control stepper motor over internet using G-code and Ethernet shilled
I need to control stepper motor via internet with help of Ethernet shilled.I need to send G code through Ethernet shield to arduino. I search internet about this title but there is nothing much. is there anyone who knows how to do this.?
There are two completely separate issues in your question. {A} sending data using an Ethernet shield (GCode is just text). And {B} interpreting GCode so as to control a stepper motor.
If you describe the project you are trying to implement it will be much easier to help.
How many stepper motors do you need to control? If (as your title implies) there is only 1 motor I wonder if GCode is overkill.
...R
i am trying to make cnc plotter. so 2 steppers for X and Y axis and 1 servo for z axis.
Have you looked at the GRBL program? It can probably do most of what you want. But I don’t think it works with Ethernet.
…R
yes.i know how to work with GRBL and CNC but i need control via internet Ethernet. isnt there any way to do this? is that possible to read G code via internet . i mean send each Gcode lines as serial via internet to the arduino?so that arduino can read each line and operate accordingly??
There should be no trouble sending text (GCode) using Ethernet - though I have no experience of Ethernet myself. The complication is integrating that with GRBL. I don't think modifying the GRBL program is a practical option unless you are a very experienced programmer.
Two options occur to me.
{A} Write a program that receives the GCode using Ethernet and then extend it with your own GCode interpreter rather than using GRBL.
{B} Write a program for a second Arduino to receive the GCode using Ethernet and then send it on unchanged via Serial to the Arduino that is running GRBL.
...R
There won't be enough RAM to add ethernet chip handling to GRBL on on Uno. On a Mega maybe. Probably
a good deal easier to use one Arduino to talk ethernet and send serial to the GRBL one.
is it possible to read the content of Web page unlikely reading URL(In web switch).so that i could use a webpage and print Gcode on that page?
pereraangelo:
I think you need to re-read that and re-write it so that it makes sense. What is the purpose of the word "unlikely" ?
if you are asking if an Arduino could read a web page and get CGode from it and then send the GCode to another Arduino then {A} why didn't you say so and {B} the answer is possibly.
Why don't you explain why you need to use Ethernet in the first place.
...R
