Since I am newbie in Arduino and C/C++ programming language (I studied mostly Pascal and HTML/JavaScript in high school and only a couple of classes of C/C++ ), I humbly ask for your advice.
So, I'll leave here the code I wrote for this application that requires an input number "x" in Serial Monitor, by which the LED (the yellow Led in my case) will blink "x" times when button A is pressed. For example, if I type "4" in the Serial Monitor, the led will blink 4 times when I press the button.
Here's the code:
#define buttonA 14
#define LedYellow 13
int blinkingtimes = 0;
pinMode(LedYellow, OUTPUT);
pinMode(buttonA, INPUT);
int statusButtonA = 0;
statusButtonA = digitalRead(buttonA);
if (statusButtonA = HIGH){
Serial.print("Introduce the on-off commutation number of the yellow LED ");
if(Serial.available() > 0){
blinkingtimes = Serial.read();
while (blinkingtimes > 0){
digitalWrite(LedYellow, HIGH);
blinkingtimes = blinkingtimes - 1;
Thank you in advance!
Have a great week ahead!
