Control servo from serial port
I don’t understand why my servo will only execute once.
It’s like it locks into the first posision I type and wont move.
This is my code:
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
int val;    // variable to read the value from the analog pin
Serial.begin(9600); // set serial speed
 myservo.attach(10);
myservo.write(90);
while (Serial.available() == 0); // do nothing if nothing sent
int val = Serial.read() - '0'; // deduct ascii value of '0' to find numeric value of sent number
val = map(val, 0, 1023, 0, 179);
if (val == 180) { // test for command 1 then turn on LED
 myservo.write(val);
 delay(50);
if (val == 0) // test for command 0 then turn off LED
 myservo.write(val);
else // if not one of above command, do nothing
Serial.println(val);
//Serial.flush(); // clear serial port
First to send the string "180" is at least 3 chars you need to get all the chars in the number. You also need a delimiter, something to tell you you have the whole string. That way you can tell the difference between 18 and 180.
Second drop the while it's pointless use
if (serial.available()>0){
  code to deal with the chars.
Third don't re-declare var's in the way you have for the int val and lookup "scope".
Mark
Servo test code.
//zoomkat 11-22-12 simple delimited ',' string parse
//from serial port input (via serial monitor)
//and print result out serial port
//multi servos added
String readString;
#include <Servo.h>
Servo myservoa, myservob, myservoc, myservod;  // create servo object to control a servo
  //myservoa.writeMicroseconds(1500); //set initial servo position if desired
  myservoa.attach(6);  //the pin for the servoa control
  myservob.attach(7);  //the pin for the servob control
  myservoc.attach(8);  //the pin for the servoc control
  myservod.attach(9);  //the pin for the servod control
  Serial.println("multi-servo-delimit-test-dual-input-11-22-12"); // so I can keep track of what is loaded
  //expect single strings like 700a, or 1500c, or 2000d,
  //or like 30c, or 90a, or 180d,
  //or 30c,180b,70a,120d,
  if (Serial.available())  {
    char c = Serial.read();  //gets one byte from serial buffer
    if (c == ',') {
      if (readString.length() >1) {
        Serial.println(readString); //prints string to serial port out
        int n = readString.toInt();  //convert readString into a number
        // auto select appropriate value, copied from someone elses code.
        if(n >= 500)
          Serial.print("writing Microseconds: ");
          Serial.println(n);
          if(readString.indexOf('a') >0) myservoa.writeMicroseconds(n);
          if(readString.indexOf('b') >0) myservob.writeMicroseconds(n);
          if(readString.indexOf('c') >0) myservoc.writeMicroseconds(n);
          if(readString.indexOf('d') >0) myservod.writeMicroseconds(n);
          Serial.print("writing Angle: ");
          Serial.println(n);
          if(readString.indexOf('a') >0) myservoa.write(n);
          if(readString.indexOf('b') >0) myservob.write(n);
          if(readString.indexOf('c') >0) myservoc.write(n);
          if(readString.indexOf('d') >0) myservod.write(n);
         readString=""; //clears variable for new input
    else {
      readString += c; //makes the string readString
