Control of Remote Control HELP!!!
I have a little rc car that I would like to program a certain way. What I would like to do is use the arduino to control the remote of the car. That way I don't need wifi sheild ect... I have taken apart the remote control to the car and determined what points I need to activate at certain times. Basically I am looking for some help on how to switch on/off for the forward, backward, left, and right. Then I want to write a program to make the car do a demo. I was thinking about using a jk flip flop or relay to control switching. What do you think? I do not know how to program the arduino to do what I want in this case. Usually I would find a similar application and manipulate the code to fit my need, but I can't figure it out. Everything that is similar is using a push button but I want this to be automatic. Basically I want to connect and disconnect wires at different times. Please help
One way to control the remote is with a CD4066 Quad Bilateral Switch. It acts like four digitally controlled switches. Put a switch across each 'button' and use the Arduino to turn the switches on and off.
Now we're talkin'! That sounds like exactly what I need. I will look it up and see where it gets me. Thank you for your suggestion.
I just so happen to have a 4066 in my box of toys! I gotta find some code for arduino now and I'm ready to role!
IR remote hacking from back in the day.
http://web.comporium.net/~shb/irmods.htm
reubenroman:
Just control each switch with an Arduino pin. Set pin HIGH for PRESSED and LOW for RELEASED. If that doesn't work, reverse it (LOW for PRESSED and HIGH for RELEASED).
I hooked up one switch to test. It works perfect with an led. But when I hooked it up to the remote control it is always on. It does not go on/off like the led does. I have the circuit as shown in attachment. The remote has its own power source. I don't get what I am doing wrong
