Control motor in self balancing robot
Hi, I am trying to make a self balancing robot but i have a problem in the way to control motor speed. What is MIN_ABS_SPEED meaning?
 // if programming failed, don't try to do anything
 if (!dmpReady) return;
 // wait for MPU interrupt or extra packet(s) available
 while (!mpuInterrupt && fifoCount < packetSize)
 //no mpu data - performing PID calculations and output to motors
 **pid.Compute();**
** motorController.move(output, MIN_ABS_SPEED);**
Which motor driver or library?
Until then I guess that it's the minimum speed before the motor stalls.
Here is the LMotorController library. They use minAbsSpeed too but i dont get it
#include "LMotorController.h"
#include "Arduino.h"
LMotorController::LMotorController(int ena, int in1, int in2, int enb, int in3, int in4, double motorAConst, double motorBConst)
    _motorAConst = motorAConst;
    _motorBConst = motorBConst;
	_ena = ena;
	_in1 = in1;
	_in2 = in2;
	_enb = enb;
	_in3 = in3;
	_in4 = in4;
	pinMode(_ena, OUTPUT);
	pinMode(_in1, OUTPUT);
	pinMode(_in2, OUTPUT);
	pinMode(_enb, OUTPUT);
	pinMode(_in3, OUTPUT);
	pinMode(_in4, OUTPUT);
void LMotorController::move(int leftSpeed, int rightSpeed, int minAbsSpeed)
    if (rightSpeed < 0)
        rightSpeed = min(rightSpeed, -1*minAbsSpeed);
        rightSpeed = max(rightSpeed, -255);
    else if (rightSpeed > 0)
        rightSpeed = max(rightSpeed, minAbsSpeed);
        rightSpeed = min(rightSpeed, 255);
    int realRightSpeed = map(abs(rightSpeed), 0, 255, minAbsSpeed, 255);
    if (leftSpeed < 0)
        leftSpeed = min(leftSpeed, -1*minAbsSpeed);
        leftSpeed = max(leftSpeed, -255);
    else if (leftSpeed > 0)
        leftSpeed = max(leftSpeed, minAbsSpeed);
        leftSpeed = min(leftSpeed, 255);
    int realLeftSpeed = map(abs(leftSpeed), 0, 255, minAbsSpeed, 255);
    digitalWrite(_in3, rightSpeed > 0 ? HIGH : LOW);
    digitalWrite(_in4, rightSpeed > 0 ? LOW : HIGH);
    digitalWrite(_in1, leftSpeed > 0 ? HIGH : LOW);
    digitalWrite(_in2, leftSpeed > 0 ? LOW : HIGH);
    analogWrite(_ena, realRightSpeed * _motorAConst);
    analogWrite(_enb, realLeftSpeed * _motorBConst);
void LMotorController::move(int speed, int minAbsSpeed)
    int direction = 1;
    if (speed < 0)
        direction = -1;
        speed = min(speed, -1*minAbsSpeed);
        speed = max(speed, -255);
        speed = max(speed, minAbsSpeed);
        speed = min(speed, 255);
    if (speed == _currentSpeed) return;
    int realSpeed = max(minAbsSpeed, abs(speed));
    digitalWrite(_in1, speed > 0 ? HIGH : LOW);
    digitalWrite(_in2, speed > 0 ? LOW : HIGH);
    digitalWrite(_in3, speed > 0 ? HIGH : LOW);
    digitalWrite(_in4, speed > 0 ? LOW : HIGH);
    analogWrite(_ena, realSpeed * _motorAConst);
    analogWrite(_enb, realSpeed * _motorBConst);
    _currentSpeed = direction * realSpeed;
void LMotorController::move(int speed)
    if (speed > 255) speed = 255;
    else if (speed < -255) speed = -255;
    analogWrite(_ena, abs(speed) * _motorAConst);
    analogWrite(_enb, abs(speed) * _motorBConst);
    _currentSpeed = speed;
void LMotorController::turnLeft(int speed, bool kick)
    digitalWrite(_in1, HIGH);
    digitalWrite(_in2, LOW);
    digitalWrite(_in3, LOW);
    digitalWrite(_in4, HIGH);
    if (kick)
        analogWrite(_ena, 255);
        analogWrite(_enb, 255);
        delay(100);
    analogWrite(_ena, speed * _motorAConst);
    analogWrite(_enb, speed * _motorBConst);
void LMotorController::turnRight(int speed, bool kick)
    digitalWrite(_in1, LOW);
    digitalWrite(_in2, HIGH);
    digitalWrite(_in3, HIGH);
    digitalWrite(_in4, LOW);
    if (kick)
        delay(100);
void LMotorController::stopMoving()
    digitalWrite(_ena, HIGH);
    digitalWrite(_enb, HIGH);
    _currentSpeed = 0;
Please give a link to the home page of that library. There should also reside the required documentation.
Here you are
https://github.com/kurimawxx00/arduino-self-balancing-robot
Sorry, that's not the home of the LMotorController library.
thanks for your responses. I found a document said the same as your first response
