I don't understand what's wrong with this code, when I put the DMX.simpleWrite command before the IR.enableIRIn(); in the setup. The projector rotates correctly however when it is put after (in the loop or not) nothing works. By the way i'm trying to control a projector via a DMX adapter connected to arduino (Pin 3).
le code :
#include <DmxSimple.h>
#include <IRremote.h>
int hori = 0;
int vert;
int cool;
int form;
String posHori;
String posVert;
String posCool;
String posForm;
int isHori = 0;
int isVert = 0;
int isCool = 0;
int isForm = 0;
IRrecv IR(2);
int ir;
IR.enableIRIn(); // cette commande bloque le projecteur
//DmxSimple.usePin(8); // pas utile (port par defaut)
DmxSimple.write(9, 255); // allumes la lumière
if (IR.available()) {
/*Serial.print("Horizontal (0° à 360°) : ");
while (isHori == 0) {
while (Serial.available() != 0) {
posHori = Serial.readString();
//hori = hori + posHori;
//if (posHori == 10) { isHori = 1; } // fin transmission msg (si Serial.read)
isHori = 1;
posHori.trim(); // enleve la mise a la ligne
hori = posHori.toInt(); // converti le String en int
hori = map(hori, 0, 360, 0, 172);
Serial.println(hori);
/*Serial.print("Vertical (0° à 280°) : ");
while (isVert == 0) {
posVert = Serial.readString();
//vert = vert + posVert;
//if (posVert == 10) { isVert = 1; } // fin transmission msg (si Serial.read)
isVert = 1;
posVert.trim(); // enleve la mise a la ligne
vert = posVert.toInt(); // converti le String en int
vert = map(vert, 0, 280, 0, 255);
Serial.println(vert);
/*if (IR.decode()) {
//ir = IR.decodedIRData.decodedRawData;
if (IR.decodedIRData.decodedRawData == 0xFD02BF00) {
Serial.println("bouton appuyé");
hori = 128;
ir = 0;
IR.resume();
DmxSimple.write(1, 230);
DmxSimple.write(2, 50);
DmxSimple.write(6, cool);
DmxSimple.write(7, form);
isHori = 0;
isVert = 0;
isCool = 0;
isForm = 0;
Serial.println("***** program send *****");
delay(10);
