C:\Users\Preethi\Documents\Arduino\sketch_apr23a\sketch_apr23a.ino: In function 'uint8_t deleteFingerprint(int)':
sketch_apr23a:743:20: error: control reaches end of non-void function [-Werror=return-type]
743 | display.display();
C:\Users\Preethi\Documents\Arduino\sketch_apr23a\sketch_apr23a.ino: In function 'uint8_t getFingerprintEnroll()':
sketch_apr23a:971:18: error: control reaches end of non-void function [-Werror=return-type]
971 | confirmAdding();
C:\Users\Preethi\Documents\Arduino\sketch_apr23a\sketch_apr23a.ino: In function 'void SendFingerprintID(int)':
sketch_apr23a:604:13: error: call to 'HTTPClient::begin' declared with attribute error: obsolete API, use ::begin(WiFiClient, url)
604 | http.begin(link); //initiate HTTP request, put your Website URL or Your Computer IP
C:\Users\Preethi\Documents\Arduino\sketch_apr23a\sketch_apr23a.ino: In function 'void ChecktoDeleteID()':
sketch_apr23a:716:13: error: call to 'HTTPClient::begin' declared with attribute error: obsolete API, use ::begin(WiFiClient, url)
716 | http.begin(link); //initiate HTTP request, put your Website URL or Your Computer IP
C:\Users\Preethi\Documents\Arduino\sketch_apr23a\sketch_apr23a.ino: In function 'void confirmAdding()':
sketch_apr23a:994:13: error: call to 'HTTPClient::begin' declared with attribute error: obsolete API, use ::begin(WiFiClient, url)
994 | http.begin(link); //initiate HTTP request, put your Website URL or Your Computer IP
C:\Users\Preethi\Documents\Arduino\sketch_apr23a\sketch_apr23a.ino: In function 'void ChecktoAddID()':
sketch_apr23a:790:13: error: call to 'HTTPClient::begin' declared with attribute error: obsolete API, use ::begin(WiFiClient, url)
790 | http.begin(link); //initiate HTTP request, put your Website URL or Your Computer IP
cc1plus.exe: some warnings being treated as errors
Using library SPI at version 1.0 in folder: C:\Users\Preethi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\SPI
Using library Wire at version 1.0 in folder: C:\Users\Preethi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\Wire
Using library ESP8266WiFi at version 1.0 in folder: C:\Users\Preethi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266WiFi
Using library SoftwareSerial at version 8.0.1 in folder: C:\Users\Preethi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\SoftwareSerial
Using library ESP8266WebServer at version 1.0 in folder: C:\Users\Preethi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266WebServer
Using library ESP8266HTTPClient at version 1.2 in folder: C:\Users\Preethi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266HTTPClient
Using library Adafruit_GFX_Library at version 1.11.9 in folder: C:\Users\Preethi\Documents\Arduino\libraries\Adafruit_GFX_Library
Using library Adafruit_BusIO at version 1.15.0 in folder: C:\Users\Preethi\Documents\Arduino\libraries\Adafruit_BusIO
Using library Adafruit_SSD1306 at version 2.5.9 in folder: C:\Users\Preethi\Documents\Arduino\libraries\Adafruit_SSD1306
Using library Adafruit-Fingerprint-Sensor-Library-master at version 2.1.3 in folder: C:\Users\Preethi\Documents\Arduino\libraries\Adafruit-Fingerprint-Sensor-Library-master
exit status 1
//*******************************libraries********************************
#include <SPI.h>
#include <Wire.h>
#include <WiFiClient.h>
#include <ESP8266WiFi.h>
#include <SoftwareSerial.h>
#include <ESP8266WebServer.h>
#include <ESP8266HTTPClient.h>
#include <Adafruit_GFX.h> //https://github.com/adafruit/Adafruit-GFX-Library
#include <Adafruit_SSD1306.h> //https://github.com/adafruit/Adafruit_SSD1306
#include <Adafruit_Fingerprint.h> //https://github.com/adafruit/Adafruit-Fingerprint-Sensor-Library
//Fingerprint scanner Pins
#define Finger_Rx 14 //D5
#define Finger_Tx 12 //D6
// Declaration for SSD1306 display connected using software I2C
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define OLED_RESET 0 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
SoftwareSerial mySerial(Finger_Rx, Finger_Tx);
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
/* Set these to your desired credentials. */
const char *ssid = "SAMSUNGM32"; //ENTER YOUR WIFI SETTINGS
const char *password = "12345678";
String postData ; // post array that will be send to the website
String link = "http://192.168.216.72/biometricattendance/getdata.php"; //computer IP or the server domain
int FingerID = 0; // The Fingerprint ID from the scanner
uint8_t id;
//*************************Biometric Icons*********************************
#define Wifi_start_width 54
#define Wifi_start_height 49
const uint8_t PROGMEM Wifi_start_bits[] = {
0x00,0x00,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x1f,0xf0,0x00,0x00,0x00
,0x00,0x03,0xff,0xff,0x80,0x00,0x00
,0x00,0x1f,0xf0,0x1f,0xf0,0x00,0x00
,0x00,0x7e,0x00,0x00,0xfc,0x00,0x00
,0x01,0xf0,0x00,0x00,0x1f,0x00,0x00
,0x03,0xc0,0x00,0x00,0x07,0xc0,0x00
,0x0f,0x00,0x00,0x00,0x01,0xe0,0x00
,0x1c,0x00,0x00,0x00,0x00,0x70,0x00
,0x38,0x00,0x07,0xc0,0x00,0x38,0x00
,0x70,0x00,0xff,0xfe,0x00,0x1e,0x00
,0xe0,0x03,0xfc,0x7f,0xc0,0x0e,0x00
,0x00,0x1f,0x80,0x03,0xf0,0x00,0x00
,0x00,0x3c,0x00,0x00,0x78,0x00,0x00
,0x00,0xf0,0x00,0x00,0x1c,0x00,0x00
,0x01,0xe0,0x00,0x00,0x0c,0x00,0x00
,0x03,0x80,0x00,0x00,0x00,0x00,0x00
,0x03,0x00,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x3f,0xf8,0x07,0x1e,0x00
,0x00,0x00,0xff,0xfe,0x1f,0xbf,0x80
,0x00,0x03,0xe0,0x04,0x7f,0xff,0xc0
,0x00,0x07,0x80,0x00,0xff,0xff,0xe0
,0x00,0x0e,0x00,0x00,0xff,0xff,0xe0
,0x00,0x0c,0x00,0x00,0x7f,0xff,0xc0
,0x00,0x00,0x00,0x00,0xfe,0x07,0xe0
,0x00,0x00,0x00,0x03,0xf8,0x03,0xf8
,0x00,0x00,0x07,0xe7,0xf9,0xf1,0xfc
,0x00,0x00,0x1f,0xe7,0xf1,0xf9,0xfc
,0x00,0x00,0x1f,0xe7,0xf3,0xf9,0xfc
,0x00,0x00,0x3f,0xe7,0xf3,0xf9,0xfc
,0x00,0x00,0x3f,0xe7,0xf1,0xf1,0xfc
,0x00,0x00,0x3f,0xe3,0xf8,0xe3,0xfc
,0x00,0x00,0x3f,0xf3,0xfc,0x07,0xf8
,0x00,0x00,0x1f,0xf0,0x7f,0x0f,0xc0
,0x00,0x00,0x0f,0xe0,0x7f,0xff,0xe0
,0x00,0x00,0x07,0xc0,0xff,0xff,0xe0
,0x00,0x00,0x00,0x00,0x7f,0xff,0xe0
,0x00,0x00,0x00,0x00,0x3f,0xff,0x80
,0x00,0x00,0x00,0x00,0x1f,0xbf,0x00
,0x00,0x00,0x00,0x00,0x03,0x18,0x00
#define Wifi_connected_width 63
#define Wifi_connected_height 49
const uint8_t PROGMEM Wifi_connected_bits[] = {
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
,0x00,0x00,0x03,0xff,0xff,0x80,0x00,0x00
,0x00,0x00,0x3f,0xff,0xff,0xf8,0x00,0x00
,0x00,0x01,0xff,0xff,0xff,0xff,0x00,0x00
,0x00,0x0f,0xff,0xff,0xff,0xff,0xe0,0x00
,0x00,0x3f,0xff,0xc0,0x07,0xff,0xf8,0x00
,0x00,0xff,0xf8,0x00,0x00,0x3f,0xfe,0x00
,0x03,0xff,0x80,0x00,0x00,0x03,0xff,0x80
,0x07,0xfe,0x00,0x00,0x00,0x00,0xff,0xc0
,0x1f,0xf8,0x00,0x00,0x00,0x00,0x3f,0xf0
,0x3f,0xe0,0x01,0xff,0xff,0x00,0x0f,0xf8
,0x7f,0x80,0x0f,0xff,0xff,0xe0,0x03,0xfc
,0xff,0x00,0x7f,0xff,0xff,0xfc,0x01,0xfe
,0xfc,0x01,0xff,0xff,0xff,0xff,0x00,0x7e
,0x78,0x07,0xff,0xc0,0x07,0xff,0xc0,0x3c
,0x00,0x0f,0xfc,0x00,0x00,0x7f,0xe0,0x00
,0x00,0x1f,0xf0,0x00,0x00,0x1f,0xf0,0x00
,0x00,0x3f,0xc0,0x00,0x00,0x07,0xf8,0x00
,0x00,0x7f,0x00,0x01,0x00,0x01,0xfc,0x00
,0x00,0x7e,0x00,0x7f,0xfc,0x00,0xfc,0x00
,0x00,0x3c,0x03,0xff,0xff,0x80,0x78,0x00
,0x00,0x00,0x07,0xff,0xff,0xc0,0x00,0x00
,0x00,0x00,0x1f,0xff,0xff,0xf0,0x00,0x00
,0x00,0x00,0x3f,0xf0,0x1f,0xf8,0x00,0x00
,0x00,0x00,0x3f,0x80,0x03,0xf8,0x00,0x00
,0x00,0x00,0x3f,0x00,0x01,0xf8,0x00,0x00
,0x00,0x00,0x1c,0x00,0x00,0x70,0x00,0x00
,0x00,0x00,0x00,0x01,0x00,0x00,0x00,0x00
,0x00,0x00,0x00,0x0f,0xe0,0x00,0x00,0x00
,0x00,0x00,0x00,0x1f,0xf0,0x00,0x00,0x00
,0x00,0x00,0x00,0x3f,0xf8,0x00,0x00,0x00
#define FinPr_start_width 64
#define FinPr_start_height 64
const uint8_t PROGMEM FinPr_start_bits[] = {
0x00,0x00,0x00,0x1f,0xe0,0x00,0x00,0x00
,0x00,0x00,0x01,0xff,0xfe,0x00,0x00,0x00
,0x00,0x00,0x0f,0xc0,0x0f,0xe0,0x00,0x00
,0x00,0x00,0x1f,0x00,0x01,0xf8,0x00,0x00
,0x00,0x00,0x3c,0x00,0x00,0x7c,0x00,0x00
,0x00,0x00,0x78,0x00,0x00,0x3e,0x00,0x00
,0x00,0x00,0xf0,0x3f,0xf8,0x0f,0x00,0x00
,0x00,0x01,0xe0,0xff,0xfe,0x07,0x80,0x00
,0x00,0x03,0xc3,0xff,0xff,0x03,0x80,0x00
,0x00,0x03,0x87,0xc0,0x07,0xc3,0xc0,0x00
,0x00,0x07,0x0f,0x00,0x03,0xe1,0xc0,0x00
,0x00,0x0f,0x0e,0x00,0x00,0xe0,0xe0,0x00
,0x00,0x0e,0x1c,0x00,0x00,0xf0,0xe0,0x00
,0x00,0x0c,0x3c,0x1f,0xe0,0x70,0xe0,0x00
,0x00,0x00,0x38,0x3f,0xf0,0x38,0x70,0x00
,0x00,0x00,0x78,0x78,0xf8,0x38,0x70,0x00
,0x00,0x00,0x70,0x70,0x3c,0x18,0x70,0x00
,0x00,0x00,0xe0,0xe0,0x1e,0x1c,0x70,0x00
,0x00,0x03,0xe1,0xe0,0x0e,0x1c,0x70,0x00
,0x00,0x0f,0xc1,0xc3,0x0e,0x1c,0x70,0x00
,0x00,0x3f,0x03,0xc3,0x8e,0x1c,0x70,0x00
,0x00,0x3e,0x03,0x87,0x0e,0x1c,0x70,0x00
,0x00,0x30,0x07,0x07,0x0e,0x18,0xe0,0x00
,0x00,0x00,0x0e,0x0e,0x0e,0x38,0xe0,0x00
,0x00,0x00,0x3e,0x1e,0x1e,0x38,0xe0,0x00
,0x00,0x00,0xf8,0x1c,0x1c,0x38,0xe0,0x00
,0x00,0x03,0xf0,0x38,0x3c,0x38,0xe0,0x00
,0x00,0x3f,0xc0,0xf8,0x78,0x38,0xe0,0x00
,0x00,0x7f,0x01,0xf0,0x70,0x38,0xf0,0x00
,0x00,0x78,0x03,0xe0,0xe0,0x38,0x70,0x00
,0x00,0x00,0x0f,0x81,0xe0,0x38,0x7c,0x00
,0x00,0x00,0x3f,0x03,0xc0,0x38,0x3e,0x00
,0x00,0x00,0xfc,0x0f,0x80,0x38,0x1e,0x00
,0x00,0x07,0xf0,0x1f,0x1c,0x1c,0x04,0x00
,0x00,0x3f,0xc0,0x3e,0x3f,0x1e,0x00,0x00
,0x00,0x7f,0x00,0xf8,0x7f,0x0f,0x00,0x00
,0x00,0x38,0x01,0xf0,0xf7,0x07,0xc0,0x00
,0x00,0x00,0x07,0xe1,0xe3,0x83,0xf8,0x00
,0x00,0x00,0x3f,0x87,0xc3,0xc0,0xfc,0x00
,0x00,0x01,0xfe,0x0f,0x81,0xe0,0x3c,0x00
,0x00,0x0f,0xf8,0x1f,0x00,0xf0,0x00,0x00
,0x00,0x1f,0xc0,0x7c,0x00,0x7c,0x00,0x00
,0x00,0x1e,0x01,0xf8,0x00,0x3f,0x00,0x00
,0x00,0x00,0x07,0xe0,0x78,0x0f,0xc0,0x00
,0x00,0x00,0x3f,0x81,0xfe,0x07,0xf0,0x00
,0x00,0x01,0xfe,0x07,0xff,0x01,0xf0,0x00
,0x00,0x07,0xf8,0x0f,0x87,0x80,0x30,0x00
,0x00,0x07,0xc0,0x3f,0x03,0xe0,0x00,0x00
,0x00,0x06,0x00,0xfc,0x01,0xf8,0x00,0x00
,0x00,0x00,0x03,0xf0,0x00,0x7e,0x00,0x00
,0x00,0x00,0x0f,0xc0,0x00,0x3f,0x80,0x00
,0x00,0x00,0x7f,0x00,0xf8,0x0f,0x80,0x00
,0x00,0x00,0xfc,0x03,0xfe,0x01,0x80,0x00
,0x00,0x00,0xf0,0x1f,0xff,0x80,0x00,0x00
,0x00,0x00,0x00,0x7f,0x07,0xe0,0x00,0x00
,0x00,0x00,0x00,0xfc,0x03,0xf8,0x00,0x00
,0x00,0x00,0x03,0xf0,0x00,0x78,0x00,0x00
,0x00,0x00,0x0f,0xc0,0x00,0x18,0x00,0x00
,0x00,0x00,0x0f,0x01,0xf8,0x00,0x00,0x00
,0x00,0x00,0x00,0x07,0xfe,0x00,0x00,0x00
,0x00,0x00,0x00,0x1f,0xfe,0x00,0x00,0x00
,0x00,0x00,0x00,0x1e,0x0e,0x00,0x00,0x00
,0x00,0x00,0x00,0x18,0x00,0x00,0x00,0x00
#define FinPr_valid_width 64
#define FinPr_valid_height 64
const uint8_t PROGMEM FinPr_valid_bits[] = {
0x00,0x00,0x03,0xfe,0x00,0x00,0x00,0x00
,0x00,0x00,0x1f,0xff,0xe0,0x00,0x00,0x00
,0x00,0x00,0x7f,0xff,0xf8,0x00,0x00,0x00
,0x00,0x00,0xfc,0x00,0xfe,0x00,0x00,0x00
,0x00,0x03,0xe0,0x00,0x1f,0x00,0x00,0x00
,0x00,0x07,0xc0,0x00,0x07,0x80,0x00,0x00
,0x00,0x0f,0x80,0x00,0x03,0xe0,0x00,0x00
,0x00,0x0e,0x03,0xff,0x01,0xe0,0x00,0x00
,0x00,0x1c,0x1f,0xff,0xe0,0xf0,0x00,0x00
,0x00,0x3c,0x3f,0xff,0xf0,0x78,0x00,0x00
,0x00,0x78,0x7c,0x00,0xf8,0x3c,0x00,0x00
,0x00,0x70,0xf0,0x00,0x3c,0x1c,0x00,0x00
,0x00,0xe1,0xe0,0x00,0x1e,0x1c,0x00,0x00
,0x00,0xe1,0xc0,0x00,0x0f,0x0e,0x00,0x00
,0x00,0xc3,0x81,0xfc,0x07,0x0e,0x00,0x00
,0x00,0x03,0x83,0xff,0x07,0x8e,0x00,0x00
,0x00,0x07,0x07,0x8f,0x83,0x87,0x00,0x00
,0x00,0x0f,0x0f,0x03,0xc3,0x87,0x00,0x00
,0x00,0x1e,0x0e,0x01,0xc3,0x87,0x00,0x00
,0x00,0x3c,0x1c,0x00,0xe1,0x87,0x00,0x00
,0x00,0xf8,0x1c,0x30,0xe1,0x87,0x00,0x00
,0x07,0xf0,0x38,0x70,0xe1,0x86,0x00,0x00
,0x07,0xc0,0x78,0x70,0xe3,0x8e,0x00,0x00
,0x02,0x00,0xf0,0xf0,0xe3,0x8e,0x00,0x00
,0x00,0x01,0xe0,0xe0,0xe3,0x8e,0x00,0x00
,0x00,0x03,0xc1,0xe1,0xc3,0x8e,0x00,0x00
,0x00,0x0f,0x83,0xc3,0xc3,0x8e,0x00,0x00
,0x00,0x7f,0x07,0x83,0x83,0x0e,0x00,0x00
,0x07,0xfc,0x0f,0x07,0x83,0x0e,0x00,0x00
,0x07,0xf0,0x1e,0x0f,0x03,0x0e,0x00,0x00
,0x07,0x80,0x7c,0x1e,0x03,0x07,0x00,0x00
,0x00,0x00,0xf8,0x3c,0x03,0x87,0x80,0x00
,0x00,0x03,0xf0,0x78,0x03,0x83,0xc0,0x00
,0x00,0x1f,0xc0,0xf0,0x02,0x00,0x00,0x00
,0x00,0xff,0x01,0xe1,0xc0,0x0c,0x00,0x00
,0x07,0xfc,0x03,0xc3,0xe1,0xff,0xc0,0x00
,0x07,0xe0,0x0f,0x87,0xc7,0xff,0xf0,0x00
,0x07,0x00,0x3f,0x0f,0x0f,0xff,0xfc,0x00
,0x00,0x00,0x7c,0x3e,0x3f,0xff,0xfe,0x00
,0x00,0x03,0xf8,0x7c,0x3f,0xff,0xff,0x00
,0x00,0x1f,0xe0,0xf0,0x7f,0xff,0xff,0x80
,0x00,0xff,0x83,0xe0,0xff,0xff,0xff,0x80
,0x01,0xfc,0x07,0xc1,0xff,0xff,0xe3,0xc0
,0x01,0xe0,0x1f,0x01,0xff,0xff,0xc3,0xc0
,0x00,0x00,0xfe,0x01,0xff,0xff,0x87,0xe0
,0x00,0x03,0xf8,0x13,0xff,0xff,0x0f,0xe0
,0x00,0x1f,0xe0,0x73,0xff,0xfe,0x1f,0xe0
,0x00,0x7f,0x81,0xf3,0xff,0xfc,0x1f,0xe0
,0x00,0xfc,0x03,0xe3,0xef,0xf8,0x3f,0xe0
,0x00,0x60,0x0f,0xc3,0xc7,0xf0,0x7f,0xe0
,0x00,0x00,0x3f,0x03,0xc3,0xe0,0xff,0xe0
,0x00,0x00,0xfc,0x03,0xc1,0xc1,0xff,0xe0
,0x00,0x07,0xf0,0x13,0xe0,0x83,0xff,0xe0
,0x00,0x0f,0xc0,0x7b,0xf8,0x07,0xff,0xe0
,0x00,0x0f,0x01,0xf9,0xfc,0x0f,0xff,0xc0
,0x00,0x00,0x07,0xf1,0xfe,0x1f,0xff,0xc0
,0x00,0x00,0x1f,0xc0,0xff,0x3f,0xff,0x80
,0x00,0x00,0x7e,0x00,0xff,0xff,0xff,0x80
,0x00,0x00,0xfc,0x00,0x7f,0xff,0xff,0x00
,0x00,0x00,0xf0,0x1f,0x3f,0xff,0xfe,0x00
,0x00,0x00,0x00,0x7f,0x1f,0xff,0xfc,0x00
,0x00,0x00,0x01,0xff,0x8f,0xff,0xf8,0x00
,0x00,0x00,0x03,0xe0,0xe3,0xff,0xe0,0x00
,0x00,0x00,0x01,0x80,0x00,0x7f,0x00,0x00
#define FinPr_invalid_width 64
#define FinPr_invalid_height 64
const uint8_t PROGMEM FinPr_invalid_bits[] = {
,0x00,0xff,0x01,0xe1,0xc0,0x00,0x00,0x00
,0x07,0x00,0x3f,0x0f,0x0f,0xff,0xf8,0x00
,0x00,0x00,0x7c,0x3e,0x1f,0xff,0xfe,0x00
,0x00,0x1f,0xe0,0xf0,0x7f,0xff,0xff,0x00
,0x00,0xff,0x83,0xe0,0xfe,0xff,0xbf,0x80
,0x01,0xfc,0x07,0xc0,0xfc,0x7f,0x1f,0xc0
,0x01,0xe0,0x1f,0x01,0xf8,0x3e,0x0f,0xc0
,0x00,0x00,0xfe,0x01,0xf8,0x1c,0x07,0xe0
,0x00,0x03,0xf8,0x13,0xf8,0x00,0x0f,0xe0
,0x00,0x1f,0xe0,0x73,0xfc,0x00,0x1f,0xe0
,0x00,0x7f,0x81,0xf3,0xfe,0x00,0x3f,0xe0
,0x00,0xfc,0x03,0xe3,0xff,0x00,0x7f,0xe0
,0x00,0x60,0x0f,0xc3,0xff,0x80,0xff,0xe0
,0x00,0x00,0x3f,0x03,0xff,0x00,0x7f,0xe0
,0x00,0x00,0xfc,0x03,0xfe,0x00,0x3f,0xe0
,0x00,0x07,0xf0,0x13,0xfc,0x00,0x1f,0xe0
,0x00,0x0f,0xc0,0x79,0xf8,0x08,0x0f,0xe0
,0x00,0x0f,0x01,0xf9,0xf8,0x1c,0x0f,0xc0
,0x00,0x00,0x07,0xf1,0xfc,0x3e,0x1f,0xc0
,0x00,0x00,0x1f,0xc0,0xfe,0x7f,0x3f,0x80
#define FinPr_failed_width 64
#define FinPr_failed_height 64
const uint8_t PROGMEM FinPr_failed_bits[] = {
0x00,0x00,0x3f,0xe0,0x00,0x00,0x00,0x00
,0x00,0x01,0xff,0xfe,0x00,0x00,0x00,0x00
,0x00,0x0f,0xc0,0x1f,0x80,0x00,0x00,0x00
,0x00,0x1e,0x00,0x03,0xc0,0x00,0x00,0x00
,0x00,0x78,0x00,0x00,0xf0,0x00,0x00,0x00
,0x00,0xe0,0x00,0x00,0x38,0x00,0x00,0x00
,0x01,0xc0,0x00,0x00,0x1c,0x00,0x00,0x00
,0x03,0x80,0x00,0x00,0x0e,0x00,0x00,0x00
,0x07,0x00,0x7f,0xe0,0x07,0x00,0x00,0x00
,0x06,0x01,0xff,0xf8,0x03,0x00,0x00,0x00
,0x0c,0x03,0xc0,0x3c,0x03,0x80,0x00,0x00
,0x1c,0x0f,0x00,0x0e,0x01,0x80,0x00,0x00
,0x18,0x0c,0x00,0x03,0x00,0xc0,0x00,0x00
,0x18,0x18,0x00,0x01,0x80,0xc0,0x00,0x00
,0x30,0x38,0x00,0x01,0xc0,0xe0,0x00,0x00
,0x30,0x30,0x0f,0x00,0xc0,0x60,0x00,0x00
,0x30,0x30,0x3f,0xc0,0xe0,0x60,0x00,0x00
,0x70,0x60,0x78,0xe0,0x60,0x60,0x00,0x00
,0x60,0x60,0x60,0x60,0x60,0x70,0x00,0x00
,0x60,0x60,0x60,0x60,0x60,0x30,0x00,0x00
,0x60,0x60,0x60,0x60,0x30,0x30,0x00,0x00
,0x60,0x60,0x60,0x30,0x30,0x20,0x00,0x00
,0x60,0x60,0x60,0x30,0x30,0x01,0xe0,0x00
,0x60,0x60,0x60,0x30,0x30,0x0f,0xfc,0x00
,0x60,0x60,0x60,0x30,0x30,0x3f,0xff,0x00
,0x60,0x60,0x60,0x30,0x18,0x78,0x03,0x80
,0x60,0x60,0x60,0x30,0x1c,0x60,0x01,0x80
,0x60,0x60,0x30,0x38,0x0c,0xc0,0x00,0xc0
,0x00,0x60,0x30,0x18,0x00,0xc0,0x00,0xc0
,0x00,0xe0,0x30,0x0c,0x01,0xc0,0x00,0xe0
,0x00,0xc0,0x18,0x0e,0x01,0xc0,0x00,0xe0
,0x60,0xc0,0x18,0x07,0x01,0xc0,0x00,0xe0
,0x01,0xc0,0x1c,0x03,0x81,0xc0,0x00,0xe0
,0x01,0x80,0x0c,0x01,0xc1,0xc0,0x00,0xe0
,0x03,0x80,0x0e,0x00,0xf1,0xc0,0x00,0xe0
,0x0f,0x00,0x06,0x00,0x01,0xc0,0x00,0xe0
,0x3e,0x01,0x03,0x00,0x01,0xc0,0x00,0xe0
,0x30,0x03,0x83,0x80,0x1f,0xff,0xff,0xfe
,0x00,0x03,0x81,0xc0,0x3f,0xff,0xff,0xff
,0x00,0x07,0xc0,0xe0,0x30,0x00,0x00,0x03
,0x00,0x0e,0xc0,0x78,0x30,0x00,0x00,0x03
,0x00,0x3c,0x60,0x1e,0x30,0x00,0x00,0x03
,0x00,0x78,0x70,0x0f,0x30,0x00,0x00,0x03
,0x03,0xe0,0x38,0x03,0x30,0x00,0x00,0x03
,0x07,0x80,0x1c,0x00,0x30,0x00,0x00,0x03
,0xc0,0x00,0x0f,0x00,0x30,0x00,0x00,0x03
,0xc0,0x00,0x03,0x80,0x30,0x01,0xe0,0x03
,0x00,0x18,0x01,0xe0,0x30,0x03,0xf0,0x03
,0x00,0x18,0x00,0x7c,0x30,0x07,0x38,0x03
,0x00,0x0c,0x00,0x1f,0x30,0x06,0x18,0x03
,0x18,0x0e,0x00,0x07,0x30,0x06,0x18,0x03
,0x0c,0x07,0x80,0x00,0x30,0x07,0x38,0x03
,0x0e,0x03,0xc0,0x00,0x30,0x03,0x30,0x03
,0x07,0x00,0xf0,0x00,0x30,0x03,0x30,0x03
,0x03,0x00,0x7e,0x00,0x30,0x03,0x30,0x03
,0x01,0x80,0x1f,0xc0,0x30,0x03,0x30,0x03
,0x01,0xc0,0x03,0xe1,0x30,0x07,0xf8,0x03
,0x00,0xf0,0x00,0x01,0x30,0x03,0xf0,0x03
,0x00,0x38,0x00,0x00,0x30,0x00,0x00,0x03
,0x00,0x1e,0x00,0x00,0x30,0x00,0x00,0x03
,0x00,0x07,0xc0,0x00,0x30,0x00,0x00,0x03
,0x00,0x01,0xff,0x80,0x3f,0xff,0xff,0xff
,0x00,0x00,0x3f,0x80,0x1f,0xff,0xff,0xfe
#define FinPr_scan_width 64
#define FinPr_scan_height 64
const uint8_t PROGMEM FinPr_scan_bits[] = {
,0x00,0x00,0x00,0x1f,0xf8,0x00,0x00,0x00
,0x00,0x00,0x00,0x7f,0xff,0x00,0x00,0x00
,0x00,0x00,0x01,0xfc,0x7f,0xc0,0x00,0x00
,0x00,0x00,0x03,0xc0,0x03,0xe0,0x00,0x00
,0x00,0x00,0x07,0x80,0x00,0xf0,0x00,0x00
,0x00,0x00,0x0e,0x00,0x00,0x3c,0x00,0x00
,0x00,0x00,0x1c,0x1f,0xfc,0x1c,0x00,0x00
,0x00,0x00,0x38,0x7f,0xfe,0x0e,0x00,0x00
,0x00,0x00,0x78,0xf8,0x0f,0x87,0x00,0x00
,0x00,0x00,0x71,0xe0,0x03,0xc7,0x00,0x00
,0x00,0x00,0xe3,0x80,0x01,0xc3,0x80,0x00
,0x00,0x00,0xc3,0x83,0xc0,0xe3,0x80,0x00
,0x00,0x00,0xc7,0x0f,0xf0,0x71,0x80,0x00
,0x00,0x00,0x06,0x1f,0xf8,0x71,0xc0,0x00
,0x00,0x00,0x0e,0x1c,0x3c,0x31,0xc0,0x00
,0x00,0x00,0x1c,0x38,0x1c,0x31,0xc0,0x00
,0x00,0x00,0x38,0x70,0x0e,0x39,0xc0,0x00
,0x00,0x01,0xf0,0x71,0x8e,0x39,0xc0,0x00
,0x00,0x03,0xe0,0xe1,0x86,0x31,0xc0,0x00
,0x00,0x03,0x81,0xe3,0x8e,0x31,0x80,0x00
,0x00,0x00,0x03,0xc3,0x8e,0x33,0x80,0x00
,0x00,0x00,0x07,0x87,0x0c,0x73,0x80,0x00
,0x00,0x00,0x1f,0x0e,0x1c,0x73,0x80,0x00
,0x7f,0xff,0xff,0xff,0xff,0xff,0xff,0xfe
,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff
,0x00,0x03,0xf0,0x1e,0x3e,0x1c,0x00,0x00
,0x00,0x03,0x80,0x7c,0x77,0x0f,0x00,0x00
,0x00,0x00,0x01,0xf0,0xe3,0x07,0xc0,0x00
,0x00,0x00,0x07,0xe3,0xc3,0x81,0xf0,0x00
,0x00,0x00,0x3f,0x87,0x81,0xc0,0x60,0x00
,0x00,0x01,0xfc,0x1f,0x00,0xf0,0x00,0x00
,0x00,0x01,0xe0,0x3c,0x00,0x7c,0x00,0x00
,0x00,0x00,0x00,0xf8,0x78,0x1f,0x00,0x00
,0x00,0x00,0x07,0xe0,0xfc,0x0f,0xc0,0x00
,0x00,0x00,0x3f,0x83,0xef,0x03,0xc0,0x00
,0x00,0x00,0xfc,0x0f,0x87,0x80,0x00,0x00
,0x00,0x00,0x70,0x1f,0x03,0xe0,0x00,0x00
,0x00,0x00,0x00,0x7c,0x00,0xf8,0x00,0x00
,0x00,0x00,0x01,0xf0,0x00,0x3e,0x00,0x00
,0x00,0x00,0x0f,0xc0,0xf8,0x0f,0x00,0x00
,0x00,0x00,0x1f,0x03,0xfe,0x02,0x00,0x00
,0x00,0x00,0x0c,0x0f,0x8f,0x80,0x00,0x00
,0x00,0x00,0x00,0x3f,0x03,0xe0,0x00,0x00
,0x00,0x00,0x00,0xf8,0x00,0xf0,0x00,0x00
,0x00,0x00,0x01,0xe0,0x00,0x30,0x00,0x00
,0x00,0x00,0x01,0xc0,0xf8,0x00,0x00,0x00
,0x00,0x00,0x00,0x0f,0x8e,0x00,0x00,0x00
,0x00,0x00,0x00,0x06,0x00,0x00,0x00,0x00
//-----------initiate OLED display-------------
// SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
Serial.println(F("SSD1306 allocation failed"));
for(;;); // Don't proceed, loop forever
// Show initial display buffer contents on the screen --
// the library initializes this with an Adafruit splash screen.
// you can delet these three lines if you don't want to get the Adfruit logo appear
display.display();
delay(2000); // Pause for 2 seconds
display.clearDisplay();
connectToWiFi();
// set the data rate for the sensor serial port
finger.begin(57600);
Serial.println("\n\nAdafruit finger detect test");
if (finger.verifyPassword()) {
Serial.println("Found fingerprint sensor!");
display.drawBitmap( 34, 0, FinPr_valid_bits, FinPr_valid_width, FinPr_valid_height, WHITE);
display.display();
Serial.println("Did not find fingerprint sensor :(");
display.drawBitmap( 32, 0, FinPr_failed_bits, FinPr_failed_width, FinPr_failed_height, WHITE);
display.display();
while (1) { delay(1); }
finger.getTemplateCount();
Serial.print("Sensor contains "); Serial.print(finger.templateCount); Serial.println(" templates");
Serial.println("Waiting for valid finger...");
//------------*test the connection*------------
//SendFingerprintID( FingerID );
//check if there's a connection to WiFi or not
if(WiFi.status() != WL_CONNECTED){
connectToWiFi();
//If there no fingerprint has been scanned return -1 or -2 if there an error or 0 if there nothing, The ID start form 1 to 127
FingerID = getFingerprintID(); // Get the Fingerprint ID from the Scanner
delay(50); //don't need to run this at full speed.
DisplayFingerprintID();
ChecktoAddID();
ChecktoDeleteID();
//************Display the fingerprint ID state on the OLED*************
void DisplayFingerprintID(){
//Fingerprint has been detected
if (FingerID > 0){
display.display();
SendFingerprintID( FingerID ); // Send the Fingerprint ID to the website.
//No finger detected
else if (FingerID == 0){
display.drawBitmap( 32, 0, FinPr_start_bits, FinPr_start_width, FinPr_start_height, WHITE);
display.display();
//Didn't find a match
else if (FingerID == -1){
display.drawBitmap( 34, 0, FinPr_invalid_bits, FinPr_invalid_width, FinPr_invalid_height, WHITE);
display.display();
//Didn't find the scanner or there an error
else if (FingerID == -2){
display.display();
//************send the fingerprint ID to the website*************
void SendFingerprintID( int finger ){
HTTPClient http; //Declare object of class HTTPClient
//Post Data
postData = "FingerID=" + String(finger); // Add the Fingerprint ID to the Post array in order to send it
// Post methode
http.addHeader("Content-Type", "application/x-www-form-urlencoded"); //Specify content-type header
int httpCode = http.POST(postData); //Send the request
String payload = http.getString(); //Get the response payload
Serial.println(httpCode); //Print HTTP return code
Serial.println(payload); //Print request response payload
Serial.println(postData); //Post Data
Serial.println(finger); //Print fingerprint ID
if (payload.substring(0, 5) == "login") {
String user_name = payload.substring(5);
// Serial.println(user_name);
display.setTextSize(2); // Normal 2:2 pixel scale
display.setTextColor(WHITE); // Draw white text
display.setCursor(15,0); // Start at top-left corner
display.print(F("Welcome"));
display.setCursor(0,20);
display.print(user_name);
display.display();
else if (payload.substring(0, 6) == "logout") {
String user_name = payload.substring(6);
display.setCursor(10,0); // Start at top-left corner
display.print(F("Good Bye"));
display.display();
postData = "";
http.end(); //Close connection
//********************Get the Fingerprint ID******************
int getFingerprintID() {
uint8_t p = finger.getImage();
switch (p) {
case FINGERPRINT_OK:
//Serial.println("Image taken");
case FINGERPRINT_NOFINGER:
//Serial.println("No finger detected");
return 0;
case FINGERPRINT_PACKETRECIEVEERR:
//Serial.println("Communication error");
return -2;
case FINGERPRINT_IMAGEFAIL:
//Serial.println("Imaging error");
return -2;
default:
//Serial.println("Unknown error");
return -2;
// OK success!
p = finger.image2Tz();
switch (p) {
//Serial.println("Image converted");
case FINGERPRINT_IMAGEMESS:
//Serial.println("Image too messy");
return -1;
return -2;
case FINGERPRINT_FEATUREFAIL:
//Serial.println("Could not find fingerprint features");
return -2;
case FINGERPRINT_INVALIDIMAGE:
return -2;
default:
return -2;
// OK converted!
p = finger.fingerFastSearch();
if (p == FINGERPRINT_OK) {
//Serial.println("Found a print match!");
} else if (p == FINGERPRINT_PACKETRECIEVEERR) {
return -2;
} else if (p == FINGERPRINT_NOTFOUND) {
//Serial.println("Did not find a match");
return -1;
return -2;
// found a match!
//Serial.print("Found ID #"); Serial.print(finger.fingerID);
//Serial.print(" with confidence of "); Serial.println(finger.confidence);
return finger.fingerID;
//******************Check if there a Fingerprint ID to delete******************
void ChecktoDeleteID(){
//Post Data
postData = "DeleteID=check"; // Add the Fingerprint ID to the Post array in order to send it
// Post methode
if (payload.substring(0, 6) == "del-id") {
String del_id = payload.substring(6);
Serial.println(del_id);
deleteFingerprint( del_id.toInt() );
//******************Delete Finpgerprint ID*****************
uint8_t deleteFingerprint( int id) {
uint8_t p = -1;
p = finger.deleteModel(id);
//Serial.println("Deleted!");
display.setCursor(0,0); // Start at top-left corner
display.print(F("Deleted!\n"));
display.display();
display.setTextSize(1); // Normal 1:1 pixel scale
display.print(F("Communication error!\n"));
display.display();
return p;
} else if (p == FINGERPRINT_BADLOCATION) {
//Serial.println("Could not delete in that location");
display.print(F("Could not delete in that location!\n"));
display.display();
return p;
} else if (p == FINGERPRINT_FLASHERR) {
//Serial.println("Error writing to flash");
display.print(F("Error writing to flash!\n"));
display.display();
return p;
//Serial.print("Unknown error: 0x"); Serial.println(p, HEX);
display.print(F("Unknown error:\n"));
display.display();
return p;
//******************Check if there a Fingerprint ID to add******************
void ChecktoAddID(){
//Post Data
postData = "Get_Fingerid=get_id"; // Add the Fingerprint ID to the Post array in order to send it
// Post methode
if (payload.substring(0, 6) == "add-id") {
String add_id = payload.substring(6);
Serial.println(add_id);
id = add_id.toInt();
getFingerprintEnroll();
//******************Enroll a Finpgerprint ID*****************
uint8_t getFingerprintEnroll() {
int p = -1;
display.drawBitmap( 34, 0, FinPr_scan_bits, FinPr_scan_width, FinPr_scan_height, WHITE);
display.display();
while (p != FINGERPRINT_OK) {
switch (p) {
display.display();
//Serial.println(".");
display.setTextSize(1); // Normal 2:2 pixel scale
display.print(F("scanning"));
display.display();
display.display();
default:
// OK success!
p = finger.image2Tz(1);
switch (p) {
display.display();
display.display();
return p;
return p;
return p;
return p;
default:
return p;
display.print(F("Remove"));
display.print(F("finger"));
display.display();
//Serial.println("Remove finger");
delay(2000);
p = 0;
while (p != FINGERPRINT_NOFINGER) {
Serial.print("ID "); Serial.println(id);
p = -1;
display.display();
switch (p) {
display.display();
display.display();
default:
// OK success!
p = finger.image2Tz(2);
switch (p) {
display.display();
return p;
return p;
return p;
return p;
default:
return p;
// OK converted!
Serial.print("Creating model for #"); Serial.println(id);
p = finger.createModel();
//Serial.println("Prints matched!");
display.display();
return p;
} else if (p == FINGERPRINT_ENROLLMISMATCH) {
Serial.println("Fingerprints did not match");
return p;
return p;
p = finger.storeModel(id);
//Serial.println("Stored!");
display.display();
confirmAdding();
return p;
Serial.println("Could not store in that location");
return p;
return p;
return p;
void confirmAdding(){
//Post Data
postData = "confirm_id=" + String(id); // Add the Fingerprint ID to the Post array in order to send it
// Post methode
display.setTextSize(1.5); // Normal 1:1 pixel scale
display.print(payload);
display.display();
//********************connect to the WiFi******************
void connectToWiFi(){
WiFi.mode(WIFI_OFF); //Prevents reconnection issue (taking too long to connect)
WiFi.mode(WIFI_STA);
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
display.setCursor(0, 0); // Start at top-left corner
display.print(F("Connecting to \n"));
display.setCursor(0, 50);
display.print(ssid);
display.drawBitmap( 73, 10, Wifi_start_bits, Wifi_start_width, Wifi_start_height, WHITE);
display.display();
Serial.print(".");
Serial.println("");
Serial.println("Connected");
display.setTextSize(2); // Normal 1:1 pixel scale
display.setCursor(8, 0); // Start at top-left corner
display.print(F("Connected \n"));
display.drawBitmap( 33, 15, Wifi_connected_bits, Wifi_connected_width, Wifi_connected_height, WHITE);
display.display();
Serial.print("IP address: ");
Serial.println(WiFi.localIP()); //IP address assigned to your ESP
