Control multiple FDD drives via PD
I can fully control single FDD. When send "20" by object "comport" from the PD then run a line of code:
if (incomingByte == 20) vibe (40, 4291);
and so on
My problem is that I connected two FDD and I would like to have played two different sounds simultaneously that is run two commands at once. Unfortunately, it works like this:
  • 20 launches drive A
  • 30 launches both drives, despite the fact that should work only drive B
  • 20 and 30 simultaneously - launches first drive A and B after a long delay
I Make a mistake somewhere, but I do not understand where.
Arduino code:
SETTINGS
#define StepA 2
#define DirA 3
#define SelA 4
#define StepB 5
#define DirB 6
#define SelB 7
int incomingByte = 0;
START
  Serial.begin(9600); // opens serial port, sets data rate to 9600 bps
  pinMode(DirA, OUTPUT);
  pinMode(StepA, OUTPUT);
  pinMode(SelA, OUTPUT);
  digitalWrite(SelA, HIGH);
  pinMode(DirB, OUTPUT);
  pinMode(StepB, OUTPUT);
  pinMode(SelB, OUTPUT);
  digitalWrite(SelB, HIGH);
  initHead();  // move header half way
void initHead() {
  digitalWrite(StepA, HIGH);
  digitalWrite(DirA, HIGH);
  doSteps(80, 1911);  // move header to start position wherever it is, 80 steps at ~261 step/s
  digitalWrite(DirA, LOW);
  doSteps(40, 1911);
  digitalWrite(StepB, HIGH);
  digitalWrite(DirB, HIGH);
  digitalWrite(DirB, LOW);
  doSteps(40, 1911);
void doSteps(int steps, int stepDelay) {
  digitalWrite(SelA, LOW);
  for(int i=0;i<steps; i++) {
    digitalWrite(StepA,LOW);
    delayMicroseconds(stepDelay);
    digitalWrite(StepA,HIGH);
    digitalWrite(StepB,LOW);
    digitalWrite(StepB,HIGH);
VIBE VIBE VIBE
void vibeA(int count, int period) {
  for(int l=0;l<count; l++) {
    doSteps(1, period);
    doSteps(1, period);
void vibeB(int count, int period) {
    doSteps(1, period);
    doSteps(1, period);
FIRST FDD
  if (Serial.available()>0) {
    incomingByte=Serial.read();
  if (incomingByte == 20) vibeA(40, 4291);  //C
  if (incomingByte == 21) vibeA(40, 4050);
  if (incomingByte == 22) vibeA(40, 3823);
  if (incomingByte == 23) vibeA(40, 3609);
SECOND FDD
  if (incomingByte == 30) vibeB(40, 4291); //C
  if (incomingByte == 31) vibeB(40, 4050);
  if (incomingByte == 32) vibeB(40, 3823);
  if (incomingByte == 33) vibeB(40, 3609);
Your doSteps() function is a blocking function that takes time to complete. You will never get both drives to move at the same time with the blocking delay() calls.
How is PD (whatever that is) sending the data. The code you posted is not expecting "20" or "30" or any other string.
20 launches drive A
The middle issue looks like it might be a PD issue, since there is nothing in the code that I see that would explain it.
