I'm pretty new to arduino and processing, but I want to control a stepper motor using a computer keyboard. What I had in mind is when I press down a button such as "right button" then the motor would turn to the right and keep moving till I press up, or when I press "left button" then the motor would move to the left until I press up.I searched for this idea and all what I got is for the servo motor. Can anyone help me with the schismatic of the idea and the code?
There's a bunch of posts discussing how to do that on the forum but I don't remember where they are. You'll just have to search on the forum.
You didn't mention whether your driver uses STEP/DIR or IN1,IN2,IN3,IN4 signals. We would need to know that.
You'll need to use a different terminal program than the one included with the IDE. The Arduino terminal requires you to use the "enter" key to send text to the Arduino.
That's a good point. I didn't even think of that. I made a custom keyboard for my Senior Project at DeVry. I found a very expensive all metal custom ATE keyboard at a surplus store for $50 . It had a round CANON plug on the end and output TTL serial so I added a UART to convert the serial to parallel
and changed the connector to a parallel connector. I then added an EEPROM addressed by the parallel output of the UART. I then made a list of every value (in HEX) sent by every key. I created a memory-mapped I/O for the EEPROM by storing the standard ASCII value I wanted at the addresses (key values) sent by the keyboard. Since it was a multi thousand dollar custom keyboard with groups of different colored keys, the values sent were not always the ascii values I expected and there were many more keys than a standard keyboard. By creating a memory map of the keys, I could store the desired value in the address sent by the keyboard and thus was able to convert a group of custom ascii values sent in serial to a standard set of values sent in parallel. I admit it was probably more work than it was worth
but I wanted the "WOW" factor that the keyboard evoked when you saw it. It was like "holy crap ! will you look at that keyboard ! It looks like something from WAR GAMES !".. ;D
Take a look at this sketch.
It reads the keyboard and looks for "f" [FORWARD]
or
"F" [REVERSE]
byte directionPin1 = 7;
// byte directionPin2 = 4;
// byte directionPin3 = 6;
// byte directionPin4 = 8;
// byte directionPin5 = 10;
// byte directionPin6 = 12;
byte stepPin1 = 8;
// byte stepPin2 = 5;
// byte stepPin3 = 7;
// byte stepPin4 = 9;
// byte stepPin5 = 11;
// byte stepPin6 = 13;
int numberOfSteps = 5000;
byte ledPin = 14;
int pulseWidthMicros = 50; // microseconds
int millisbetweenSteps = 10; // milliseconds
for (int pins = 1; pins < 13; pins++)
pinMode(pins, OUTPUT);
if (Serial.available() > 0)
int inByte = Serial.read();
switch (inByte)
case 'f': {
Serial.println("Starting Stepper Motor 1 CW");
digitalWrite(ledPin, LOW);
delay(1);
pinMode(directionPin1, OUTPUT);
pinMode(stepPin1, OUTPUT);
pinMode(ledPin, OUTPUT);
digitalWrite(directionPin1, HIGH);
for(int n = 0; n < numberOfSteps; n++)
digitalWrite(stepPin1, HIGH);
delayMicroseconds(pulseWidthMicros);
digitalWrite(stepPin1, LOW);
delay(millisbetweenSteps);
digitalWrite(ledPin, !digitalRead(ledPin));
delay(100);
case 'F': {
Serial.println("Starting Stepper Motor 1 CCW");
delay(1);
digitalWrite(directionPin1, LOW);
delay(100);
default: {
I try not to challenge solutions proposed by others, but the code in Reply #4 uses delay() and that is completely unsuitable if the Arduino is to be responsive to button messages coming from the PC.
There needs to be a function that causes the stepper to move according to th value in a variable. Something like this pseudo code
if (cmdVar == 'F' ) {
direction = forward;
moveOneStep());
else if (cmdVar == 'R') {
direction = reverse;
moveOneStep();
and there needs to be a separate function that recieves data from the PC and updates the contents of cmdVar. See Serial Input Basics
It would probably be easier from the user's perspective to write a PC program to detect the key presses and send suitable messages to the Arduino.
You do NOT want to send a continuous stream of 'F's when the F key is pressed. You just want to send a message when the key is first pressed and another message when the key is released.
...R
