Hey people, i'm building a camera slider. That's how i got into Arduino.
After a little research i managed to get a Nema 17 - 12 Volt 2,5 Amp steppermotor to run on my joystick
for now i use the nano with drv8825. I took a stepperprogram because i didn't learn code yet.
what i like to know is if its possible to program steps ahead? like travel from A to B with optional waypoints, i heard about the stepperlibery that makes it possible for the motors to start and finish at the same time even if the have to travel another length (it auto adjusts speed)
i still also like to keep the joystick funtion.
is it possible to create a modus like that, so you can switch between pre programed camera moves and live filming
i want to change it so i can use it with a Nano in stead of UNO.
And i hope that i can find help with building this stand alone (with a display, and just a few buttons, or control it with my tablet with somthing like the app Arduino Total Control.
any other suggestions that could improve this idea are welcome
/* Arduino Multiple Stepper Control Using Joystick switch
Created by Yvan / https://Brainy-Bits.com
This code is in the public domain...
You can: copy it, use it, modify it, share it or just plain ignore it!
Thx!
// Library created by Mike McCauley at http://www.airspayce.com/mikem/arduino/AccelStepper/
#include "AccelStepper.h"
#include "MultiStepper.h"
// AccelStepper Setup
AccelStepper stepperX(1, 3, 4); // 1 = Easy Driver interface
// UNO Pin 3 connected to STEP pin of Easy Driver
// UNO Pin 4 connected to DIR pin of Easy Driver
AccelStepper stepperZ(1, 6, 7); // 1 = Easy Driver interface
// UNO Pin 6 connected to STEP pin of Easy Driver
// UNO Pin 7 connected to DIR pin of Easy Driver
MultiStepper StepperControl; // Create instance of MultiStepper
// Analog Joystick setup
#define JoyX A0 // Joystick X pin connected to A0 on the UNO
#define JoyY A1 // Joystick Y pin connected to A1 on the UNO
#define JoySwitch 2 // Joystick switch connected to interrupt Pin 2 on UNO
long joystepX=0; // Used to move steppers when using the Joystick
long joystepY=0; // Used to move steppers when using the Joystick
// Variables used to store the IN and OUT points
volatile long XInPoint=0;
volatile long ZInPoint=0;
volatile long XOutPoint=0;
volatile long ZOutPoint=0;
int InandOut=0; // Used to detect if IN and OUT points have been set
long gotoposition[2]; // Used to move steppers using MultiStepper Control
void joyswitchclick () { // Interrupt runs when clicking the Joystick Switch
static unsigned long last_call_interrupt = 0; // Used to debounce to Joystick Switch
unsigned long interrupt_length = millis();
if (interrupt_length - last_call_interrupt > 300) { // Check if enough time has passed since clicking switch
switch (InandOut) { // Keep track of number of times the switch has been clicked
case 0:
InandOut=1;
XInPoint=stepperX.currentPosition(); // Set the IN points for both steppers
ZInPoint=stepperZ.currentPosition();
Serial.print("IN Points set at: ");
Serial.print(XInPoint);
Serial.print(" , ");
Serial.println(ZInPoint);
Serial.println("");
Serial.println("Use Joystick to set OUT Points: ");
case 1:
InandOut=2;
XOutPoint=stepperX.currentPosition(); // Set the OUT Points for both steppers
ZOutPoint=stepperZ.currentPosition();
Serial.print("OUT Points set at: ");
Serial.print(XOutPoint);
Serial.println(ZOutPoint);
Serial.println("");
Serial.println("Enter Stepper Travel Speed: ");
Serial.println("OR");
Serial.println("Press Joystick Switch again to Reset IN and OUT Points");
case 2:
Serial.println("");
Serial.println("IN and OUT Points have been Reset...");
Serial.println("");
Serial.println("");
Serial.println("Set IN points for Steppers using the Joystick ");
InandOut=0;
case 3:
Serial.println("");
Serial.println("");
Serial.println("");
InandOut=0;
joystepY=stepperZ.currentPosition(); // Reset Positions
joystepX=stepperX.currentPosition();
stepperX.setMaxSpeed(350.0); // Reset Max Speed of X axis
last_call_interrupt = interrupt_length;
Serial.begin(9600); // Start the Serial monitor with speed of 9600 Bauds
// Print out Instructions on the Serial Monitor at Start
pinMode(JoySwitch, INPUT_PULLUP);
// Set Max Speed and Acceleration of each Steppers
stepperX.setMaxSpeed(350.0); // Set Max Speed of X axis
stepperX.setAcceleration(5000.0); // Acceleration of X axis
stepperZ.setMaxSpeed(150.0); // Set Max Speed of Z axis slower for rotation
stepperZ.setAcceleration(1000.0); // Acceleration of Y axis
// Create instances for MultiStepper
StepperControl.addStepper(stepperX); // Add Stepper #1 to MultiStepper Control
StepperControl.addStepper(stepperZ); // Add Stepper #2 to MultiStepper Control
attachInterrupt (0,joyswitchclick,FALLING); // interrupt 0 always connected to pin 2
while ((InandOut != 2) && (InandOut !=3)) { // Enable moving of steppers using the Joystick
if (analogRead(JoyX) < 200) {
joystepX=joystepX-20; }
if (analogRead(JoyX) > 900) {
joystepX=joystepX+20;
if (analogRead(JoyY) < 200) {
joystepY=joystepY-20; }
if (analogRead(JoyY) > 900) {
joystepY=joystepY+20;
stepperX.moveTo(joystepX);
stepperZ.moveTo(joystepY);
while ((stepperX.distanceToGo() !=0) || (stepperZ.distanceToGo() !=0)) {
stepperX.runSpeedToPosition();
stepperZ.runSpeedToPosition();
if (InandOut == 2) {
while (Serial.available() > 0) { // Check if values are available in the Serial Buffer
int setspeed = Serial.parseInt(); // Read entered Speed from Serial Buffer
if (setspeed > 0) {
stepperX.setMaxSpeed(setspeed);
Serial.println("");
Serial.println("Speed set at: ");
Serial.println(setspeed);
Serial.println("");
Serial.println("Type 'I' to go to the IN points or 'O' to go to the OUT points");
setspeed=0;
InandOut=3;
if (InandOut == 3) {
char checkinput = Serial.read(); // Read Character entered in Serial Monitor
Serial.println(checkinput);
if (checkinput == 'I') { // Move both steppers to IN points
gotoposition[0]=XInPoint;
gotoposition[1]=ZInPoint;
StepperControl.moveTo(gotoposition);
StepperControl.runSpeedToPosition(); // Blocks until all are in position
Serial.println("Steppers are at the IN Position...");
Serial.println("");
if (checkinput == 'O') { // Move both steppers to OUT points
gotoposition[0]=XOutPoint;
gotoposition[1]=ZOutPoint;
Serial.println("Steppers are at the OUT Position...");
Serial.println("");
Rebelstudios:
The Nano uses the same Atmega 328 as the Uno so programs that work on an Uno should work on a Nano. What happens when you use that program on your Nano?
C:\Users\Acer\Documents\Arduino\set_in_en_outpoints_travelspeed\set_in_en_outpoints_travelspeed.ino:13:27: fatal error: AccelStepper.h: No such file or directory
compilation terminated.
exit status 1
Error compiling for board Arduino Nano.
option enabled in File -> Preferences.
Use of quotes around the name implies that it and associated library files are in the same folder as the sketch that #includes them. Is that the case ? If so, why not install the library in the libraries folder of your sketchbook folder to make it available to all sketches using
