Control of projector screen hangs
Hi all.
I made control of projector screen via remote control from projector, based on arduino nano and IR sensor. Everything works fine but sometimes, I suppose when to fast pushing the buttons to roll down or roll up prejector screen, the system hangs. Then I have to restart the board and is ok. Should I add something to the code?
#include <IRremote.h>
#define irPin 5
IRrecv irrecv(irPin);
decode_results results;
String ekran;
   irrecv.enableIRIn();
   pinMode(2, OUTPUT); //góra
   pinMode(3, OUTPUT); //stop
   pinMode(4, OUTPUT); //dół
   if (irrecv.decode(&results)) {
      //Serial.println(results.value);
       unsigned long odczyt = results.value;
if (odczyt == 1286813895) {ekran = odczyt;}
if (ekran == "1286813895"){
 switch (odczyt) {
case 1286834295:
    Serial.println("Góra");
     ekran = "";
     digitalWrite(4, HIGH);
     delay(200);
     digitalWrite(4, LOW);
case 1286860815:
     Serial.println("Stop");
     ekran = "";
     digitalWrite(3, HIGH);
     delay(200);
     digitalWrite(3, LOW);
case 1286809815:
    Serial.println("Dół");
     ekran = "";
     digitalWrite(2, HIGH);
     delay(200);
     digitalWrite(2, LOW);
      delay(250);
      irrecv.resume();
This sequence looks fischy:
   switch (odczyt) {
zwieblum:
  switch (odczyt) {
Ok, so what is your proposition? First I push the "initial" button and after that I can push up, down or stop button, otherwise nothing happen. This is solution to prevent changing something in projector settings during directly pushing navigation buttons(up, down or enter-stop).
