La cosa es que tengo 16 años y estoy empezando con esto... he intentado hacer un código para una mano articulada que funciona con 5 servos (cadauno controla un dedo) y cada servo se regula con un potenciometro. El problema es que al conectar los servos y los potenciometros y encenderlo todo, los servos se mueven solos de un lado para otro sin ningun tipo de control....
Muchas gracias de antemano.
#include <Servo.h>
Servo myservo;
Servo servo2;
Servo servo3;
Servo servo4;
Servo servo5;// create servo object to control a servo
int potpi = 0;
int pot = 1;
int potp = 2;
int po = 3;
int p = 4;// analog pin used to connect the potentiometer
int val; // variable to read the value from the analog pin
int val1;
int val2;
int val3;
int val4;
myservo.attach(9);
servo2.attach(8);
servo3.attach(7);
servo4.attach(6);
servo5.attach(5);// attaches the servo on pin 9 to the servo object
val = analogRead(potpi); // reads the value of the potentiometer (value between 0 and 1023)
val = map(val, 0, 1023, 0, 180); // scale it to use it with the servo (value between 0 and 180)
myservo.write(val); // sets the servo position according to the scaled value
delay(15); // waits for the servo to get there
val1 = analogRead(pot); // reads the value of the potentiometer (value between 0 and 1023)
val1 = map(val1, 0, 1023, 0, 180); // scale it to use it with the servo (value between 0 and 180)
servo2.write(val1); // sets the servo position according to the scaled value
val2 = analogRead(potp); // reads the value of the potentiometer (value between 0 and 1023)
val2 = map(val2, 0, 1023, 0, 180); // scale it to use it with the servo (value between 0 and 180)
servo3.write(val2); // sets the servo position according to the scaled value
val3 = analogRead(po); // reads the value of the potentiometer (value between 0 and 1023)
val3 = map(val3, 0, 1023, 0, 180); // scale it to use it with the servo (value between 0 and 180)
servo4.write(val3); // sets the servo position according to the scaled value
val4 = analogRead(p); // reads the value of the potentiometer (value between 0 and 1023)
val4 = map(val4, 0, 1023, 0, 180); // scale it to use it with the servo (value between 0 and 180)
servo5.write(val4); // sets the servo position according to the scaled value
