Hi everyone
I need to control my servo motor using limit switch
when the limit switch is pressed the motor should stop. The limit switch is connected to CN
Can anyone help me with that please?
Hi everyone
So what is the problem?
Jomana_A:
connected to CN
CN?
But since a servo's position can be controlled, why don't you just let it approach the finish position one degree at a time, and make a note of the correct number. Then code that number into the sketch and tell it to go there.
arduino_new:
I need help with the code
I tried several codes but non of them worked
Jomana_A:
What code have you tried? "Doesn't work" is not a problem.
neiklot:
CN?But since a servo's position can be controlled, why don't you just let it approach the finish position one degree at a time, and make a note of the correct number. Then code that number into the sketch and tell it to go there.
yes that can be done but I should use a limit switch
CN = normally opened
Jomana_A:
Well something like this should work, assuming myServo is attach()-ed and you have a variable for the position, say myServoPos...
First put the normally open switch from a pin say limitSwitchPin to ground and:
pinMode(limitSwitchPin, INPUT_PULLUP);
Then:
while (digitalRead(limitSwitchPin)== HIGH) //unpressed
myServoPos++;
if (myServoPos > 175) myServoPos=175; //in case it's running right near the end of its travel
myServo.write(myServoPos);
Btw, what's supposed to happen next? Presumably something will happen that encourages the servo to go back the other way?
Jomana_A:
What sort of servo motor?
In the Arduino world servo usually means one of these
However there are also industrial servos that behave similarly to stepper motors.
...R
