control relays though android app
I am using this board with 2ch relays
![](http://C:\Users\sajtb\Desktop\New folder\2re3.jpg)
to control it, i am using android app called esp2relay controller
the problem is that when i am using this app, there is no current state status, which means i dont know if relay is turned on or off
when i tried to use any other app i couldnt control relays...which app and what command should i send through it to get relays work
thanks
Ah yes, that thing!
I think to promote discussion, you need to cite the Web reference to the module in question and its operating manuals. It did appear in a recent discussion but I have lost track of it as I did not consider it worthwhile - and too expensive.
I suspect to provide the functionality you want, you would have to re-flash the on-board PIC microcontroller. Which is not related to "Arduino". :astonished:
Incidentally, "http://C:\Users\sajtb\Desktop\New folder\2re3.jpg" is not a useful URL to display your image. :roll_eyes:
i just want to use another app instead of esp2relay controller.... iwith this application and right ip adress relays is working but when i type this ip to some other app on android, it wont work... i need to write command, i tried in hex like A10001A2 or similar but it wont reacted....
the problem is that in this application you cannot see if the relay is on or off when you log in to app... thats why i am searching for app in which is possible to see the state of any relay
