I'm completely new to the world of Arduino and just got my first Arduino and 8 relay.
For the past couple of days I've been setting everything up but just now ran into my first problem with writing actual code to run a motor.
I have gotten so far that my code runs the motor CW for the time I want, then stops, then runs the motor CCW and stops.
Basically I have a couple of button / limswitches (normaly open and normaly closed) laying around which I want to use to stop the motor whenever the switch is pressed.
So in my opinion the code should do this:
check if bottomLimitSwitch is pressed
if false: give power to Relay1 so the motor runs CCW until it presses the bottomLimitSwitch, then it should stop.
if true: give power to Relay1 so the motor runs CW until it presses the topLimitSwitch, then it should pause for 5 seconds, then run CCW until it hits bottomLimitSwitch.
I have come this far and could really use some help:
// These data pins link to 4 Relay board pins IN1, IN2, IN3, IN4
#define RELAY1 12
#define RELAY2 13
#define limSwitchBottom
#define limSwitchTop
// Initialise the Arduino data pins for OUTPUT
pinMode(RELAY1, OUTPUT);
pinMode(RELAY2, OUTPUT);
pinMode(limSwitchBottom, INPUT);
pinMode(limSwitchTop, INPUT);
int buttonState = 0; // variable for reading the pushbutton status
void loop(){
const int limSwitchBottom = 1; // the number of the bottom Limit switch pin
const int limSwitchTop = 2; // the number of the top Limit switch pin
buttonState = digitalRead(limSwitchBottom);
digitalWrite(RELAY1,LOW); // Turns ON Relay number 1
delay(4000); // Let motor run for 4 seconds
if(buttonState == LOW); // Wait for limit switch to un-trigger
//while (digitalRead(limSwitchBottom) == LOW); // Wait for limit switch to un-trigger
digitalWrite(RELAY1,HIGH); // Turns Relay number 1 Off
buttonState = digitalRead(limSwitchTop);
digitalWrite(RELAY2,LOW); // Turns ON Relay number 1
digitalWrite(RELAY2,HIGH); // Turns Relay number 2 Off
OK, on lines 8 and 10, you haven't specified pin numbers for the switches.
23 and 25, you have the unknown pins as INPUTs, are the switches connected to 5V or ground?
33 and 35, you are defining pin numbers with the same names as the previous defines ( you can't use pin 1, it's the serial TX pin), use the first defines and delete lines 33 and 35.
Fix those and see what happens and report back.
I made the adjustments and the code does not throw any errors now.
I did not connect the limit switches as of yet, but I was planning to connect them to ground.
If you read the code in my loop(), should it do what I want it to do(?), which is:
1. check if bottomLimitSwitch is pressed if false: give power to Relay1 so the motor runs CCW until it presses the bottomLimitSwitch, then it should stop. if true: give power to Relay1 so the motor runs CW until it presses the topLimitSwitch, then it should pause for 5 seconds, then run CCW until it hits bottomLimitSwitch.
#define RELAY1 12
#define RELAY2 13
#define limSwitchBottom 1
#define limSwitchTop 2
void setup(){
void loop(){
int buttonState = 0; // variable for reading the limSwitch status
rem what outsider said do not use pin number 1 for any inputs or outputs as it is used for serial tx. otherwise the code seems ok. change the 1 to a 3 or something besides 0 or 1.
rogertee:
Made some adjustments, does this look OK or is there another/ better way to do what I want?
I created notes with every line so it is easy to read and understand, hopefully..
Also I wasnt sure to use boolean or int.
#define RELAY1 12
#define RELAY2 13
#define limSwitchBottom 3
void setup(){
void loop(){
boolean bottomButtonState; // variable for reading the bottom limit Switch status
boolean topButtonState; // variable for reading the top limit Switch status
/* Maybe try int if bool doesnt work.
int bottomButtonState = 0; // variable for reading the bottom limit Switch status
int topButtonState = 0; // variable for reading the top limit Switch status
bottomButtonState = digitalRead(limSwitchBottom);
topButtonState = digitalRead(limSwitchTop);
if(bottomButtonState == LOW) // Check for (pushed) state bottom limit switch
digitalWrite(RELAY1,LOW); // If bottom limit switch is pressed, turn ON Relay number 1 to run motor CW
while(digitalRead(topButtonState) == LOW); // Wait for top limit switch to trigger
digitalWrite(RELAY1,HIGH); // Stop motor from running CW
delay(4000); // Pause 4 seconds
digitalWrite(RELAY2,LOW); // run motor CCW back to bottom position
while(digitalRead(bottomButtonState) == LOW); // Wait for bottom limit switch to trigger
digitalWrite(RELAY2,HIGH); // Stop motor from running CWW.
else if(topButtonState == LOW) // Check for (pushed) state top limit switch
digitalWrite(RELAY2,LOW); // If top limit switch is pressed, turn ON Relay number 2 to run motor CCW
digitalWrite(RELAY2,HIGH); // Stop motor from running CCW
else if(topButtonState == HIGH && bottomButtonState == HIGH) // Check for unpushed state both top and bottom limit switch
digitalWrite(RELAY2,LOW); // if TRUE Turns ON Relay number 2 to run motor CCW
delay(2000); // Pause 2 seconds
digitalWrite(RELAY1,LOW); // Turns ON Relay number 1 to run motor CW
