Control Uno "dimmer" example from OS X terminal
Hello everyone,
I am very new to hardware however not new to programming so writing simple programs and understanding it all is no big deal, but i ran into a problem.
Is there any way to communicate with this program (send bytes) through the computer terminal?
Whenever I try with the built in communicator I cannot send just bytes to the device.
Any help would be appreciated!
you could start with
ARDUINO 1.0
FILE / EXAMPLES / COMMUNICATION / DIMMER
if you need more options for commands from TERMINAL
pls see a small MENU system
with setpoint input example
( but no dimmer code )
one character input menu
can start
ONE SHOT JOB or CONTI JOBs ( semiparallel )
menu_kll_v08.zip (5.88 KB)
kllsamui: you could start with ARDUINO 1.0 FILE / EXAMPLES / COMMUNICATION / DIMMER
if you need more options for commands from TERMINAL pls see a small MENU system with setpoint input example ( but no dimmer code ) one character input menu can start ONE SHOT JOB or CONTI JOBs ( semiparallel )
Yeah, I was already in that example..
anyway, I figured it out, so far using the command (in terminal)
echo "\xff" > /dev/tty.DEVICEID
to turn it on or
echo "\x00\c" > /dev/tty.DEVICEID
to turn it off
however, this only works when I open the serial communicator in the IDE first..
