Controling 2 leds by midi CC help
Hi
I am trying to get 2 leds to turn on and off from a Midi Control Change, 82 for led 1 and 83 for led2. it works at the moment for just 82 led1 and not for the second led. can someone tell me where i have gone wrong in the code.
The plan would be to control 8 leds.
Thank you
#include <MIDI.h>
#include <midi_Defs.h>
#include <midi_Message.h>
#include <midi_Namespace.h>
#include <midi_Settings.h>
// Let's define the MIDI channel
#define MIDI_CHANNEL 1
// The LED we're going to light
#define LED 13
#define LED2 9
// The CC we'll handle, can be changed
//The CC values we'll handle, can be changed
#define CC_TOGGLE_ON 127
#define CC_TOGGLE_OFF 0
MIDI_CREATE_DEFAULT_INSTANCE();
int pc;
int cc;
int ccValue;
  // Starting to listen on the specified MIDI channel
  MIDI.begin(MIDI_CHANNEL);
  pinMode(LED, OUTPUT);
  pinMode(LED2, OUTPUT);
  int CCnumber[8] = {82, 83, 22, 23, 24, 25, 26, 27};
  // If we have a message, we treat it
  if (MIDI.read()) {
    // Get the type of the message we caught
    switch(MIDI.getType()) {
      // If it is a Control Change
      case midi::ControlChange:
        cc = MIDI.getData1();
        if (cc == CCnumber[0]) {
          ccValue = MIDI.getData2();
          if (ccValue == CC_TOGGLE_OFF) {
            digitalWrite(LED, HIGH);
          } else if (ccValue == CC_TOGGLE_ON) {
            digitalWrite(LED, LOW);
        if (cc == CCnumber[1]) {
            digitalWrite(LED2, HIGH);
You have the case statement wrong. You are switching on MIDI.get type, you have the first case statement as ControlChange: and then you have a break. This means the second lump of code can never run.
Cheers Mike
