Hi
I want to make an automatic watering system for my plant. I have build all the hardware, but now i need help to the code. So, i want it to turn the relay on for 5 seconds every 6 hours. Well that is simple enough. But i also want to turn the relay on with a IR remote. The thing is that if i use the delay command it pauses the entire code and i want it to search for inputs at the same time. So, what should i do?
Plz. help! I have been searching around and i haven't found any good results.
Use CTRL T to format your code.
Attach your ‘complete’ sketch between code tags, use the </> icon in the posting menu. [code]Paste your sketch here[/code]
Hi
I dont have a code to insert. That is what i need. I have a schematic of my wiring and i have a picture of my wiring. (dont know if the relay is wired properly in the diagram.)
