Control led brightness via web server using arduino uno + ethernet shield
I’m working on a little project where I want to control a LED brithness via my browser using arduino uno + ethernet shield . well, might as well i try to do it , but something went wrong (it’s work just in the first click then the browser page crashes in the next ).
can some one help me plz !!!
i will attach the file that i do
LEDbrightness.ino (2.85 KB)
7 below shows how to post code if you want people to look at it. That being said, it is fairly easy to add buttons or text boxes to web pages to send control data back to the arduino.
http://forum.arduino.cc/index.php/topic,148850.0.html
this is the code
 #include <SPI.h>
 #include <Ethernet.h>
 #include <Servo.h>
 Servo myservo;  // create servo object to control a servo
 byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
 byte ip[] = { 192 , 168, 1, 177 }; // fixed IP addr  in LAN
 byte gateway[] = { 192 , 168 , 1 , 1 }; // internet access via router
 byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
 EthernetServer server(80); //server port
 String readString;
 void setup(){
 pinMode(9, OUTPUT); //pin selected to control LED  4
 //start Ethernet
 Ethernet.begin(mac, ip, gateway, subnet);
 server.begin();       //the pin for the servo co
 //enable serial data print
 void loop(){
   byte brightness;
   delay(1000);                           //wait one second before sending new data
 // Create a client connection
 if (client) {
	while (client.connected()) {
		if (client.available()) {
			char c = client.read();                  //read char by char HTTP request
			if (readString.length() < 100) {   //store characters to string
				readString += c;        //Serial.print(c);             }
				//if HTTP request has ended
				if (c == '\n') {
				Serial.println(readString); //print to serial monitor for debuging
				client.println("HTTP/1.1 200 OK");//send new page
				client.println("Content-Type: text/html");
				client.println();
				client.println("<HTML>");
				client.println("<HEAD>");
				client.println("<TITLE>Arduuino Project</TITLE>");
		                client.println("<meta http-equiv=\"refresh\" content=\"1\">");
				client.println("</HEAD>");
				client.println("<BODY bgcolor='black'><center>");
				client.println("<H1 style=\"background-color:white;\">Arduino project</H1>");
                                client.println("<a href=\"/?light-\"> - </a> <a href=\"/?light+\"> + </a>");
                                client.println(" </center></BODY></HTML>");
				delay(1);
				//stopping client
				client.stop();
                                        if(readString.indexOf("?light-") >0)//checks for -
					{   brightness = brightness-15;
                                            analogWrite(9, brightness);
						Serial.println("brightness -");
						if(readString.indexOf("?light+") >0)//checks for +
					{   brightness = brightness+15;
						Serial.println("brightness +");
				readString="";   //clearing string for next read
Below is the web page that you have generated. All it does is refresh the page and does not send your intended control commands. Bottom is what the serial monitor is printing out. You probably need to drop the meta refresh and make buttons to send your commands.
edit: after cleaning up your html so I could see the buttons, it appears your basic incremental dim/brighten code is flawed. You need to fix that issue using the serial monitor, then move to put it in a web page. bottom is the serial monitor output.
<HTML>
<HEAD>
<meta http-equiv="refresh" content="1">
</HEAD>
<H1 style="background-color:white;">Arduino project</H1>
<a href="/?light-"> - </a> <a href="/?light+"> + </a>
GET / HTTP/1.1
GET / HTTP/1.1
GET / HTTP/1.1
GET / HTTP/1.1
GET / HTTP/1.1
GET / HTTP/1.1
GET / HTTP/1.1
GET / HTTP/1.1
GET /?light- HTTP/1.1
brightness -
GET /?light+ HTTP/1.1
brightness -
brightness -
brightness -
