Control LED whit htm page and Ethernet Shield.
Hi, i want to control a led whit arduino ethernet shield W5100 and htm pages loaded from the sd card, i can control it whit diferent pages, for example i have the index, then one link to other page, and put the led code to turn on when i request that page, but this isnt good, because i will need to do one page for each led i will control, could you tell me if there is a way to do this without having to load a new page? thanks.
Servo control test code that down loads the files to generate a servo slider control on a web page. You could do similar by putting your current html control page file on the SD card, then downloading it.
//zoomkat 1/26/13
//SD server slider test code
//open serial monitor to see what the arduino receives
//address will look like http://192.168.1.102:84/servosld.htm when submited
//for use with W5100 based ethernet shields
//put the servosld.htm, slider.js, bluev_sl.gif,
//and bluev_bg.gif on the SD card
//files at http://web.comporium.net/~shb/servoslider.htm page
#include <SD.h>
#include <SPI.h>
#include <Ethernet.h>
#include <Servo.h>
Servo myservoa, myservob, myservoc, myservod;  // create servo object to control a servo
Servo myservoe, myservof, myservog;
String readString, pos;
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = {
  192, 168, 1, 102 }; // ip in lan
byte gateway[] = {
  192, 168, 1, 1 }; // internet access via router
byte subnet[] = {
  255, 255, 255, 0 }; //subnet mask
EthernetServer server(84); //server port
void setup(){
  // disable w5100 while setting up SD
  pinMode(10,OUTPUT);
  digitalWrite(10,HIGH);
  Serial.print("Starting SD..");
  if(!SD.begin(4)) Serial.println("failed");
  else Serial.println("ok");
  Ethernet.begin(mac, ip, gateway, gateway, subnet);
  //delay(2000);
  server.begin();
  Serial.println("Ready");
  myservoa.attach(2);  //the pin for the servoa control
  myservob.attach(3);  //the pin for the servob control
  myservoc.attach(5);  //the pin for the servoc control
  myservod.attach(6);  //the pin for the servod control
  myservoe.attach(7);  //the pin for the servoa control
  myservof.attach(8);  //the pin for the servob control
  myservog.attach(9);  //the pin for the servoc control
  //myservoh.attach(10);  //the pin for the servod control
void loop(){
  // Create a client connection
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        //read char by char HTTP request
        if (readString.length() < 100) {
          //store characters to string
          readString += c;
          //Serial.print(c);
        //if HTTP request has ended
        if (c == '\n') {
          Serial.println(readString); //print to serial monitor for debuging
         //select proper header for file to be sent to browser
          client.println("HTTP/1.1 200 OK"); //send new page
          if(readString.indexOf("servosld") >=0) {
          client.println("Content-Type: text/html");
          client.println(); }
          if(readString.indexOf("slider") >=0) {
          client.println("Content-Type: application/x-javascript");
          client.println(); }
          if(readString.indexOf("bluev") >=0) {
          client.println("Content-Type: image/gif");
          client.println(); }
          //select file to send to browser
            File myFile = SD.open("SERVOSLD.HTM");
            if (myFile) {
              while (myFile.available()) {
                client.write(myFile.read());
              myFile.close();
            File myFile = SD.open("slider.js");
            if (myFile) {
              myFile.close();
          if(readString.indexOf("bluev_sl") >=0) {
            File myFile = SD.open("bluev_sl.gif");
            if (myFile) {
              myFile.close();
          if(readString.indexOf("bluev_bg") >=0) {
            File myFile = SD.open("bluev_bg.gif");
            if (myFile) {
              myFile.close();
          delay(1);
          //stopping client
          client.stop();
          //process GET string request from client and and position servo
          pos = readString.substring(8, 12); //get the first four characters
          //Serial.println(pos);
          int n = pos.toInt();  //convert readString into a number
          Serial.println(n);
          if(readString.indexOf("?0") >0) myservoa.writeMicroseconds(n);
          if(readString.indexOf("?1") >0) myservob.writeMicroseconds(n);
          if(readString.indexOf("?2") >0) myservoc.writeMicroseconds(n);
          if(readString.indexOf("?3") >0) myservod.writeMicroseconds(n);
          if(readString.indexOf("?4") >0) myservoe.writeMicroseconds(n);
          if(readString.indexOf("?5") >0) myservof.writeMicroseconds(n);
          if(readString.indexOf("?6") >0) myservog.writeMicroseconds(n);
          //only seven servo pins, so back to myservoa for testing
          if(readString.indexOf("?7") >0) myservoa.writeMicroseconds(n);
          //clearing string for next read
          readString="";
          pos="";
zoomkat:
//zoomkat 1/26/13
#include <SD.h>
#include <SPI.h>
#include <Servo.h>
byte mac = {
byte ip = {
byte gateway = {
byte subnet = {
void setup(){
  pinMode(10,OUTPUT);
  Serial.print(“Starting SD…”);
  if(!SD.begin(4)) Serial.println(“failed”);
  else Serial.println(“ok”);
//delay(2000);
  server.begin();
  Serial.println(“Ready”);
void loop(){
  if (client) {
          readString += c;
          //Serial.print(c);
        if (c == ‘\n’) {
          client.println(“HTTP/1.1 200 OK”); //send new page
          if(readString.indexOf(“servosld”) >=0) {
          client.println(“Content-Type: text/html”);
          client.println(); }
if(readString.indexOf(“slider”) >=0) {
          client.println(“Content-Type: application/x-javascript”);
          client.println(); }
          if(readString.indexOf(“bluev”) >=0) {
          client.println(“Content-Type: image/gif”);
          client.println(); }
            File myFile = SD.open(“SERVOSLD.HTM”);
            if (myFile) {
              myFile.close();
            File myFile = SD.open(“slider.js”);
            if (myFile) {
              myFile.close();
if(readString.indexOf(“bluev_sl”) >=0) {
            File myFile = SD.open(“bluev_sl.gif”);
            if (myFile) {
              myFile.close();
if(readString.indexOf(“bluev_bg”) >=0) {
            File myFile = SD.open(“bluev_bg.gif”);
            if (myFile) {
              myFile.close();
delay(1);
          //stopping client
          client.stop();
          Serial.println(n);
          readString="";
          pos="";
Thanks for the answer, but is not posible to do that whitout JavaScript?
Well, it depends on what the "that" you refer to is. You talking about javascript sliders, or just downloading files from the SD card?
Can you post the slider.js file? I’m interested in how to add a slider with javascript to my own server :slight_smile: Thanks.
zoomkat:
I refer to send the string, is posible to do whit html using a button?
