Control Servo With VB 2010 Problem
Hi, i want to make servo position control with VB 2010. For first try, i want to control servo between 0 - 100 degrees. In VB 2010 i use trackbar to control servo, and i setting the trackbar value between 0 and 10. So, 1 trackbar value represent 10 degree of servo movement. When i tried the system, it works, but there is a problem, the system will works well if the trackbar value ranged between 0 - 9. When i move trackbar value to 10, the servo must be move to 100 degree, but it goes wrong, the servo move to 0 degree, looks like arduino read the trackbar value is 0 not 10.
Then i do other experiment, and the conclusion is arduino only execute trackbar value between 0 and 9. When it between 10-19, or 20 and 29, and so on, arduino will read it as 0 - 9.
Well, how to solve this problem?
Thank you
this is my Arduino Code:
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
int val,pos;
  myservo.attach(A0);  // attaches the servo on pin 9 to the servo object
  Serial.begin(115200); //begins serial communication
  serialControl();
  myservo.write(val);
void serialControl() {
  if (Serial.available()){
    delay(100);
    while(Serial.available()>0){
    pos=int(Serial.read());     //reads the value sent from Visual Basic
      if(pos=='0')
        val=0;   //rotates the servo 0 degrees
      else if(pos=='1')
        val=10;
      else if(pos=='2')
        val=20;
      else if(pos=='3')
        val=30;
      else if(pos=='4')
        val=40;
      else if(pos=='5')
        val=50;
      else if(pos=='6')
        val=60;
      else if(pos=='7')
        val=70;
      else if(pos=='8')
        val=80;
      else if(pos=='9')
        val=90;
      else if(pos== '10')
        val=100;
And this is my VB 2010 Code:
Imports System.IO
Imports System.IO.Ports
Imports System.Threading
Public Class Form1
    Shared _continue As Boolean
    Shared _serialPort As SerialPort
    Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        SerialPort1.Close()
        SerialPort1.PortName = "com18" 'you need to check which com port your arduino is using, and change them if you need
        SerialPort1.BaudRate = 115200
        SerialPort1.DataBits = 8
        SerialPort1.Parity = Parity.None
        SerialPort1.StopBits = StopBits.One
        SerialPort1.Handshake = Handshake.None
        SerialPort1.Encoding = System.Text.Encoding.Default
    End Sub
    Private Sub Label1_Click(sender As System.Object, e As System.EventArgs) Handles Label1.Click
    End Sub
    Private Sub TrackBar1_Scroll(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles TrackBar1.Scroll
        SerialPort1.Open()
        SerialPort1.Write(TrackBar1.Value)
        SerialPort1.Close()
        TextBox1.Text = TrackBar1.Value
    End Sub
    Private Sub TextBox1_TextChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles TextBox1.TextChanged
    End Sub
End Class
 else if(pos== '10')
You can't transmit and receive two characters like that - you need to form them into a string.
This question comes up every other day here in some form or another.
The problem is, your code receives a '1', moves the servo to 10 degrees,then very shortly after (less time than a servo frame), it receives the '0' and moves the servo to 0 degrees.
If you have a slider, you are converting the slider value to a string to send to the Arduino. Stop doing that. Send the value as a (binary) value. Then, you can read the servo position as a single value (from 0 to 255).
