control multiple led using ldr and gsm
hi all,
i have a sketch which multiple led is being control on/off by using ldr. They also can be turn on/off automatically by sms.
the code can compile. I got sms after initialization setting " the system is ready" but the led is not working. i hope somebody could give me some pointer?
thanks.
#include "SIM900.h"
#include <SoftwareSerial.h>
#include "sms.h"
SMSGSM sms;
int a = 8 ;
boolean started=false;
char pos;
char message[180];
char number[13];
char *LedOn;
char *LedOff;
int LDR = 0;     //analog pin to which LDR is connected, here we set it to 0 so it means A0
int LDRValue = 0;      //that’s a variable to store LDR values
int light_sensitivity = 500;    //This is the approx value of light surrounding your LDR (on observation:700 on afternoon, 500 on morning
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  pinMode(10, OUTPUT);
  pinMode(11, OUTPUT);
  pinMode(12, OUTPUT);
  digitalWrite(8, LOW);
  digitalWrite(9, LOW);
  digitalWrite(10, LOW);
  digitalWrite(11, LOW);
  digitalWrite(12, LOW);
  number[12]='\0';
  if (gsm.begin(9600))
    Serial.println("\nstatus=READY");
    started=true;
        Serial.println("\nstatus=IDLE");
    if(started)
        if (sms.SendSMS("+00000000000", "The system is ready"))
          Serial.println("\nSMS sent OK.");
          Serial.println("\nError sending SMS.");
    LDRValue = analogRead(LDR);      //reads the ldr’s value through LDR
    Serial.println(LDRValue);       //prints the LDR values to serial monitor
    delay(100);        //This is the speed by which LDR sends value to arduino
 for (int a=8; a < 13; a++)
    if (LDRValue < light_sensitivity)
        digitalWrite(a, HIGH);
        digitalWrite(a, LOW);
  if(started)
    pos=sms.IsSMSPresent(SMS_UNREAD);
    if((int)pos>0 && (int)pos<=20)
      message[0]='\0';
      sms.GetSMS((int)pos,number,message,180);
      LedOn = strstr(message,"Led on");
      LedOff = strstr(message,"Led off");
      if(LedOn)  digitalWrite(a, HIGH);
      if(LedOff)  digitalWrite(a, LOW);
      sms.DeleteSMS((int)pos);
    delay(5000);
That comment is nonsense.
What does sending "Led on" mean? You are checking for an SMS when a is 8. If there is one, you check the contents and turn pin 8 on or off and delete the message. Then, a is incremented to 9, and you check for an SMS. If there is one, you check the contents and turn pin 9 on or off and delete the message. You repeat that for pins 10, 11, and 12.
That just seems bizarre.
