Control speed of 220 VAC Motor with digital potentiometer?
Hi everyone,
My goal is to control the speed of a motor (connected to a fan) to control the exhaust temperature of a wood burning
I read a lot of articles about controlling AC motor with triac/opto but all of these solution involve to built the AC "shield" and i'm not confortable to play with 220VAC.
Currently my motor is controlled manually by a voltage dimmer connected to a rotary poteniometer.
something like that:
http://fr.aliexpress.com/item/1Pc-2000W-220V-Dimming-Dimmers-Thermostat-SCR-Speed-Controller-Voltage-Regulator-Newest/32555242468.html
I would like to know if it is possible to replace the rotaty dimmer by a digital potentiometer controlled by i2c.
Thanks you
ksartor:
Yes - that should be possible, provided your digital pot has the same ohm range as the physical pot. The only possible problem might be that the load of the digipot and the load of the physical pot are different enough to upset the operation of the rest of the circuit in the dimmer - in which case it won't likely work right. But - if you think you can hook it up to try it, it is certainly worth a shot.
Before you attempt this, what kind of AC motor do you have? If its an induction or synchronous
motor then it simply may not be suitable for speed control at all (and your current method of
control could cause it to overheat or even catch fire).
Ok, but is there any digital potentiometer which can do that?
Because all digital potentiometer work at about 5-15VDC and in my case it is 220V AC...
Concerning my AC motor, i don't know, how can i know that?
Because the Motor/fan is in the chimney. But i can unmount the actual controller and take pictures (perhaps this controller is dedicated to a determined AC motor type)
Is the "actual controller" one that was supplied with the motor by the manufacturer? If so, a model number or link to a product web page would help.
Here are two pictures of the module:
Well it appears to be a standard triac circuit, which suggests the motor is a universal motor, or
perhaps a low power torque-motor, which can be power/speed controlled this way.
The point about induction motors is that they need voltage and frequency to be scaled together
to control speed, which requires a V/f inverter-based controller. Standard induction motors overheat
if abused. Synchronous motors depend on the line frequency as they are locked to it.
I'd check what circuit the controller is actually using - checkout the active device part number if
it has one to make sure its a triac fro instance.
Ok, thanks.
But in this case, do you think it will be possible to replace the potentiometer by a digital potentiometer to control it by arduino?
Not if its running at mains voltages, which it probably is - as I said figure out the existing controller
circuit to see what it is.
Digitial pots require that the signals are within the 0V -- Vcc range at all times. They are not available
for high voltages or high currents, they are for analog signal handling only.
The black piece is a triac 2N6075
Maybe a servo to turn the existing mechanical pot. Might be an electrically safer thing to do.
zoomkat:
I thought that it could be a possibility but i'm trying to find a solution without mecanical parts.
I understand the digital potentiometer is not possible but i think some electronic solutions would be available...
Yes, but not with that circuit - you'd normally use an opto-isolated circuit to measure
zero-crossing time and trigger the triac after a programmable delay.
In the existing circuit an RC circuit using the pot is creating a variable delay directly
at high voltages.
In this case (opto circuit), is there a module to buy to do this?
In all cases, thank you for the advices.
Perhaps something like this would work: AC Phase Control
Just a note re induction motors and variable speed:
An induction motor is inherently a fixed speed or near fixed speed machine when run at its nameplate speed, frequency and voltage. When driving a fan, however It can be (and has been) run at reduced variable voltage and nameplate frequency to get a reasonably wide range of speed control. This is possible because the fan load torque falls off rapidly as the speed is reduced and so the motor current is reduced enough to save it from burning up. Of course the power factor and efficiency are very poor in this mode.
In using it this way you almost have to do a case by case examination of the motor and fan speed-torque curves to make sure the motor does not burn up and the speed stays more or less under control.
This was used more in the past when nothing better was available; now there are several well designed alternatives so I see little reason to use it this way
Phoxx
