Control volume and mouse scroll wheel using arduion leo (rotatory encoder)
Board - Arduino leo
Encoder - ky40
I want to do a project in which I control the volume and mouse scroll wheel using Arduino Leonardo and a rotatory encoder. but somehow volume feature is working but the scroll wheel is not.
Here is my code
#include <HID-Project.h>
#include <HID-Settings.h>
// Rotary Encoder Inputs
const int pinA = 2; // CLK
const int pinB = 3; // DT
const int buttonPin = 4; // SW
int lastStateCLK;
int currentStateCLK;
int lastButtonState = HIGH;
int currentButtonState;
  pinMode(pinA, INPUT);
  pinMode(pinB, INPUT);
  pinMode(buttonPin, INPUT_PULLUP);
  Consumer.begin(); // Start the Consumer device emulation
  lastStateCLK = digitalRead(pinA);
  currentStateCLK = digitalRead(pinA);
  // If the state has changed, a pulse occurred
  if (currentStateCLK != lastStateCLK) {
    // Determine the rotation direction
    if (digitalRead(pinB) != currentStateCLK) {
      // Encoder rotated clockwise
      Consumer.write(MEDIA_VOLUME_UP);
      // Encoder rotated counterclockwise
      Consumer.write(MEDIA_VOLUME_DOWN);
  lastStateCLK = currentStateCLK;
  // Check for button press to control mouse scroll
  currentButtonState = digitalRead(buttonPin);
  if (currentButtonState != lastButtonState) {
    if (currentButtonState == LOW) {
      // Button pressed, scroll up
      AbsoluteMouse.move(0, 0, 1);
      // Button released, scroll down
      AbsoluteMouse.move(0, 0, -1);
    lastButtonState = currentButtonState;
Won't this simply scroll up one line when you press the button and then scroll down one line when you release the button?
How did you want this to work?
Perhaps you want it to work like this:
int lastStateCLK;
        // scroll up
        // scroll down
for example - when I rotate the encoder clockwise, the mouse scrolls up work, and in anti-clockwise motion scrolls down work.
I hope you get what I am trying to say.
What about the volume up/down?
How do you want the encoder to control both volume and scroll?
I want to use the Rotatory encoder in two ways, change between these two options using the button (switch)
First - volume control (worked)
Second - Mouse scroll wheel (not working)
Note - I am not able to figure out why the mouse scroll is not working where whereas volume control works fine without any issue.
Because what you described is not what your code is doing. Your code says to scroll up one line when button is pressed and down one line when button is released. Not very useful. Your code does not say that scrolling should happen when the encoder is rotated.
Did you try my suggested code?
yup, the same problem I tried your code, and the volume control worked but the mouse scroll was not working.
Can you write a specific code for the mouse scroll wheel?
I try to chat GPT, the copilot version of code but none of them working
Did you try holding the button down and turning the encoder at the same time?
yes, I try holding but not worked
I get this when i upload code in my arduino, why there is no mouse.h (is this could be the reason)
In file included from c:\users\prabh-pc\documents\arduino\libraries\hid-project\src\hid-apis\KeyboardAPI.h:29:0, from c:\users\prabh-pc\documents\arduino\libraries\hid-project\src\hid-apis\defaultkeyboardapi.h:27, from C:\Users\Prabh-PC\Documents\Arduino\libraries\HID-Project\src/SingleReport/BootKeyboard.h:30, from C:\Users\Prabh-PC\Documents\Arduino\libraries\HID-Project\src/HID-Project.h:50, from C:\Users\Prabh-PC\Documents\sketch_jun10b\sketch_jun10b.ino:1: c:\users\prabh-pc\documents\arduino\libraries\hid-project\src\keyboardlayouts\improvedkeylayouts.h:54:21: note: #pragma message: Using default ASCII layout for keyboard modules #pragma message "Using default ASCII layout for keyboard modules" ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
Is there an example sketch with that library which demonstrates mouse scrolling? Have you tried it?
when I tried to move the mouse with the joystick module, again it didn't work. I think its a problem with the mouse library because the keyboard library works fine.
The mouse library simply says to use Mouse.move(x-axis, y-axis, Scroll_value to control any mouse movement.
Note - I didn't find any useful resource to solve this issue.
But you used
Maybe that's the problem. It is scrolling to absolute positions +1 or -1.
I tried all values which could work.
Share your latest code.
Now I am trying to achive same goal(Mouse control) with joystick module but not working
Here is the code in which i am using joystick
/* HID Joystick Mouse Example
   by: Jim Lindblom
   date: 1/12/2012
   license: MIT License - Feel free to use this code for any purpose.
   No restrictions. Just keep this license if you go on to use this
   code in your future endeavors! Reuse and share.
   This is very simplistic code that allows you to turn the
   SparkFun Thumb Joystick (http://www.sparkfun.com/products/9032)
   into an HID Mouse. The select button on the joystick is set up
   as the mouse left click.
#include <Mouse.h>
int horzPin = A0;  // Analog output of horizontal joystick pin
int vertPin = A1;  // Analog output of vertical joystick pin
int selPin = 9;  // select button pin of joystick
int vertZero, horzZero;  // Stores the initial value of each axis, usually around 512
int vertValue, horzValue;  // Stores current analog output of each axis
const int sensitivity = 200;  // Higher sensitivity value = slower mouse, should be <= about 500
int mouseClickFlag = 0;
//int invertMouse = 1;        //Invert joystick based on orientation
int invertMouse = -1;         //Noninverted joystick based on orientation
  pinMode(horzPin, INPUT);  // Set both analog pins as inputs
  pinMode(vertPin, INPUT);
  pinMode(selPin, INPUT);  // set button select pin as input
  digitalWrite(selPin, HIGH);  // Pull button select pin high
  delay(1000);  // short delay to let outputs settle
  vertZero = analogRead(vertPin);  // get the initial values
  horzZero = analogRead(horzPin);  // Joystick should be in neutral position when reading these
  Mouse.begin(); //Init mouse emulation
  vertValue = analogRead(vertPin) - vertZero;  // read vertical offset
  horzValue = analogRead(horzPin) - horzZero;  // read horizontal offset
  if (vertValue != 0)
    Mouse.move(0, (invertMouse * (vertValue / sensitivity)), 0); // move mouse on y axis
  if (horzValue != 0)
    Mouse.move((invertMouse * (horzValue / sensitivity)), 0, 0); // move mouse on x axis
  if ((digitalRead(selPin) == 0) && (!mouseClickFlag))  // if the joystick button is pressed
    mouseClickFlag = 1;
    Mouse.press(MOUSE_LEFT);  // click the left button down
  else if ((digitalRead(selPin)) && (mouseClickFlag)) // if the joystick button is not pressed
    mouseClickFlag = 0;
    Mouse.release(MOUSE_LEFT);  // release the left button
Hey bro, I don't know why but after restarting my PC joystick mouse works.
Ufh, Finally it worked.
Control Mouse scroll wheel & Mouse x-axis movement
This is the final version of my code
#include <Mouse.h>
int lastStateCLK;
bool xControlEnabled = false; // State to control X-axis movement
  Mouse.begin(); // Start the mouse emulation
      if (xControlEnabled) {
        Mouse.move(1, 0, 0); // Move X-axis to the right
        Mouse.move(0, 0, 1); // Scroll up
        Mouse.move(-1, 0, 0); // Move X-axis to the left
        Mouse.move(0, 0, -1); // Scroll down
  // Check for button press to toggle X-axis control
  if (currentButtonState != lastButtonState && currentButtonState == LOW) {
    // Toggle the control state
    xControlEnabled = !xControlEnabled;
