Hello everyone. Here i want to ask some question. How to communicate an arduino with the relay using a single push button. Please please help me.. I am a new here.
Thank you.
Thank you.
What have you tried?
Hint: posting the same question multiple times pisses people off. Don't do it
const int proxswitchPin = 2; // the number of the pushbutton pin
const int airval1 = 4; // the number of Plunger valve 1 pin
const int airval2 = 7; // the number of Part release after plunger valve 2 pin
const int airval3 = 8; // the number of Part release into plunger valve 3 pin
// variables will change:
int proxswitchState = 0; // variable for reading the pushbutton status
pinMode(airval1, OUTPUT); // initialize airval1 pin as output
pinMode(airval2, OUTPUT); // initialize airval2 pin as output
pinMode(airval3, OUTPUT); // initialize airval3 pin as output
// initialize the pushbutton pin as an input:
pinMode(proxswitchPin, INPUT);
// read the state of the pushbutton value:
proxswitchState = digitalRead(proxswitchPin);
// check if the pushbutton is pressed.
// if it is, the buttonState is HIGH:
if (proxswitchState == HIGH) {
delay(100); // Delay to make sure part is in write position before assembly
digitalWrite(airval3, HIGH); // Bring cylinder up to hold second part in line in place while first one drops
digitalWrite(airval1, HIGH); // Activate Plunger
delay(50); // Delay to make sure plunger goes all the way down
digitalWrite(airval1, LOW); // Bring plunger back up
digitalWrite(airval2, HIGH); // Open gate for part to fall off chute
delay(500); // Delay to make sure part has time to fall
digitalWrite(airval2, LOW); // Close gate after part falls
delay(00); // Delay after part drop off chute to make sure gate is closed
digitalWrite(airval3, LOW); // release part to get assembled
else {
digitalWrite(airval2, LOW); // Leave gate open for parts to fall into plunger area
digitalWrite(airval3, LOW); // Leave gate closed so parts stop in plunger area
I'm already try this source code, but it not function properly.
Another thing that pisses people off is noobs who think the posting guidelines don't apply to them.
It hasn't been a good start, has it?
This code looks very familiar. Have you previously posted a query about counting the number of times the proximity switch detects an item and stopping when it reaches 101 ?
If you want to use a relay and a push button, why in you're code I see 3 air valves (not relays) ad a proximity switch (not push button)?
So, or tell use exactly what you want to do, NOT what you think you need to do. Or make a simple example that indeed DOES what you ask use and learn from that. But I think the first is the best for now.
Also, use code tags!
