Controling bldc hoverboard wheels with RF remote movement problems
#include <RCSwitch.h>
RCSwitch mySwitch = RCSwitch();
unsigned long   TimerUp;   //UP arrow on the remote
boolean         TimerUpFlag = false;
unsigned long   dummy;
unsigned long * TimerPtr = &dummy; //pointer to the current timer
int speedSetting = 0;
int speedSettingLeft = 0;
int speedSettingRight = 0;
const byte leftWheel         = 9;  //turns on as long as the UP button is pressed
const byte rightWheel        = 10;
const byte reverseRightWheel = 8;
const byte reverseLeftWheel  = 7;
const byte leftBrake  = 6;
const byte rightBrake = 5;
  mySwitch.enableReceive(0);  // Receiver on interrupt 0 => that is pin #2
  pinMode(leftWheel, OUTPUT);
  pinMode(rightWheel, OUTPUT);
  pinMode(reverseRightWheel, OUTPUT);
  pinMode(reverseLeftWheel, OUTPUT);
  pinMode(leftBrake, OUTPUT);
  pinMode(rightBrake, OUTPUT);
  if (speedSetting > 14) {
    Serial.println(speedSetting);
    speedSettingLeft = speedSetting - 14;
    speedSettingRight = speedSetting - 14;
  if (mySwitch.available()) {
    processButton();
    mySwitch.resetAvailable();
  if (TimerUpFlag && millis() - TimerUp >= 250ul)
    TimerUpFlag = false; //disable timing
    TimerPtr = &dummy;   //pointer to dummy timer
    digitalWrite(leftWheel, LOW);
    digitalWrite(rightWheel, LOW);
    digitalWrite(reverseRightWheel, LOW);
    digitalWrite(reverseLeftWheel, LOW);
    digitalWrite(leftBrake, LOW);
    digitalWrite(rightBrake, LOW);
void processButton()
  switch (mySwitch.getReceivedValue())
    case 12188945:
      Serial.println("BACK");
      TimerPtr = &TimerUp;  //point to this timer
      //TimerUpFlag = true;   //enable timing
      digitalWrite(reverseRightWheel, HIGH);
      digitalWrite(reverseLeftWheel, HIGH);
      analogWrite(leftWheel, speedSetting);
      analogWrite(rightWheel, speedSetting);
      TimerUp = millis();
      break;
    case 12188939:
      Serial.println("FWD");
      TimerUp = millis();
      break;
    case 12188941:
      Serial.println("LEFT");
      analogWrite(leftWheel, speedSettingLeft);
      TimerUp = millis();
      break;
    case 12188943:
      Serial.println("RIGHT");
      analogWrite(rightWheel, speedSettingRight);
      TimerUp = millis();
      break;
    /*******************SPEED SETTINGS********************/
    case 12188935:
      Serial.println("SPEED 100");
      speedSetting = 60;
      TimerUp = millis();
      break;
    case 12188936:
      Serial.println("SPEED 50");
      speedSetting = 40;
      TimerUp = millis();
      break;
    case 12188937:
      Serial.println("SPEED 25");
      speedSetting = 15;
      TimerUp = millis();
      break;
    /*  case 0xFF30CF:
        Serial.println("SPEED 4");
        speedSetting = 55;
        TimerUp = millis();
        break;
      case 0xFF18E7:
        Serial.println("SPEED 5");
        speedSetting = 70;
        TimerUp = millis();
        break;
    //**********************BRAKE/STOP*********************
    case 12188929:
      Serial.println("BRAKE");
      digitalWrite(leftBrake, HIGH);
      digitalWrite(rightBrake, HIGH);
      TimerUp = millis();
      break;
