Control whether cables are cut or not?
Hello everyone.
I want to check if any of the 3 wires between Arduino and sensor are cut. How can I do this from within arduino?
ARDUINO SENSOR
5V ---------------------------------------- 5V
GND ---------------------------------------- GND
D4 INPUT ---------------------------------------- SENSOR DATA
Read the sensor, if you get nothing, one of the wires is cut.
Thanks. But sensor is digital, not analog.
I'm not sure how being digital would make a difference.
The first thing I would do is disconnect each wire the two wires etc. and document what happens. From there is should be obvious how to approach a testing scheme.
An ANALOG reading on the 5 volt line would give an indication of either GND or 5V not being there.
This topic was automatically closed 90 days after the last reply. New replies are no longer allowed.
