Hi there, my name is Juan Carlos Ortiz Posada, from Medellín - Colombia. I am making many projects (Lightsabers, Robots, etc)
I have Arduino UNO and Arduino NANO, I am making a Robot Head and need to control 7 servos:
One servo to move eyes Up and Down.
One servo to move eyes Left and Right.
One servo to move the eyelid UP and Down (one for each eye).
One servo to Open and Close the Mouth.
One servo to move the neck Left and Right (to say no).
One servo to move the neck Up and Down (to say yes).
Thank you very much.
I've been trying to make it but I am new on this kind of stuff, son I need your help.
For the servos you will need a power supply capable of producing 5-6 V at several amperes, preferably more than 5 amperes. Do not attempt to power servos from the Arduino or small batteries.
Test code for controlling several servos.
//zoomkat 11-22-12 simple delimited ',' string parse
//from serial port input (via serial monitor)
//and print result out serial port
//multi servos added
// Powering a servo from the arduino usually *DOES NOT WORK*.
String readString;
#include <Servo.h>
Servo myservoa, myservob, myservoc, myservod; // create servo object to control a servo
//myservoa.writeMicroseconds(1500); //set initial servo position if desired
myservoa.attach(6); //the pin for the servoa control
myservob.attach(7); //the pin for the servob control
myservoc.attach(8); //the pin for the servoc control
myservod.attach(9); //the pin for the servod control
Serial.println("multi-servo-delimit-test-dual-input-11-22-12"); // so I can keep track of what is loaded
//expect single strings like 700a, or 1500c, or 2000d,
//or like 30c, or 90a, or 180d,
//or combined like 30c,180b,70a,120d,
if (Serial.available()) {
char c = Serial.read(); //gets one byte from serial buffer
if (c == ',') {
if (readString.length() >1) {
Serial.println(readString); //prints string to serial port out
int n = readString.toInt(); //convert readString into a number
// auto select appropriate value, copied from someone elses code.
if(n >= 500)
Serial.print("writing Microseconds: ");
Serial.println(n);
if(readString.indexOf('a') >0) myservoa.writeMicroseconds(n);
if(readString.indexOf('b') >0) myservob.writeMicroseconds(n);
if(readString.indexOf('c') >0) myservoc.writeMicroseconds(n);
if(readString.indexOf('d') >0) myservod.writeMicroseconds(n);
Serial.print("writing Angle: ");
Serial.println(n);
if(readString.indexOf('a') >0) myservoa.write(n);
if(readString.indexOf('b') >0) myservob.write(n);
if(readString.indexOf('c') >0) myservoc.write(n);
if(readString.indexOf('d') >0) myservod.write(n);
readString=""; //clears variable for new input
else {
readString += c; //makes the string readString
Thank you very much, I will try all you say.
Obviously things move nice and slowly in Colombia....
zoomkat:
Jota-Bots:
