Controling a Solar Panel with two servos
Hello everybody,
I wrote a simple sketch to follow a light source using 3 sensors (LDR or phototransistors) and two hobby servos. I'm share with you because it could be used on other didatics applications. Any question, please let me know... Good luck and have fun.
Guto
Matão-SP
gutosan@terra.com.br
The Sketch:
// Controlling a solar panel with two servos and three photo-transistors
// I suggest high-torque servos to straight control of your solar panel.
// By José Augusto Santaella - Concluding degree in Mechatronics Engineering
// Anhanguera Matão-SP
// e-mail address: gutosan@terra.com.br
// Example for the cientific project of Mr. Carlos Eduardo Servidoni - SENAI Araraquara-SP
// This sketch could be used for education and other purposes
// void loop instruction in English and Portuguese.
#include <Servo.h>
Servo servo_x; // create servo object to control a servo
Servo servo_y; // create servo object to control a servo
int sensor0 = 0; // analog pin used to connect the phototransitor 0
int sensor1 = 1; // analog pin used to connect the phototransitor 1
int sensor2 = 2; // analog pin used to connect the phototransitor 2
int fotocel = 3; // analog pin used to connect the solar panel
int var_a; // variable to read the value from the analog pin 0
int var_b; // variable to read the value from the analog pin 1
int var_c; // variable to read the value from the analog pin 2
int volts; // variable to read the value from the analog pin 3
float V; // variable that will be used with floar numbers
int eixo_x=90; // variable to manipulate x-axis position (starting on 90 degrees)
int eixo_y=90; // variable to manipulate x-axis position (starting on 90 degrees)
servo_y.attach(9); // attaches the servo on pin 9 to the servo object
servo_x.attach(10); // attaches the servo on pin 10 to the servo object
Serial.begin(9600); // Start serial communication
var_a = analogRead(sensor0); // reads the value of the photo-transitor (value between 0 and 1023)
var_a = map(var_a, 0, 1023, 0, 100); // scale it to use it with the servo position calculations (value between 0 and 100)
var_b = analogRead(sensor1); // reads the value of the photo-transitor (value between 0 and 1023)
var_b = map(var_b, 0, 1023, 0, 100); // scale it to use it with the servo position calculations (value between 0 and 100)
var_c = analogRead(sensor2); // reads the value of the photo-transitor (value between 0 and 1023)
var_c = map(var_c, 0, 1023, 0, 100); // scale it to use it with the servo position calculations (value between 0 and 100)
volts = analogRead(fotocel); // reads the solar panel voltage
volts = map(volts, 0, 1023, 0, 500); // scale it to use it with command serial print (value between 0 a 500)
// Portuguese:
if (var_a > var_b) // comparamos a origem com o eixo y
eixo_y = eixo_y + 1; // se a > b então aumenta um grau
eixo_y = constrain(eixo_y, 0, 179); // estabelece a faixa entre 0 e 179 grau para não estourar a contagem
servo_y.write(eixo_y ); // escreve o valor calculado na variável do eixo y
delay(10); // temporiza 10 milisegundos (faixa testada entre 10~100)
// English:
if (var_a < var_b) // comparing the origin with the y-axis
eixo_y = eixo_y - 1; // if a < b then a degree decreases
eixo_y = constrain(eixo_y, 0, 179); // Establishes the range Between 0 and 179 degree not to over count
servo_y.write(eixo_y); // writes the calculated value in the y-axis variable
delay(10); // temporize 10 milliseconds (range tested between 10 ~ 100)
if (var_a > var_c) // o mesmo para o eixo x
eixo_x = eixo_x + 1;
eixo_x = constrain(eixo_x, 0, 179);
servo_x.write(eixo_x);
delay(10);
if (var_a < var_c) // the same for the x-axis
eixo_x = eixo_x - 1;
delay(10);
Serial.print("Eixo X = " );
Serial.print(eixo_x);
Serial.print(" Eixo Y = ");
Serial.println(eixo_y);
Serial.print("Tensao = ");
V = float (volts) / 100.00; //using decimal point
Serial.println(V);
Serial.print(" Volts");
This is last Sketch for the Solar Panel Controler:
#include <Servo.h>
Servo servo_x;
Servo servo_y;
int sensor0 = 0;
int sensor1 = 1;
int sensor2 = 2;
int foto_1 = 3;
int foto_2 = 4;
int var_a;
int var_b;
int var_c;
int volts1;
int volts2;
float V1;
float V2;
int eixo_x=90;
int eixo_y=90;
int tmpSer=0;
int tmX=0;
int tmY=0;
servo_y.attach(9);
servo_x.attach(10);
var_a = map(var_a, 0, 1023, 0, 10);
var_b = map(var_b, 0, 1023, 0, 10);
var_c = map(var_c, 0, 1023, 0, 10);
volts1 = analogRead(foto_1);
volts1 = map(volts1, 0, 1023, 0, 500);
volts2 = analogRead(foto_2);
volts2 = map(volts2, 0, 1023, 0, 500);
if (tmY==0)
if (var_a > var_b)
eixo_y = constrain(eixo_y, 45, 135);
} else if (var_a < var_b)
if (tmX==0)
if (var_a > var_c)
eixo_x = constrain(eixo_x, 45, 135);
} else if (var_a < var_c)
if (tmpSer==0)
Serial.print("V1=");
V1 = float (volts1) / 100.00;
Serial.print(V1);
Serial.print(",");
Serial.print("V2=");
V2 = float (volts2) / 100.00;
Serial.println(V2);
tmpSer++;
if (tmpSer==400)
tmpSer=0;
tmX++;
if(tmX==20)
tmX=0;
tmY++;
if(tmY==20)
tmY=0;
Gutosan,
What is the difference between the two skecthes that you posted?
Hello CSigleton,
The differences are in the void loop, you will find three new time variable to replace the "delay times"(tmX and tmY). Working that new way, we will keep the program running no matter the time used to compare de sensor variables (now you could set one time for X and other for Y), and also we can set the serial transmition data rate (tmpSer). Using delays means a lot of stops during program execution.
Tks,
Guto.
