I apologize, I should have kept it in the same thread... and I should have posted the entire code set. For some reason I thought it was be less... "clutter".
Here is the complete code for my program.
I also formatted the code like you said... thank you for that input. I am only trying to work on the items inside the runWithButton(); under the void loop.
In regards to your commends about speed... I am calling out for two separate speeds and I honestly thought it was easier to just call out the values I wanted under the void runWithButton() area.
#include <AccelStepper.h>
#include <AFMotor.h>
#define encoderPinA 3
#define encoderPinB 2
#define button 0
#define buttontwo 1
int encoderPos = 0;
int encoderPinALast = LOW;
int encoderPinBLast = LOW;
int n = LOW;
int potpin = A0;
int val;
int lightpin = A1;
int lightpintwo = A2;
int initialReading;
int initialReadingtwo;
AF_Stepper motor2(200, 2);
// wrappers for the motor! SINGLE is default, can also use INTERLEAVE DOUBLE MICROSTEP
void forwardstep2() {
motor2.onestep(BACKWARD, INTERLEAVE);
void backwardstep2() {
motor2.onestep(FORWARD, INTERLEAVE);
// Motor shield has two motor ports, now we'll wrap them in an AccelStepper object
AccelStepper stepper2(forwardstep2, backwardstep2);
stepper2.setMaxSpeed(1000.0);
stepper2.setAcceleration(100.0);
stepper2.moveTo(0);
pinMode(encoderPinA, INPUT_PULLUP);
pinMode(encoderPinB, INPUT_PULLUP);
pinMode(button, INPUT);
pinMode(buttontwo, INPUT);
initialReading = analogRead(lightpin);
initialReading = analogRead(lightpintwo);
runWithEncoder();
runWithButton();
runWithButtontwo();
void runWithEncoder()
n = digitalRead(encoderPinA);
if ((encoderPinALast != n )) {
if (((n == HIGH) && (digitalRead(encoderPinB) == LOW)) ||
((n == LOW) && (digitalRead(encoderPinB) == HIGH))) {
motor2.step(1, BACKWARD, INTERLEAVE);
motor2.step(1, FORWARD, INTERLEAVE);
n = digitalRead(encoderPinB);
if ((encoderPinBLast != n )) {
if (((n == HIGH) && (digitalRead(encoderPinA) == LOW)) ||
((n == LOW) && (digitalRead(encoderPinA) == HIGH))) {
encoderPinALast = digitalRead(encoderPinA);
encoderPinBLast = digitalRead(encoderPinB);
if(digitalRead(button) == LOW) while (analogRead(lightpin) > (initialReading + 100))
stepper2.setSpeed(500);
stepper2.runSpeed();
if(digitalRead(button) == LOW) while (analogRead(lightpintwo) < (initialReadingtwo + 100))
stepper2.setSpeed(18);
void runWithButtontwo()
val = analogRead(potpin);
val = map(val, 0, 1024, 1, 600);
if(digitalRead(buttontwo) == LOW)
stepper2.setSpeed(val);
The code in Reply #3 has the same problem that I commented on in Reply #2
And you haven't commented on your decision to use WHILE (which seems to me to be the problem)
Maybe the second IF should be if(digitalRead(button) == HIGH)
If none of my suggestions solves the problem I think you need to write down very carefully in plain language (not code) exactly what you want to happen.
I've looked at your video and I can't say it added much to my knowledge - perhaps because it does not show the stepper motor.
If I understand correctly you want two options that don't interfere with each other.
On the one hand you want to be able to press a button (briefly) and cause the motor to move all the way as far as the point where a photodetector is tripped. You have a second button that causes the same action but in the opposite direction. Either of these buttons can leave the motor in any position between the two limits, or at one or other of the limits.
On the other hand you have a rotary encoder which you want to be able to rotate manually and have the motor move step-by-step as the encoder moves.
When using the encoder what is supposed to happen if the motor is already at one of the limits? I don't see any reference to the limits in the encoder function.
What happens if you comment-out the calls to the button functions? Does the encoder function then work properly?
I have to say that I don't immediately see why the encoder function won't work automatically after the motor has come to a stop following a button press.
I think I mentioned before that it would be better to take the actual movement code into a function of its own that is called by both the encoder function and the button functions. That way you would have only a single piece of motor code and the problem might be more obvious.
Another thought ... you don't make use of the absolute position of the motor. In most cases the limit switch is used to detect the zero position and all movements after that are done by telling the motor to move by a certain number of steps to some other specific position. For example a limit switch at the other end would be unnecessary because that end would be defined as (eg) step number 2765.
There is no need for any limit switch for positional data.
I am working on making a 2nd video here... I didn't show any of the material in the 1st video because I am still waiting on parts.
Its connected to a powder tickler which only needs to be rotated in one direction (everything (buttons) moves it clockwise) you can move it counter clockwise using the rotary encoder but its not like that does anything for my setup.
The photosensors will be attached to a beam balance scale...
The bottom sensor will be obstructed by default like I mentioned in the video.
The button moves the tickler at a fast speed and the moment it starts to move, it stops per the video.
Pressing the button again will make it move at the slower speed.
The "high" sensor which moves at a slower speed, stops when tripped.
The extra button and rotary encoder are just there if you wanted manual control over the process.
Per the video, the automated process needs to be pressed twice in order for it to be completed. I wanted to automatically move from fast trickle to a slow trickle without used intervention.
I hope that helps, if not, stand by for a 2nd video which would hopefully clarify everything.
