Control of pressure via serial and linear actuator
I am able to send a receive variables completely fine when i run functions separately for instance i will send over and i will receive ABC on the serial line just like i want to. if i run another function separately which i am using to set the value of a variable to an integer and i send (250) i will receive 250 just like i expect on the serial monitor. I am trying to control a linear actuator so that it achieves a certain pressure value and then holds that pressure value. I send commands to the actuator using the <> brackets and i send my variable value in (). I don't seem to be able to run these two commands at the same time. I am trying to send the commands in <> to an actuator and keeping the value i send in () saved on the arduino as a variable to reference against the incoming analog read which is my pressure value. If anyone may be able to offer some advice thanks in advance. My next step after figuring this out will be incorporating a PID.
The following is the code that i am trying to get to run:
#include <SoftwareSerial.h>
#define rxPin 10 //define receiver pin
#define txPin 11 //define transmitter pin
SoftwareSerial mySerial =  SoftwareSerial(rxPin, txPin);
const byte numChars = 32;
char receivedChars[numChars];
boolean newData = false;
const byte numCharspress = 32;
char receivedCharspress[numCharspress];
boolean newDatapress = false;
int t = 1000;//delay
int analogPin = 0;
int val = 0;
int pval;
  pinMode(rxPin, INPUT); //pin type
  pinMode(txPin, OUTPUT); //pin type
  Serial.begin(115200); //set baud rate for arduino to pc
  mySerial.begin(115200); //set baud rate for arduino to actuator
  delay(t);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  mySerial.println("SP1200000"); //set initial speed
  mySerial.println("AC3000"); //set initial acceleration
  mySerial.println("TA5000"); //cycle through some movements to let me know everythings working
  delay(t);
  mySerial.println("TA10000"); //cycle through some movements to let me know everythings working
  delay(t);
  mySerial.println("TA15000"); //cycle through some movements to let me know everythings working
  delay(t);
  mySerial.println("TR"); //return to start of movement
  delay(t);
    getPressureval(); // gets pressure value from pressure sensor on apin 0
    recvpressWithStartEndMarkers(); // gets pressure value from pc serial input in "()"
    showNewDatapress(); //echos received data to serial monitor so i know it was received correctly
    recvWithStartEndMarkers(); //gets commands to be sent to actuator in "<>"
    showNewData(); //sends commands from pc to actuator that were sent in "<>"
    pressureMove(); // Moves actuator so that it maintains pressure value set in "()"
void getPressureval()
    val = analogRead(analogPin); //reads the pressure sensor
    Serial.println(val); //sends the pressure values through serial
    delay(10);
void recvpressWithStartEndMarkers()
    static boolean recvInProgresspress = false;
    static byte ndxpress = 0;
    char startMarkerpress = '(';
    char endMarkerpress = ')';
    char rcpress;
    while (Serial.available() > 0 && newDatapress == false) {
        rcpress = Serial.read();
        if (recvInProgresspress == true) {
            if (rcpress != endMarkerpress) {
                receivedCharspress[ndxpress] = rcpress;
                ndxpress++;
                if (ndxpress >= numCharspress) {
                    ndxpress = numCharspress - 1;
            else {
                receivedCharspress[ndxpress] = '\0'; // terminate the string
                ndxpress = 0;
                newDatapress = true;
        else if (rcpress == startMarkerpress) {
            recvInProgresspress = true;
void showNewDatapress()
     if (newDatapress == true) {
        pval = atoi(receivedCharspress);
        Serial.println(pval);
void recvWithStartEndMarkers()
    static boolean recvInProgress = false;
    static byte ndx = 0;
    char startMarker = '<';
    char endMarker = '>';
    char rc;
    while (Serial.available() > 0 && newData == false) {
        rc = Serial.read();
        if (recvInProgress == true) {
            if (rc != endMarker) {
                receivedChars[ndx] = rc;
                ndx++;
                if (ndx >= numChars) {
                    ndx = numChars - 1;
            else {
                receivedChars[ndx] = '\0'; // terminate the string
                ndx = 0;
                newData = true;
        else if (rc == startMarker) {
            recvInProgress = true;
void showNewData()
    if (newData == true) {
        mySerial.println(receivedChars);
        newData = false;
void pressureMove ()
  if (val > pval)
  else if (val< pval)
    mySerial.println("TE");
    mySerial.println("TK");
Both of your functions to receive serial data contain:
        rc = Serial.read();
Since both functions get called, and newDatapress and newData are true ONLY when the end markers arrive, you are reading all available data twice. You are guaranteed to scramble data that way.
It would be far simpler to have ONE function to get serial data, with one kind of start and end markers. Inside the markers, you would have <A:actuatorData> or <P:pressureData>. When newData is true, you would then look at the first character to decide whether it is actuator data or pressure data, and use the remaining data appropriately.
You should just have one receive function and include in the data some identifier so the Arduino knows what the data is for. For example <X, ABC> and <Y,250>
Another (perhaps simpler) option is to send all the data every time even if values have not changed. For example <ABC,250>
...R
I thought about doing something like that as i have done something similar in a previous project, but wasn't able to get it working for this project. I tried it earlier on but what i had before seemed a little bit easier for me to do. I cant seem to get the right ouput though
void showNewData()
    char* a = receivedChars;
    if (a[0] = A )
      string1 = String(receivedChars);
      Serial.println(string1);
      L = string1.length();
      command = receivedChars[1,L];
      Serial.println(command);
    newData = false;
if i print a[0] i get A when i send over
but when i run it through my statement i can't get it to print the rest of the characters
I figured out the first part i forgot to compare it to a character, but I cant seem to figure out how to store the characters that I loop through in my for loop so that i can later issue them in a Serial.println() command. I tried using Serial.print() which sends all the characters on one line and then sending a Serial.print("\n") to terminate it, but the actuator won't pick this up i had this problem before it needs to be sent as Serial.println().
void showNewData()
    if (a[0] = 'A' )
      s = a;
      L = s.length();
      V = L - 1;
      for (int i=1; i<L; i++)
        C = a[i];
      Serial.println(C);
    newData = false;
You seem to be making this far too complicated. Have you looked at the parse example in Serial Input Basics? It should do most of what you want.
Use showNewData() as a debugging tool to show the data as received. Create another function to parse the data.
...R
How far apart are your two controllers?
Tom... :slight_smile:
I forgot to post it i ended up just doing this:
void showNewData()
    s = a;
    if (a[0] = 'A' )
      s.remove(0,1);
      Serial.println(s);
      mySerial.println(s);
    else if (a[0] = 'P')
      s.remove(0,1);
      pval = s.toInt();
      //Serial.println(pval);
    newData = false;
I dont really understand the question how far apart they are. They are both wired to the arduino if that is what you are asking.
How far apart are your two arduinos, cms, meters etc...
Why do you need two arduinos, what model are they? UNO, MEGA ???
Thanks.. Tom.. :slight_smile:
I only have one arduino. It is hooked up to a PC it sends commands like to set the pressure value that i want to be achieved, acceleration/speed of actuator. I want to have the actuator hold certain pressure values but this is the area that i can't seem to get to work. If i run my code and skip over the reading of the pressure data and the movement of the actuator based on the pressure data i can issue position commands in the brackets i.e but if i turn on the analog read for the pressure value and the loop i have running to try to maintain a pressure is where i run into an issue. I can no longer send position commands and i also can't get the actuator to move to the position i set the pressure to even though i can see that the arduino is receiving my commands.
int analogPin = 0;
int val;
int pval;
String s = "";
  Serial1.begin(115200); //set baud rate for arduino to actuator
  delay(t);
  while (!Serial) {
  Serial1.println("SP1200000"); //set initial speed
  Serial1.println("AC3000"); //set initial acceleration
  Serial1.println("TA5000"); //cycle through some movements to let me know everythings working
  delay(t);
  Serial1.println("TA10000"); //cycle through some movements to let me know everythings working
  delay(t);
  Serial1.println("TA15000"); //cycle through some movements to let me know everythings working
  delay(t);
  Serial1.println("TR"); //return to start of movement
  delay(t);
    recvWithStartEndMarkers(); // gets pressure value from pc serial input in "()"
    delay(10);
    char rc;
        rc = Serial.read();
                ndx++;
                    ndx = numChars - 1;
            else {
                ndx = 0;
                newData = true;
void showNewData()
    s = a;
    if (a[0] = 'A' )
      s.remove(0,1);
      Serial.println(s);
      Serial1.println(s);
      s.remove(0,1);
      pval = s.toInt();
    newData = false;
  if (val > pval)
  else if (val< pval)
    Serial1.println("TE");
    Serial1.println("TK");
Hi.
Okay so you have.
  • A pressure sensor.
  • An actuator.
  • An Arduino.
  • A PC.
  • The actuator is connected to a pressure control valve.
  • The Arduino, what model?, controls the actuator via serial comms.
  • The Arduino, is also connected to the pressure sensor, analog input.
  • The Arduino is also connected to a PC.
  • The PC communicates with the Arduino and sends the pressure value it wants to the Arduino to use as it's set value?
  • The Arduino then controls the actuator to keep the pressure at the set value.
Please tell us if each item I have written is correct.
Now, can you post links to the data/spec of the pressure transducer and actuator please?
Yes a pressure sensor connected to an arduino MEGA 2560 and an actuator connected to the same arduino. I am reading the incoming pressure data on analog pin 0. I am sending commands to the actuator via rx1 and tx1 on the mega board. I am trying to send the pressure values read on the analog pin to the computer via the usb A to usb B cable on the MEGA 2560. I am trying to set the desired pressure value that i want with the computer and also send the actuator certain data like max accel and max speed and also if i want to manually decide how far i want the actuator to extend.
I am using the following materials:
  1. max3232 chip from Sparkfun so that the arduino can communicate with the actuator which is using rs232
  2. Arduino Mega 2560
  3. Omega PX309-015G5V (Pressure Range 0-15psi, 0-5Vdc)
  4. Ultramotion Linear Actuator (Servo Cylinder – Ultra Motion) not much doc. on this.
Thanks for helping clear up the situation,
Why do you need to control the actuator speed and acceleration?
Have you tried PID control of the pressure actuator, it will take care of your response times and control errors.
PS. Can you begin spacing you answers like in posts replying to your posts please, the forum editor does not do indenting or paragraphs.
So without carriage returns all your sentences run together.
Not your fault, but line spaces help.
I need to control the actuator speed and acceleration because it minimizes the amount of travel that the actuator will move during a set time.
The actuator needs to be issued a stop command in order to stop its current trajectory and then issued a new command which will reverse its trajectory so that it can go to the set value there is a small delay in this command so if i decrease the speed and acceleration there will be less travel during this delay which will give me pressure values closer to what i'm looking for. which is why i want to take the output of a PID and use it to control the speed and acceleration of the actuator.
I am trying to implement a PID that brett beauregard posted on his blog so that i can minimize the error in pressure values when I change them. (Improving the Beginner’s PID – Introduction « Project Blog)
My Current Code is:
//Receiving Variables
const byte numChars = 32; //deifnes size of byte array
char receivedChars[numChars]; //defines receivedChars as character array
boolean newData = false; //Inititalezes boolean value
// timing variables
//Pressure Variables and Pins
int analogPin = 0; //sets the analog pin to
//double Input;  // value of pressure read by analog pin
double Setpoint1; //value of pressure set by serial
//working variables
unsigned long lastTime;
double Input, Output, Setpoint;
double errSum, lastInput;
double kp, ki, kd;
double Kp = 1; double Ki = 1; double Kd = 1;
  delay(t);
  while (!Serial) {
  Serial1.println("SP12000000"); //set initial speed
  delay(t);
  delay(t);
  delay(t);
  delay(t);
    commands(); //sends commands from pc to actuator that were sent in "<>"
    Compute();
    SetTunings(double Kp, double Ki, double Kd);
    Input = analogRead(analogPin); //reads the pressure sensor
    //Serial.println(Input1); //sends the pressure values through serial
    delay(10);
    static boolean recvInProgress = false; //creates variable visible to only one function with boolean
    char startMarker = '<'; //sets begin condition
    char endMarker = '>'; //sets end condition
    char rc; //sets variable type to char
        rc = Serial.read(); //sets rc equal to serial value
                ndx++;
                    ndx = numChars - 1;
            else {
                ndx = 0;
                newData = true;
void commands()
    if (receivedChars[0] == 'A')
      //Serial.println(&receivedChars[1]);
      Serial1.println(&receivedChars[1]);
    else if (receivedChars[0] == 'P')
      Setpoint1 = atoi(&receivedChars[1]);
      Setpoint = Setpoint1;
      Serial.println(Setpoint);
    else if (receivedChars[0] == 'S')
    Setpoint = 0;
    delay(5000);
  newData = false;
void Compute()
   /*How long since we last calculated*/
   unsigned long now = millis();
   double timeChange = (double)(now - lastTime);
   /*Compute all the working error variables*/
   double error = Setpoint - Input;
   errSum += (error * timeChange);
   double dErr = (error - lastErr) / timeChange;
   /*Compute PID Output*/
   Output = kp * error + ki * errSum + kd * dErr;
   /*Remember some variables for next time*/
   lastErr = error;
   lastTime = now;
void SetTunings(double Kp, double Ki, double Kd)
   kp = Kp;
   ki = Ki;
   kd = Kd;
void SetSampleTime(int NewSampleTime)
   if (NewSampleTime > 0)
      double ratio  = (double)NewSampleTime
                      / (double)SampleTime;
      ki *= ratio;
      kd /= ratio;
      SampleTime = (unsigned long)NewSampleTime;
  if (Input > Setpoint + Setpoint*.1)
    //Serial1.println("SP");
    //Serial1.println("AC");
  else if (Input< Setpoint - Setpoint*.1)
I Keep getting the error: exit status 1
expected primary-expression before 'double'
So i am trying to figure this out now if you have any suggestions please let me know i am just concerned with getting the PID to work right now and getting the Output from it i will then take that output and use it to adjust the speed and accel.
Thank you for the help.
emg184:
You have double in lots of places.Which line is causing the problem?
...R
I fixed that I have added the rest of his program to my arduino I am now just trying to make it so that i can control the speed and get the outputs I would expect. My main concern right now is getting the Outputs and seeing their behavior i want to set my pressure value and then see the output values decrease as i near that pressure value although now i am only seeing the output as zero.
// timing variables
//working variables
double ITerm, lastInput;
double kp, ki, kd;
int SampleTime = 10; //.01 sec
int NewSampleTime;
double Min; double Max;
double outMin = -50000000; double outMax = 50000000;
bool inAuto = false;
int Mode;
int Direction;
#define MANUAL 0
#define AUTOMATIC 1
#define DIRECT 0
#define REVERSE 1
int controllerDirection = DIRECT;
  delay(t);
  while (!Serial) {
  delay(t);
  delay(t);
  delay(t);
  delay(t);
    Compute();
    SetTunings();
    SetSampleTime();
    SetOutputLimits();
    SetMode();
    Initialize();
    SetControllerDirection();
    Serial.println(Output);
    Serial.println(Input); //sends the pressure values through serial
    //delay(10);
                ndx++;
                    ndx = numChars - 1;
            else {
                ndx = 0;
                newData = true;
void commands()
      //Serial.println(Setpoint);
    Setpoint = 0;
    delay(5000);
  newData = false;
void Compute()
   if(!inAuto) return;
   int timeChange = (now - lastTime);
   if(timeChange>=SampleTime)
   ITerm += (ki * error);
   if(ITerm> outMax) ITerm= outMax;
   else if(ITerm< outMin) ITerm= outMin;
   double dInput = (Input - lastInput);
   Output = kp * error + ITerm - kd * dInput;
   if(Output > outMax) Output = outMax;
   else if(Output < outMin) Output = outMin;
   //Serial.println(Output);
   lastInput = Input;
   lastTime = now;
void SetTunings()
   if (Kp<0 || Ki<0|| Kd<0) return;
   double SampleTimeInSec = ((double)SampleTime)/1000;
   kp = Kp;
   ki = Ki * SampleTimeInSec;
   kd = Kd / SampleTimeInSec;
  if(controllerDirection ==REVERSE)
  kp = (0 - kp);
  ki = (0 - ki);
  kd = (0 - kd);
void SetSampleTime()
      ki *= ratio;
      kd /= ratio;
void SetOutputLimits()
   if(Min > Max) return;
   outMin = Min;
   outMax = Max;
void SetMode()
    bool newAuto = (Mode == AUTOMATIC);
    if(newAuto && !inAuto)
    {  /*we just went from manual to auto*/
        Initialize();
    inAuto = newAuto;
void Initialize()
   lastInput = Input;
   ITerm = Output;
void SetControllerDirection()
   controllerDirection = Direction;
I am just using his as an example controller so i can familiarize myself with PID and implement my own.
Glad you are making progress.
Let us know if you have any further questions.
...R
I am able to control the piston to send it from one pressure value to another but the more I add to my program the longer the delay appears to be for the actuator to move.
My end goal is to be able to send pressure values from matlab to the arduino and have it move smoothly from pressure value to pressure value.
The basic idea is:
  1. Read the pressure value on the analog pin. Compare the pressure read to the pressure value i set it to go to with the PC
  2. Send the trajectory interrupt command via Serial1("TK")
  3. Set the Speed via Serial1("SP...")
  4. Set the acceleration via Serial1("AC...")
  5. Move the actuator based on the Pressure value via Serial1("TE or TR") TR to decrease TE to increase
I was able to get an ok control system going by just using logic statements that got incrementally smaller. So if the read value is between 10% 9% 8% of setpoint adjust speed and accel to lower and lower values.
Here is my current code: (I have not been able to play with the tuning parameters yet since the system really isnt running smooth and am just printing them to the screen to see how it's working while i have the PID going).
#include <PID_v1.h>
// timing variables
//Define Variables we'll be connecting to
double Setpoint, Setpoint1, Input, Output;
double min, max;
int Y,A,S;
String X;
String Velocity;
String Acceleration;
PID myPID(&Input, &Output, &Setpoint,1,1,1, DIRECT);
  myPID.SetMode(AUTOMATIC);
  min = -50000000;
  max = 50000000;
  myPID.SetSampleTime(10);
  myPID.SetOutputLimits(min, max);
  delay(t);
  while (!Serial) {
  delay(t);
  delay(t);
  delay(t);
  delay(t);
    myPID.Compute();
    Y = abs(Output);
    A = Y;
    S = Y * 1500000;
    X = String(Y);
    String Speed = "SP";
    String Accel = "AC";
    String Velocity = Speed + S;
    String Acceleration = Accel + A;
    Serial.println(Velocity);
    Serial.println(Acceleration);
    delay(10);
                ndx++;
                    ndx = numChars - 1;
            else {
                ndx = 0;
                newData = true;
void commands()
  { Serial1.println("TK");
      Setpoint = atoi(&receivedChars[1]);
      Setpoint1 = Setpoint;
    Setpoint = 0;
    delay(5000);
  newData = false;
  if (Input > Setpoint1)
    //Serial1.println(Velocity);
    //Serial1.println(Acceleration);
  else if (Input < Setpoint1)
Why does getPressureval() have a delay() in it?
Why do you need to move the actuator on EVERY pass through loop()?
What, exactly, are you doing with the output from myPID.Compute()?
You have delay(5000) in your program. You should not use the delay() function at all as the Arduino can do nothing useful during a delay. In 5 seconds an Arduino can do about 80 million instructions.
The demo Several Things at a Time illustrates the use of millis() to manage timing without blocking.
...R
