Control LED Strip functions using SINGLE Push Button Help!
Hello, I am attempting to modify my code, which currently has two functions that I use:
RunningLightsAll() and FadeInOutAll(). I am trying to have the button alternate between the two. I don't want to hold the button down for some time but rather have a simple push of the button change the current function that is running. I currently have the button being "read" during the While loops of the function to change between the two. However, this only works if timed correctly(@ location in code). I need help to change between the two. Any guidance or tools in the right direction are greatly appreciated.
<br>[size=0.8em]Code: [url=https://arduinogetstarted.com/tools/arduino-code-highlighter]see how to post code[/url] [/size]<br>
[size=0.8em]#include "FastLED.h"
#define[nobbc] NUM_LEDS 15[/nobbc]
CRGB leds[NUM_LEDS];
#define[nobbc] PIN 6             [/nobbc][nobbc]// the pin that the LED is attached t[/nobbc]
const int[nobbc] buttonPin = 2;  [/nobbc][nobbc]// the pin that the pushbutton is attached to[/nobbc]
[nobbc]// Variables that will chane[/nobbc]
int[nobbc] buttonPushCounter = 1;    [/nobbc][nobbc]// Counter for button Presses[/nobbc]
int[nobbc] buttonState = 1;          [/nobbc][nobbc]// Current state of button[/nobbc]
int[nobbc] lastButtonState = 0;      [/nobbc][nobbc]// Previous state of button[/nobbc]
void setupnobbc[/nobbc]
 FastLED.addLeds<WS2811, PIN, GRB>(leds, NUM_LEDS).setCorrection( TypicalLEDStrip );
pinMode[nobbc](buttonPin, [/nobbc]INPUT[nobbc]);[/nobbc]
 pinMode[nobbc](PIN, [/nobbc]OUTPUT[nobbc]);[/nobbc]
[nobbc]  [/nobbc]Serial[nobbc].[/nobbc]beginnobbc;[/nobbc]
[nobbc]// *** REPLACE FROM HERE ***[/nobbc]
void loopnobbc {[/nobbc]
FadeInOutAll(5);
 RunningLightsAll(100);
[nobbc]// ---> here we define the effect function <---[/nobbc]
void[nobbc] FadeInOutAll([/nobbc]int[nobbc] SpeedDelay) {[/nobbc]
 float[nobbc] r, g, b;[/nobbc]
[nobbc]/*********** PART 1 ************/[/nobbc]
[nobbc]// Square Turns OFF[/nobbc]
delaynobbc;[/nobbc]
while[nobbc] (1) {[/nobbc]
[nobbc]// Triangle Turns ON[/nobbc]
   for[nobbc] ([/nobbc]int[nobbc] k = 0; k < 256; k = k + 1) {[/nobbc]
     r = (k / 256.0) * 0x00;
     g = (k / 256.0) * 0xff;
     b = (k / 256.0) * 0x00;
     setPixel(0, r, g, b);
     setPixel(1, r, g, b);
     setPixel(2, r, g, b);
     showStrip();
     delaynobbc;[/nobbc]
   for[nobbc] ([/nobbc]int[nobbc] k = 255; k >= 0; k = k - 2) {[/nobbc]
     r = (k / 256.0) * 0xff;
     g = (k / 256.0) * 0x00;
     b = (k / 256.0) * 0xff;
     setPixel(11, r, g, b);
     setPixel(12, r, g, b);
     setPixel(13, r, g, b);
     setPixel(14, r, g, b);
     showStrip();
     delaynobbc;[/nobbc]
[nobbc]//Circle Turns ON[/nobbc]
     setPixel(3, r, g, b);
     setPixel(4, r, g, b);
     setPixel(5, r, g, b);
     setPixel(6, r, g, b);
     showStrip();
     delaynobbc;[/nobbc]
[nobbc]/****  PART 2 ****************/[/nobbc]
   [nobbc]// Triangle Turns OFF[/nobbc]
     showStrip();
     delaynobbc;[/nobbc]
[nobbc]// X Turns ON[/nobbc]
     setPixel(7, r, g, b);
     setPixel(8, r, g, b);
     setPixel(9, r, g, b);
     setPixel(10, r, g, b);
     showStrip();
     delaynobbc;[/nobbc]
   [nobbc]/*********   PART 3 *********/[/nobbc]
[nobbc]// Circle Turns OFF[/nobbc]
     showStrip();
     delaynobbc;[/nobbc]
[nobbc]// Square Turns ON[/nobbc]
     showStrip();
     delaynobbc;[/nobbc]
[nobbc]/*********   PART 4 *********/[/nobbc]
[nobbc]// X Turns OFF[/nobbc]
     showStrip();
     delaynobbc;[/nobbc]
if[nobbc] ([/nobbc]digitalReadnobbc == [/nobbc]HIGH[nobbc] ) {[/nobbc]
return;
[nobbc]/************************************************************/[/nobbc]
void[nobbc] RunningLightsAll([/nobbc]int[nobbc] WaveDelay) {[/nobbc]
   [nobbc]/* Triangle Green */[/nobbc]
   setPixel(0, 0x00, 0xff, 0x00);
   setPixel(1, 0x00, 0xff, 0x00);
   setPixel(2, 0x00, 0xff, 0x00);
[nobbc]/* Circle Red */[/nobbc]
   setPixel(3, 0xff, 0x00, 0x00);
   setPixel(4, 0xff, 0x00, 0x00);
   setPixel(5, 0xff, 0x00, 0x00);
   setPixel(6, 0xff, 0x00, 0x00);
   [nobbc]/* X Blue */[/nobbc]
   setPixel(7, 0x00, 0x00, 0xff);
   setPixel(8, 0x00, 0x00, 0xff);
   setPixel(9, 0x00, 0x00, 0xff);
   setPixel(10, 0x00, 0x00, 0xff);
[nobbc]/* Square Pink */[/nobbc]
   setPixel(11, 0xff, 0x00, 0xff);
   setPixel(12, 0xff, 0x00, 0xff);
   setPixel(13, 0xff, 0x00, 0xff);
   setPixel(14, 0xff, 0x00, 0xff);
   showStrip();
   delaynobbc;[/nobbc]
return;
[nobbc]/***********************************************************************/[/nobbc]
[/td][/tr][/table]
playstation_code_phase.ino (7.86 KB)
Read Adafruit’s multitasking discussions 1, 2 and 3.
BTW
Use code tags.
Use CTRL T to format your code.
Attach your ‘complete’ sketch between code tags, use the </> icon in the posting menu.
[code]Paste your sketch here[/code]
Thank you larryd , it seems i have quite a bit of reading to do. Will get back if any issues occur.
Also, thank you for the info on posting code. I thought i did CTRL T but I will recheck the next time I post ANY code.
Also, by 'complete' sketch, do you mean the code that I am having problems with/have questions about? And not the actual complete sketch?
We ask that when large sketches have a problem, you reduced it in size to the point where the problem still is seen.
Hello again everyone. Question, I am attempting to set up a button with 3 functions. OFF/ALL/PHASE. off and all are pretty self explanatory. For phase, I want the phase code to run forever until the button is pressed again. My issue arises with the fact that I don't know how to keep the "phase" code running without inserting a while(1) loop, which results in it being stuck forever in that state unless i restart the program. Should I use a timer interrupt for this or is there a better way to write my code for the PHASE.
void Phase(uint8_t interval) {
      ActivePattern = PHASE;
      Interval = interval;
      float r, g, b;
      // Square Turns OFF
While(1){
      for (int k = 0; k < 256; k = k + 1) {
        setPixelColor(0, r, g, b);
        setPixelColor(1, r, g, b);
        setPixelColor(2, r, g, b);
        show();
      // Square Turns OFF
      for (int k = 255; k >= 0; k = k - 2) {
        setPixelColor(11, r, g, b);
        setPixelColor(12, r, g, b);
        setPixelColor(13, r, g, b);
        setPixelColor(14, r, g, b);
        show();
      //Circle Turns ON
        setPixelColor(3, r, g, b);
        setPixelColor(4, r, g, b);
        setPixelColor(5, r, g, b);
        setPixelColor(6, r, g, b);
        show();
        show();
      // X Turns ON
        setPixelColor(7, r, g, b);
        setPixelColor(8, r, g, b);
        setPixelColor(9, r, g, b);
        setPixelColor(10, r, g, b);
        show();
      // Circle Turns OFF
        show();
      // Square Turns ON
        show();
      // X Turns OFF
        show();
NeoPatterns Stick(15, 7, NEO_GRB , &StickComplete);
// Initialize everything and prepare to start
  pinMode(8, INPUT_PULLUP);
  // Initialize all the pixelStrips
  Stick.begin();
  // Kick off a pattern
  //Stick.Fade(Stick.Color(255,0,0),Stick.Color(0,0,255), 150,50);
  Stick.ColorAll();
long counter = 0;
// Main loop
  // Update the rings.
  Stick.Update();
  // Switch patterns on a button press:
  if (digitalRead(8) == LOW && counter % 3 == 0) // Back to normal operation
  { counter++;
    Stick.ActivePattern = ALL;
    Stick.ColorAll();
    Stick.Update();
    Serial.println('counter');
    Serial.println("ALL");
  if (digitalRead(8) == LOW && counter % 3 == 1) // Button #1 pressed
  { counter++;
    Stick.ActivePattern = PHASE;
    // Set stick to all red
    Stick.Phase(100);
    Stick.Update();
    Serial.println("FADE");
  if (digitalRead(8) == LOW && counter % 3 == 2) {
    counter++;
    Stick.ActivePattern = NONE;
    Stick.ColorSet(Stick.Color(0, 0, 0));
    Stick.Update();
    Serial.println("OFF");
I hope I posted my code right :frowning:
No all the sketch is needed. It is surprising how often the mistake is not in the place where the problems manifest themselves.
Simple you don’t have a while statement at all. Did you read those links?
You need to implement your code as a state machine, that is each animation function must do a small bit of the function and then return. So no while statements and no for loops, with show or delay in them and no delays at all.
If I give you some links will you read them?
Read
The blink without delay example in the Arduino IDE.
Read this link Short Range Wireless Communication - #7 by pito - Other Hardware Development - Arduino Forum
And read my link :- http://www.thebox.myzen.co.uk/Tutorial/State_Machine.html
