Control temperature room centrifugal fans & Belimo actuators with 4 temp sensors
Hello,
A friend told me to use your product for my needs.
I have to control the temperature in a 25,000sqft room. I want 4 temperature sensors in the room, average of the 4 sensors will be used to control everything. 1 temperature sensor for the outside just for reference. I need a LCD touchscreen.
Already installed:
  • Inlet centrifugal fan for fresh air from outside
  • Exhaust centrifugal fan with 2 exits for the hot air, 1 to heat the rest of the building, 1 to send air outside of the building, each with 1 damper controlled with Belimo actuator.
  • Automation control panel on the wall to control everything. 120v relays for the fans, 24v relays for the actuators, etc. (currently controlled with regular switches)
I need to be able to:
  • send the hot air in an other room of the builduing OR outside of the building.
  • manually control each fan with a touchscreen button
  • see the temperature of each sensors on the lcd screen
I have some basis in programmation, and I'm electrician.
Can someone help me to build a nice kit, and build the base code?
Thank you!
The rest is more or less just relays. I would guess that you would need a sensor in the other room.
