I am trying to control a stepper motor with Arduino DUE and Ethernet Shield. My idea is to use the arduino as a stand alone device, to log on to and control the stepper. So far I have managed to start, stop and change the direction of the motor. The next challenge I have, is to pass an exact number of steps to the stepper.
void loop(){
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
if (readString.length() < 100) {
readString += c;
//Serial.print(c);
if (c == '\n') {
Serial.println(readString);
client.println("Content-Type: text/html");
client.println();
client.println("<HTML>");
client.println("<BODY>");
client.println("<a href=/?on1 >FORWARD</a>");
client.println("<a href=/?on2 >BACKWARD</a>");
client.println("
client.println("<a href=/?off3 >OFF</a>");
client.println("</BODY>");
client.println("</HTML>");
delay(1);
client.stop();
if(readString.indexOf('1') >0)
dir = 1;
if(readString.indexOf('2') >0)//checks for 2
dir = 2;
if(readString.indexOf('3') >0)//checks for 3
dir = 0;
readString="";
My idea is to add a text field and a submit button, but I am not sure how to get the value from POST or GET methods.
You could use a text box web page like below to send what ever number you want to the server. Find the location of the first = in readString, Save the rest of readString from that point, take the int value of that readString, and you would have captured the number you sent.
//zoomkat 12-08-12
//get submit box code
//for use with IDE 1.0
//open serial monitor to see what the arduino receives
//use the \ slash to escape the " in the html or use a '
//address will look like http://192.168.1.102:84 when submited
//for use with W5100 based ethernet shields
//note that the below bug fix may be required
// http://code.google.com/p/arduino/issues/detail?id=605
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 102 }; // ip in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(84);; //server port
String readString;
void setup(){
pinMode(5, OUTPUT); //pin selected to control
//start Ethernet
Ethernet.begin(mac, ip, gateway, gateway, subnet);
server.begin();
//enable serial data print
Serial.println("server text box test1"); // so I can keep track of what is loaded
void loop(){
// Create a client connection
if (client) {
//read char by char HTTP request
//store characters to string
readString += c;
//Serial.print(c);
//if HTTP request has ended
if (c == '\n') {
Serial.println(readString); //see what was captured
//now output HTML data header
client.println();
client.println("<HEAD>");
client.println("<TITLE>Arduino GET test page</TITLE>");
client.println("</HEAD>");
client.println("<H1>HTML form GET example</H1>");
client.println("<FORM ACTION='/' method=get >"); //uses IP/port of web page
client.println("Pin 5 'on5' or 'off5': <INPUT TYPE=TEXT NAME='LED' VALUE='' SIZE='25' MAXLENGTH='50'>
client.println("<INPUT TYPE=SUBMIT NAME='submit' VALUE='Change Pin 5!'>");
client.println("</FORM>");
client.println("
delay(1);
//stopping client
client.stop();
if(readString.indexOf("on5") >0)//checks for on
digitalWrite(5, HIGH); // set pin 5 high
Serial.println("Led On");
if(readString.indexOf("off5") >0)//checks for off
digitalWrite(5, LOW); // set pin 5 low
Serial.println("Led Off");
//clearing string for next read
readString="";
An alternative approach would be to use pfodApp (www.pfod.com.au) and control the stepper from your Android mobile.
The advantage of pfodApp is the input screens are already built for you. You just open them on the mobile using very simple text commands sent from your Arduino. (You can optionally add 128bit security without using a lot of memory on your Arduino)
