I want to control a little 1027 vibration motor with a gy-521 but it doesn't work. I had a code
and tried to modify it but as I just said it doesn't work
#include <SPI.h>
#include <Wire.h>
#include <Servo.h>
const int MPU_addr=0x68;
using namespace std;
Servo ServoX, ServoY, ServoZ;
double AcX,AcY,AcZ,Tmp,GyX,GyY,GyZ;
double aX,DaX,aY,DaY,aZ,DaZ,RealDX,RealDY,RealDZ;
short LS11 = 0;
short LS15 = 0;
short LS21 = 0;
short LS25 = 0;
short LS31 = 0;
short LS35 = 0;
short LS41 = 0;
short LS45 = 0;
short AntrLin = 0;
short AntrRec = 0;
short ReinVor = 0;
short ReinHin = 0;
void setup(){
Wire.begin();
Wire.beginTransmission(MPU_addr);
Wire.write(0x6B); // PWR_MGMT_1 register
Wire.write(0); // set to zero (wakes up the MPU-6050)
Wire.endTransmission(true);
void mpu(){
Wire.write(0x3B); // starting with register 0x3B (ACCEL_XOUT_H)
Wire.endTransmission(false);
Wire.requestFrom(MPU_addr,14,true); // request a total of 14 registers
AcX=Wire.read()<<8|Wire.read(); // 0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
AcY=Wire.read()<<8|Wire.read(); // 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
AcZ=Wire.read()<<8|Wire.read(); // 0x3F (ACCEL_ZOUT_H) & 0x40 (ACCEL_ZOUT_L)
Tmp=Wire.read()<<8|Wire.read(); // 0x41 (TEMP_OUT_H) & 0x42 (TEMP_OUT_L)
GyX=Wire.read()<<8|Wire.read(); // 0x43 (GYRO_XOUT_H) & 0x44 (GYRO_XOUT_L)
GyY=Wire.read()<<8|Wire.read(); // 0x45 (GYRO_YOUT_H) & 0x46 (GYRO_YOUT_L)
GyZ=Wire.read()<<8|Wire.read(); // 0x47 (GYRO_ZOUT_H) & 0x48 (GYRO_ZOUT_L)
aX=AcX/16384;
if (aX > 1){
aX = 1;
if (aX < -1){
aX = -1;
DaX=asin(aX);
RealDX = DaX * 180/PI;
aY=AcY/16384;
if (aY > 1){
aY = 1;
if (aY < -1){
aY = -1;
DaY=asin(aY);
RealDY = DaY * 180/PI;
aZ=AcZ/16384;
if (aZ > 1){
aZ = 1;
if (aZ < -1){
aZ = -1;
DaZ=asin(aZ);
RealDZ = DaZ * 180/PI;
void start(){
return 0;
mpu();
Serial.print("RealD X = ");Serial.print(RealDX);
Serial.print(" | RealD Y = ");Serial.print(RealDY);
Serial.print(" | RealD Z = ");Serial.println(RealDZ);
delay(700);
and I'm getting frustrated please help``
