Control the speed of RC 540
Hello guys,
I am trying to do a Ping Pong Machine. I have a motor RC 540-20T (RPM @ 7.2V : 20000 +10% , la 2Amp;) because I need a powerful one to throw the ball.
I tried to control to speed with L298, but it doesn't work. The motor just vibrates, like it seems to be under voltage. I also tried to connect the module to a 12V battery, but the problem persisted.
Do you have any idea what type of driver should I use for this type of motor?
Best regards,
Daniel
How about an RC ESC?
I wasn't sure if that is the answer and I wanted to be sure before I ll buy it.
Do I have to follow some specifications when I but it? To be sure that it is compatible with my motor?
A normal 20 turn 540 is an RC car brushed motor intended to run on 6 NiCd cells (7.2V). 2A will be the no-load current. Under normal loads current can easily get over 20A. An L298 is no use for that.
What battery are you using? 12V is a bit high but the motor should run provided your battery can supply enough current.
If you only need it to run in one direction a MOSFET will do to control it. If you need forward/reverse then an RC car ESC will be easiest (I'd go for 30A to be safe and check that it does have reverse, not all ESCs do).
Steve
have you try using l293d dc motor shield?
