I have had some issues with a ATmega32U4 board (Arduino Pro Micro) essentially getting ‘bricked’ after programming it, I think it always happened when using the control surface library. By bricking I mean it doesn’t do what it is programmed to do and it completely stops from showing up when connected over USB. The only way to save it is to use another external board to rewrite the bootloader. (This is annoying as the board is soldered into a circuit).
I assumed that my board was faulty and got a bunch of new ATmega32U4 boards (Pro Micro and Leonardo). But the exact same thing happens to all of them. I’ve found a simple example where this happens:
(WARNING: THIS CODE MIGHT CORRUPT YOUR BOOTLOADER)
#include <Control_Surface.h>
USBMIDI_Interface midi;
using namespace MIDI_Notes;
AnalogMultiplex<3> mux = {
A3,
{2, 3, 4},
6,
AnalogMultiplex<3> mux2 = {
A3,
{2, 3, 4},
7,
NoteButton button[] = {
{mux.pin(7), MCU::MUTE_1},
{mux.pin(6), MCU::SOLO_1},
{mux.pin(5), MCU::MUTE_2},
{mux.pin(4), MCU::SOLO_2},
{mux.pin(3), MCU::MUTE_3},
{mux.pin(2), MCU::SOLO_3},
{mux.pin(1), MCU::MUTE_4},
{mux.pin(0), MCU::SOLO_4},
{mux2.pin(1), MCU::PLAY},
{mux2.pin(4), MCU::STOP},
{mux2.pin(5), MCU::REWIND},
{mux2.pin(8), MCU::FAST_FWD},
{mux2.pin(7), MCU::RECORD},
Control_Surface.begin();
Control_Surface.loop()
However, the following code does not have this problem:
A3,
{2, 3, 4},
6,
A3,
{2, 3, 4},
7,
{mux.pin(7), {note(C, 4)-7, CHANNEL_1}},
{mux.pin(6), {note(C, 4)-6, CHANNEL_1}},
{mux.pin(5), {note(C, 4)-5, CHANNEL_1}},
{mux.pin(4), {note(C, 4)-4, CHANNEL_1}},
{mux.pin(3), {note(C, 4)-3, CHANNEL_1}},
{mux.pin(2), {note(C, 4)-2, CHANNEL_1}},
{mux.pin(1), {note(C, 4)-1, CHANNEL_1}},
{mux.pin(0), {note(C, 4), CHANNEL_1}},
{mux2.pin(7), {note(C, 5), CHANNEL_1}},
{mux2.pin(6), {note(C, 5), CHANNEL_1}},
{mux2.pin(5), {note(C, 5), CHANNEL_1}},
{mux2.pin(4), {note(C, 5), CHANNEL_1}},
{mux2.pin(3), {note(C, 5), CHANNEL_1}},
{mux2.pin(2), {note(C, 5), CHANNEL_1}},
{mux2.pin(1), {note(C, 5), CHANNEL_1}},
{mux2.pin(0), {note(C, 5), CHANNEL_1}},
Does anybody know why this happens?
