big web page on your desktop and just have the arduino do the control actions. Below is some test code that includes an iframe and status: 204 to keep the basic page from refreshing. You can open the serial monitor to see some of what is happening when using the control links.
//zoomkat 7-03-12, combined client and server
//simple button GET with iframe code
//for use with IDE 1.0
//open serial monitor and send an g to test client and
//see what the arduino client/server receives
//web page buttons make pin 5 high/low
//use the ' in html instead of " to prevent having to escape the "
//address will look like http://192.168.1.102:84 when submited
//for use with W5100 based ethernet shields
//note that the below bug fix may be required
// http://code.google.com/p/arduino/issues/detail?id=605
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //assign arduino mac address
byte ip[] = {192, 168, 1, 102 }; // ip in lan assigned to arduino
byte gateway[] = {192, 168, 1, 1 }; // internet access via router
byte subnet[] = {255, 255, 255, 0 }; //subnet mask
EthernetServer server(84); //server port arduino server will use
EthernetClient client;
char serverName[] = "web.comporium.net"; // (DNS) zoomkat's test web page server
//byte serverName[] = { 208, 104, 2, 86 }; // (IP) zoomkat web page server IP address
String readString; //used by server to capture GET request
void setup(){
pinMode(5, OUTPUT); //pin selected to control
pinMode(6, OUTPUT); //pin selected to control
pinMode(7, OUTPUT); //pin selected to control
pinMode(8, OUTPUT); //pin selected to control
//pinMode(5, OUTPUT); //pin 5 selected to control
Ethernet.begin(mac,ip,gateway,gateway,subnet);
server.begin();
Serial.println("server/client 1.0 test 7/03/12"); // keep track of what is loaded
Serial.println("Send an g in serial monitor to test client"); // what to do to test client
void loop(){
// check for serial input
if (Serial.available() > 0)
byte inChar;
inChar = Serial.read();
if(inChar == 'g')
sendGET(); // call client sendGET function
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
//read char by char HTTP request
if (readString.length() < 100) {
//store characters to string
readString += c;
//Serial.print(c);
//if HTTP request has ended
if (c == '\n') {
Serial.print(readString); //print to serial monitor for debuging
//now output HTML data header
if(readString.indexOf('?') >=0) { //don't send new page
client.println(F("HTTP/1.1 204 Zoomkat"));
client.println();
client.println();
else {
client.println(F("HTTP/1.1 200 OK")); //send new page on browser request
client.println(F("Content-Type: text/html"));
client.println();
client.println(F("<HTML>"));
client.println(F("<HEAD>"));
client.println(F("<TITLE>Arduino GET test page</TITLE>"));
client.println(F("</HEAD>"));
client.println(F("<BODY>"));
client.println(F("<H1>Zoomkat's simple Arduino 1.0 button</H1>"));
// DIY buttons
client.println(F("Pin5"));
client.println(F("<a href=/?on2 target=inlineframe>ON</a>"));
client.println(F("<a href=/?off3 target=inlineframe>OFF</a>
client.println(F("Pin6"));
client.println(F("<a href=/?on4 target=inlineframe>ON</a>"));
client.println(F("<a href=/?off5 target=inlineframe>OFF</a>
client.println(F("Pin7"));
client.println(F("<a href=/?on6 target=inlineframe>ON</a>"));
client.println(F("<a href=/?off7 target=inlineframe>OFF</a>
client.println(F("Pin8"));
client.println(F("<a href=/?on8 target=inlineframe>ON</a>"));
client.println(F("<a href=/?off9 target=inlineframe>OFF</a>
client.println(F("Pins"));
client.println(F(" <a href=/?off2468 target=inlineframe>ALL ON</a>"));
client.println(F(" <a href=/?off3579 target=inlineframe>ALL OFF</a>"));
client.println(F("<IFRAME name=inlineframe style='display:none'>"));
client.println(F("</IFRAME>"));
client.println(F("</BODY>"));
client.println(F("</HTML>"));
delay(1);
//stopping client
client.stop();
///////////////////// control arduino pin
if(readString.indexOf('2') >0)//checks for 2
digitalWrite(5, HIGH); // set pin 5 high
Serial.println("Led 5 On");
if(readString.indexOf('3') >0)//checks for 3
digitalWrite(5, LOW); // set pin 5 low
Serial.println("Led 5 Off");
if(readString.indexOf('4') >0)//checks for 4
digitalWrite(6, HIGH); // set pin 6 high
Serial.println("Led 6 On");
if(readString.indexOf('5') >0)//checks for 5
digitalWrite(6, LOW); // set pin 6 low
Serial.println("Led 6 Off");
if(readString.indexOf('6') >0)//checks for 6
digitalWrite(7, HIGH); // set pin 7 high
Serial.println("Led 7 On");
if(readString.indexOf('7') >0)//checks for 7
digitalWrite(7, LOW); // set pin 7 low
Serial.println("Led 7 Off");
if(readString.indexOf('8') >0)//checks for 8
digitalWrite(8, HIGH); // set pin 8 high
Serial.println("Led 8 On");
if(readString.indexOf('9') >0)//checks for 9
digitalWrite(8, LOW); // set pin 8 low
Serial.println("Led 8 Off");
//clearing string for next read
readString="";
void sendGET() //client function to send and receive GET data from external server.
if (client.connect(serverName, 80)) {
Serial.println("connected");
client.println("GET /~shb/arduino.txt HTTP/1.0");
client.println();
else {
Serial.println("connection failed");
while(client.connected() && !client.available()) delay(1); //waits for data
while (client.connected() || client.available()) { //connected or data available
Serial.print(c);
Serial.println("disconnecting.");
Serial.println("==================");
client.stop();
zoomkat:
That is in a way the goal I want to do. What I was thinking now is that I host a javascript file on the SD card and serve that to the browser on the computer and run the HTML code from the Arduino like normal. This way the network doesn't need to be on the internet in order to get the javascript file. By using the HTML 5 canvas element it opens up a lot of capabilities for game controllers and some decent looking UI controls. So what would be the best way to serve the JavaScript file to the computer over the network?
