Hello Every one;
I am new in arduino and i have project to make an robotic arm;
we have created every thing but we have an problem with the programming , we wnnt to controol our arm using blutooth or with joystick at the same time
what i mean , that if blutooth send a value we will control it with Blutooth , if not it will be controled using joystick moudle
but i does not work just the blutooth is working , the code is below if can any one help.
I am Using arduino Uno with KY-023 and HC-06 and 4 x Servo , 1 potenmater to set the speed.
Thank you.
// @Author TAU:Muhammed El Ibrhaim;
// Die liberiry, die wie es benuzen werden
#include <Arduino.h>
#include <Servo.h>
#include <SoftwareSerial.h>
#include <math.h>
// PIN-Definition
#define S1PIN 10
#define S2PIN 11
#define S3PIN 12
#define S4PIN 13
#define Joy_Y A0
#define Joy_X A1
#define Joy_B A2
#define PotM A3
#define L1 200 // Test
#define W1 150 // Test
#define bthRX 3
#define bthTX 2
#define MAX_SAngle 90
#define MAX_Speed 10
#define MIN_Speed 2000
#define MAX_Distance 350
// Varibalen und device definition
SoftwareSerial bth( bthTX , bthRX ); // Arduino RX , TX
Servo S1 , S2 , S3 , S4;
String com;
int S1POS , S2POS , S3POS , S4POS;
int S1PPOS , S2PPOS , S3PPOS , S4PPOS;
float angle1 , angle2 , angle3;
int Joy_X_Val , Joy_Y_Val , Joy_B_Val ;
int delay_val = 20;
float Distance = 0.00;
int joy = 0;
boolean states = false;
// wenn Atduion ist zu erste dingen die gemacht werden
S1.attach(S1PIN);
S1PPOS = S1.read();
S2.attach(S2PIN);
S2PPOS = S2.read();
S3.attach(S3PIN);
S3PPOS = S3.read();
S4.attach(S4PIN);
S4PPOS = S4.read();
pinMode (Joy_X, INPUT);
pinMode (Joy_Y, INPUT);
pinMode (Joy_B, INPUT);
pinMode (PotM , INPUT);
digitalWrite(Joy_B , HIGH);
bth.begin(38400);
//Unser Robot funktonen
Joy_X_Val = analogRead(Joy_X);
Joy_Y_Val = analogRead(Joy_Y);
Joy_B_Val = analogRead(Joy_B);
delay_val = analogRead(PotM);
com = bth.readString();
if(bth.available() >= 0){
if(com.startsWith("s1")){ // Z servo
String CMD = com.substring(2 ,com.length());
S1POS = CMD.toInt();
if(S1POS > S1PPOS){
for(int i = S1PPOS ; i < S1POS ; i++){
S1.write(i);
delay(delay_val);
if(S1POS < S1PPOS){
for(int i = S1PPOS ; i > S1POS ; i--){
S1.write(i);
delay(delay_val);
S1PPOS = S1POS;
if(com.startsWith("s2")){ // X servo
S2POS = CMD.toInt();
if(S2POS > S2PPOS){
for(int i = S2PPOS ; i < S2POS ; i++){
S2.write(i);
delay(delay_val);
if(S2POS < S2PPOS){
for(int i = S2PPOS ; i > S2POS ; i--){
S2.write(i);
delay(delay_val);
S2PPOS = S2POS;
if(com.startsWith("s3")){ // Rotation Servo , Y servo
S3POS = CMD.toInt();
if(S3POS > S3PPOS){
for(int i = S3PPOS ; i < S3POS ; i++){
S2.write(i);
delay(delay_val);
if(S3POS < S3PPOS){
for(int i = S3PPOS ; i > S3POS ; i--){
S3.write(i);
delay(delay_val);
S3PPOS = S3POS;
if(com.startsWith("s4")){ // Gripper Servo
if(S4POS > S4PPOS){
for(int i = S4PPOS ; i < S4POS ; i++){
S4.write(i);
delay(delay_val);
if(S4POS < S4PPOS){
for(int i = S4PPOS ; i > S4POS ; i--){
S2.write(i);
delay(delay_val);
S4PPOS = S4POS;
if(com.startsWith("speed")){ // Die Geschwindeigkeit des Servo
delay_val = com.substring(5 , com.length()).toInt();
// Control with Joystick KY-04
if(bth.available() <= 0){
angle1 = ((90 - S1POS ) * PI) / 180;
angle2 = ((90 - S2POS ) * PI) / 180;
Joy_X_Val = map(Joy_X_Val , 0 , 1023 , 180 , 0);
Joy_Y_Val = map(Joy_Y_Val , 0 , 1023 , 180 , 0);
Joy_B_Val = map(Joy_B_Val , 0 , 1023 , 0 , 500);
delay_val = map(delay_val, 0 , 1023 , 20 , 70);
if(Joy_X_Val > 95 ){
delay(delay_val);
if(Joy_Y_Val > 95 && S3PPOS < 180){
S3PPOS++;
S3.write(S3POS);
delay(delay_val);
if(Joy_X_Val < 95){
delay(delay_val);
if(Joy_Y_Val < 95 && S3PPOS > 0 ) {
S3PPOS--;
S3.write(S3POS);
delay(delay_val);
if(Joy_B_Val < 10 && S4PPOS > 90){
S4PPOS--;
S4.write(S4PPOS);
delay(20);
}else if(S4PPOS < 90) {
S4PPOS++;
S4.write(S4PPOS);
delay(20);
