Good afternoon,
I'm building a project with a lot of eight relay. But I came up with the following problem: one of the relays is to control a fan, in which when I execute a command it will work for X seconds, but while it works I like to control the rest of the relays. The problem is that if I use the delay, the arduino blocks and does not let me do anything else in those x seconds. I tried to use the "millis ()" function but it just tells me the current time. And the fan does not turn itself off automatically! BELOW THE CODE:
//name of ports
int valv1=2;
int valv2=3;
int valv3=4;
int valv4=5;
int valv5=6;
int valv6=7;
int valv7=8;
int fan=9;
unsigned long previousTime=5000;
unsigned long interval=0;
pinMode(valv1, OUTPUT);
pinMode(valv2, OUTPUT);
pinMode(valv3, OUTPUT);
pinMode(valv4, OUTPUT);
pinMode(valv5, OUTPUT);
pinMode(valv6, OUTPUT);
pinMode(valv7, OUTPUT);
pinMode(fan, OUTPUT);
//Close Relays
digitalWrite(valv1, HIGH);
digitalWrite(valv2, HIGH);
digitalWrite(valv3, HIGH);
digitalWrite(valv4, HIGH);
digitalWrite(valv5, HIGH);
digitalWrite(valv6, HIGH);
digitalWrite(valv7, HIGH);
digitalWrite(fan, HIGH);
int valor2 = digitalRead(valv2);
int valor3 = digitalRead(valv3);
int valor4 = digitalRead(valv4);
int valor5 = digitalRead(valv5);
int valor6 = digitalRead(valv6);
int valor7 = digitalRead(valv7);
int valuefan = digitalRead(fan);
String opc;
opc=Serial.readString();
if(opc == "ov1"){
digitalWrite(valv1, LOW);
Serial.println("Valvula 1 Aberta");
if (opc == "ov2")
digitalWrite(valv2, LOW);
Serial.println("Valvula 2 aberta");
if (opc == "ov3")
digitalWrite(valv3, LOW);
Serial.println("Valvula 3 aberta");
if (opc == "ov4")
digitalWrite(valv4, LOW);
Serial.println("Valvula 4 aberta");
if (opc =="ov5")
digitalWrite(valv5, LOW);
Serial.println("Valvula 5 aberta");
if (opc =="ov6")
digitalWrite(valv6, LOW);
Serial.println("Valvula 6 aberta");
if (opc =="ov7")
digitalWrite(valv7, LOW);
Serial.println("Valvula 7 aberta");
//open fan
if (opc =="fan")
unsigned long currentTime= millis();
if(currentTime - previousTime > interval) {
previousTime = currentTime;
if (valuefan == HIGH) {
valuefan = LOW;
Serial.println("fan open");
else {
valuefan = HIGH;
digitalWrite(fan, valuefan);
Thanks!!!
