So I’m trying to make a rainbow effect with the RGB LED when I press the number 1 on my remote, but it doesn’t work. It keeps freezing at a certain colour, and after some time the led jumps to a different colour. The code was working when I made just the code for the rainbow effect without the IR remote and that works perfectly fine. I don’t know what is causing the problem. Any help would be appreciated. I’m a noob btw.
#include <IRremote.h>
int red = 255;
int green = 255;
int blue = 255;
int redPin = 11;
int greenPin = 10;
int bluePin = 9;
int r = 0;
int g = 0;
int b = 0;
int msSpeed = 50; // milli seconds
const int REC_PIN = 7;
IRrecv irrecv(REC_PIN);
decode_results results;
unsigned long key_value = 0;
const int rainbow = 1;
int loopThis = 0;
pinMode(redPin, OUTPUT);
pinMode(greenPin, OUTPUT);
pinMode(bluePin, OUTPUT);
irrecv.enableIRIn();
irrecv.blink13(true);
start:
if (irrecv.decode(&results)){
if (results.value == 0XFFFFFFFF)
results.value = key_value;
switch(results.value){
case 0x9716BE3F: // 1 on the remote
if((red == 255) && (green == 255) && (blue == 255)) {
green = 0;
blue = 0;
loopThis = rainbow;
case 0x3D9AE3F7: // 2 on the rmote
loopThis = 0;
red = 255;
green = 255;
blue = 255;
RGB(red, green, blue);
delay(50);
key_value = results.value;
irrecv.resume();
switch(loopThis){
case rainbow:
if((red == 255) && (green == 0) && (blue == 0)) {
b = 0;
g = 1;
if((red == 255) && (green == 255) && (blue == 0)) {
g = 0;
r = -1;
if((red == 0) && (green == 255) && (blue == 0)) {
r = 0;
b = 1;
if((red == 0) && (green == 255) && (blue == 255)) {
b = 0;
g = -1;
if((red == 0) && (green == 0) && (blue == 255)) {
g = 0;
r = 1;
if((red == 255) && (green == 0) && (blue == 255)) {
r = 0;
b = -1;
red = red + r;
green = green + g;
blue = blue + b;
delay(msSpeed);
goto start;
void RGB(int redValue, int greenValue, int blueValue) {
analogWrite(redPin, redValue);
analogWrite(greenPin, greenValue);
analogWrite(bluePin, blueValue);
I’ve also found that if I set all the RGB values to 254 instead of 255, the colour of the RGB LED is light blue. I’ve also tried with a couple of RGB LEDs, but the problem doesn’t go away.
