Hi, I have a hot water production facility (a coil boiler and a gas water heater...autogaizer) do you want to automate the distribution with a 3-way valve (Tuya valve actuator) I tried with the Alexa app but no I manage to do a routine using a temperature sensor on the boiler, who can give me some advice. Thank you
I got them things two but I do not have a clue as to how you want to connect them or what they are to do. Draw a simple piping diagram showing the distribution and the control system interface.
Topic moved. Please do not post in "Uncategorized"; see the sticky topics in Uncategorized - Arduino Forum.
You tried something and it did not work; I suggest that you post your code (please do not forget to use code tags as described in How to get the best out of this forum). It might others to help you.
Hello, I want the gas water heater to work when there is no hot water in the boiler , i try with Amazon Alexa, but I can't. Thank you
The plumbing looks correct now you need to let us know what sensors you are looking at and what Arduino you think will do the job.
I don't see why you need to use the heaters in parallel. You may find that all you need is a/the thermostat on the main heater controlling the gas service, and Arduino might be redundant.
I hope you are not mixing your domestic potable hot water with the nasty non-potable boiler water.
Christ, I hope not. I simply assumed he was short of domestic hot water and wanted a quick boost from gas.
