Control of two motors with ESP32 and L298N
Hello, I'm controlling a two-wheeled robot with two DC motors with an ESP32 and an L298N. Its operation is that it detects 3 photoresistors and at the moment of detecting any of them the motors move. At the time of loading the program only makes me function 1 motor. The other isn't answering. The curious thing happens with the ports ENA1, ENA2 and ENB1 and ENB2. If I connect ENA1 and ENB2 only does the function motor A but if I connect ENA2 and ENB1 only does the B. If I connect ENA1 and ENB1 or ENA2 and ENB2 does nothing. As I have researched those ports only have the function of enabling or disabling the engines and controlling it by PWM but whatever it is should not be a problem. I suspect the program is the problem, someone would know what the problem might be.
As a fact, I do not know if it is relevant, the ESP32 and the LN298N have separate power supply. The ESP32 with batteries (+12V) and the ESP32 with a power bank.
This is the program in Arduino IDE:
// Librería para el ESP32
#include <WiFi.h>
// Pines de las fotorresistencias
const int leftSensorPin = 34;
const int middleSensorPin = 35;
const int rightSensorPin = 36;
// Pines del puente H L298N
const int motor1Pin1 = 2;
const int motor1Pin2 = 4;
const int motor2Pin1 = 32;
const int motor2Pin2 = 33;
// Pines de habilitación de los motores (ENA y ENB)
const int enableAPin = 25;  // Puedes asignar cualquier pin disponible
const int enableBPin = 26;  // Puedes asignar cualquier pin disponible
  // Configurar los pines de los motores como salida
  pinMode(motor1Pin1, OUTPUT);
  pinMode(motor1Pin2, OUTPUT);
  pinMode(motor2Pin1, OUTPUT);
  pinMode(motor2Pin2, OUTPUT);
  // Configurar los pines de habilitación como salida
  pinMode(enableAPin, OUTPUT);
  pinMode(enableBPin, OUTPUT);
  // Iniciar la comunicación serial
  // Habilitar PWM en los pines de habilitación de los motores
  ledcSetup(0, 5000, 8);  // Canal 0, frecuencia 5000Hz, resolución de 8 bits
  ledcSetup(1, 5000, 8);  // Canal 1, frecuencia 5000Hz, resolución de 8 bits
  ledcAttachPin(enableAPin, 0); // Habilitar PWM en el pin de habilitación del motor A
  ledcAttachPin(enableBPin, 1); // Habilitar PWM en el pin de habilitación del motor B
  // Leer los valores de las fotorresistencias
  int leftSensorValue = analogRead(leftSensorPin);
  int middleSensorValue = analogRead(middleSensorPin);
  int rightSensorValue = analogRead(rightSensorPin);
  // Mostrar los valores en el monitor serial
  Serial.print("Left Sensor: ");
  Serial.print(leftSensorValue);
  Serial.print(" | Middle Sensor: ");
  Serial.print(middleSensorValue);
  Serial.print(" | Right Sensor: ");
  Serial.println(rightSensorValue);
  // Determinar cuál sensor tiene el valor más alto
  int maxValue = max(leftSensorValue, max(middleSensorValue, rightSensorValue));
  // Control de los motores según las lecturas de las fotorresistencias
  if (maxValue > 300) { // Activar movimiento solo si algún sensor detecta más de 300
    if (leftSensorValue == maxValue) {
      // Alumbrar fotorresistencia izquierda: gira a la izquierda
      digitalWrite(motor1Pin1, HIGH); // Avance
      digitalWrite(motor1Pin2, LOW); // Reversa
      digitalWrite(motor2Pin1, LOW); // Avance
      digitalWrite(motor2Pin2, HIGH); // Reversa
      // Ajustar la velocidad de los motores
      ledcWrite(0, 255); // Velocidad máxima para motor 1
      ledcWrite(1, 255); // Velocidad máxima para motor 2
    } else if (middleSensorValue == maxValue) {
      // Alumbrar fotorresistencia del medio: avanza hacia adelante
      digitalWrite(motor2Pin1, HIGH); // Avance
      digitalWrite(motor2Pin2, LOW); // Reversa
    } else if (rightSensorValue == maxValue) {
      // Alumbrar fotorresistencia derecha: gira a la derecha
      digitalWrite(motor1Pin1, LOW); // Avance
      digitalWrite(motor1Pin2, HIGH); // Reversa
    // Si ninguno de los sensores detecta más de 300, detener el robot
The L298 has 6 inputs pins, ENA, IN1, IN2, IN3, IN4, ENB.
What ESP pins are connected to the 6 L298 pins?
Im using this pins:
ENA = 25
IN1 = 2
IN2 = 4
ENB = 26
IN3 = 32
IN4 = 33
OK.
Are you sure that your power supply can provide enough current to drive both motors?
You also need to connect the L298 GND pin the the ESP ground GND pin
It works when I connect together both GND of ESP32 and LN298N. Thanks a lot . But I have a question, why this was the problem. Is there a difference between having 2 different GND and only 1?
Yes. Electricity always need a complete circuit whether it is power or a signal.
You know that if you connect an LED with only one wire to a battery, it will not work. Same is true for the signals going from the ESP to the L298. You need the ground wire between the two in order to complete the circuit.
Glad it worked
Have a nice day
